Anyone used premium fuel????
Discussion in 'Prius c Fuel Economy' started by Fernando Colon, Oct 19, 2013.
Thread Status:
Not open for further replies.
  1. Fernando Colon
    Fernando Colon New Member
    Guayama, Puerto Rico
    Any reports on mpg's while using premium fuel????
  2. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
  3. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    "premium fuel" does not have more energy in it than regular. You will get exactly the same MPG.
    minkus, KK6PD, TC400 and 2 others like this.
    49,455
    i think a few people have tried it with no success.
    dbcassidy likes this.
  5. -1-
    -1- Don
    1,247
    434
    Chester, Virginia
    :)It's really sad the number of cars that require premium unleaded. I've been told the Smart car requires it?
    snead_c likes this.
  6. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    It should get (almost) the same MPG as 87 Octane, just cost more.
    Premium vs. Regular | Car Talk
  7. Prius NZ
    Prius NZ Junior Member
    70
    27
    Auckland, New Zealand
    If by Premium you mean higher octane fuel in the C it has no difference. High octane fuels are just more expensive so although your mpg with stay the same each mile will actually cost more. You will find several threads regarding high octane fuel already here. Cheers
  8. orenji
    orenji Senior Member
    5,884
    3,486
    I use 91 and I use it because it does not cost that much more, and it will keep the engine cleaner, they put more detergent in 91 over 87 OCT. I have done this with all my cars.
  9. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Should it worry you, just use Top Tier gas, as Toyota recommends:
  10. orenji
    5,884
    3,486
    Some cars are noted to be able to run on 87 to market the car, but really run better on 91 and Subaru is one of them. I have seen cars that knock and ping on 87 and are suppose to run on 87, switch to 91, the knocking and pinging is cured.
  11. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    I thought this was about the Prius c? I never meant to imply hat no car ever built needed Premium.
  12. orenji
    5,884
    3,486
    I will spend a little more for top tier gas and 91 OCT, its better gas, just like Mobil 1 is better oil.
  13. -1-
    -1- Don
    1,247
    434
    Chester, Virginia
    :)Fine. Nothing wrong with your logic. Same with changing oil sooner than the manufacturers recommended schedule. As a former military guy, I can follow orders, and I'll comply with what the manufacturer recommends.
  14. johnhlong
    johnhlong Junior Member
    89
    29
    East Carbon, Utah, USA
    If you want better MPG check the Ethanol content level not the octane.
    E10 (or 10% Ethanol) seems to be the standard now but E0 (no Ethanol added) has more energy per gallon of gas hence it delivers better MPG then the 10% stuff. E0 fuel is becoming harder to find but it is still out there.
    Octane refers to the amount of additives added to reduce knocking.
    If you want best MPH stick with E0 fuel. (Might cost a bit more but gives you better bragging rights :rolleyes: )
    If you want best cost / mile use standard 87 Octane E10 fuel.
    John
    minkus likes this.
  15. snead_c
    snead_c Jam Ma's Car
    667
    58
    Hendersonville
    NOT very smart !:eek:
  16. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    Not much about the smart car is...
  17. orenji
    5,884
    3,486
    Most small Euro cars require premium, 91. The Fiat 500 does as does Mini Cooper S.
  18. steveoknievo
    steveoknievo Member
    225
    79
    17
    ^^ All the more reason to get a "C"!
    ztanos likes this.
  19. mahout
    mahout Active Member
    655
    116
    NC
    When we go to the track we always refill with 91 octane as a safety measure. We have seen mpg gain of 1 to 2 mpg but we attribute that to less ethanol in the p[remium than regular. Anyway, premum costs more tan its worth.
  20. Larry Greenwald
    Larry Greenwald Junior Member
    67
    16
    2018 Prius
    What about midgrade, 89?
Thread Status:
