Anyone uses Blue Driver OBDII tool?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by VFerdman, Jun 30, 2019.
  1. VFerdman
    VFerdman Senior Member
    1,200
    1,218
    Western Massachusetts
    I just learned about Blue Driver OBDII tool that is supposed to be better than the usual $20 dongle plus Torque Pro. It looks really nice from descriptions, but I am wondering how it is for the hybrid part of the equation. Does anyone use one of these on their Prius? How well does it work for say diagnosing the HV battery, computers and networks related to hybrid systems in the car?
  2. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    The wonders of marketing!
    Ask the makers if their toy can read ALL codes, including sub-codes?
    Ask them if it can perform maintenance tasks: Bleed brakes? Crank engine for compression check? Activate CHRS pump? Activate the HV Battery fan? Other features.
    Let us know what they say.
    If you have NO desire for DIY maintenance, then that toy will probably work. But, all the OBD2 toy bluetooth readers have consistently demonstrated an INABILITY to READ ALL CODES.
    Techstream or comparable professional equivalent, is required to READ ALL CODES and perform maintenance. Getting codes read at the dealer will likely cost you $100+. Ouch, that toy reader costs $99.95 on Amazon! Techstream will give you the same dealer code reading and maintenance capability, as that is what they use. Techstream is the OFFICIAL diagnostic and maintenance software, written for Toyota/Lexus, and used at all Toyota/Lexus dealerships.
    #2 exstudent, Jun 30, 2019
  3. Leadfoot J. McCoalroller
    8,288
    7,800
    Pennsylvania
    2018 Prius c
    The big question:
    Is it smart enough to detect that the car has been turned off so that it turns itself off instead of killing your 12v battery overnight?
    The OBD specification requires that the OBD port receive hot battery power at all times. Therefore any device plugged into the port has the potential to kill your battery. So they have to use some logic to determine whether the car is on and charging the battery, and they have to accurately detect that when the car is off and go into sleep mode. Even in sleep mode it's still taking a little power to check for when it should wake up, so a good one will use very little electricity in that mode.
    It's harder to make this call on a hybrid, because the engine won't run all the time, and 12v charging is provided by the DC/DC converter which seems to have a narrower voltage range than the typical car alternator.
  4. GearHead600
    GearHead600 Member
    64
    74
    Chicago, IL
    I was actually looking at this device too! Would highly appreciate any follow-up info you have. Such as, did you buy one (and all the questions that come with that if you did). Or, has anyone else out there experience with this device and a Prius???
    The top two contenders I was looking at for b/t OBD2 scanners was this Blue Driver and the OBDLink MX.
  5. jessiejosco
    jessiejosco Member
    62
    42
    I have a blue driver and it works fine for routine codes. I don't know about the hybrid codes because I have never had a problem with the hybrid system. It definitely works for the brake and engine codes and it resets them.
    When it reads a code, the Blue Driver app gives you the commonly reported reasons for that code specific to your car, so the app is helpful. It will also monitor a bunch of live data if you are into that.
    It is definitely expensive but it is also universal. It will work on any car with OBD, and as long as you have an internet connection, it interprets many of the codes for you. I would say they justify the cost because of the information on the app, not because it is a special dongle.
    I also have 2 cheap dongles and hacked techstream but have not had much success with it. The first dongle totally crashed the cars computer. Disconnecting the 12v battery fortunately fixed that. I have not had to try the second one yet because the Blue Driver has worked for me. Also getting techstream working on a computer is a real pain, and there is concern about malware so you don't want it on a computer you use for anything else. Genuine techstream would be great but that would be way more expensive than the Blue Driver.
    These are just my experiences with Blue Driver. I'm not saying its the best choice.
    Hersh and GearHead600 like this.
  6. hill
    9,036
    Had ours for about a year, & I can't say this does EVERYTHING that techstream does, but it's mighty close. As far as parasitic draw goes? BlueDriver power consumption is small (<10ma) - using tech similar to cell phones which pulse only periodically to check for an incoming call/transmission while screen is off. Most devices on cars have some kind of milliamp draw ..... gps / time / door lock-prox sensors etc. Even so, if folks are the type that leave there vehicle sitting dormant for weeks or months at a time, one can install an auxiliary power source to run such items. Our dashcams came with those backup power features but we decided to forego.
    #6 hill, Feb 24, 2020
    Hersh likes this.
  7. Willl
    Willl Junior Member
    34
    Orlando
    Is Bluedriver the best wireless odb2 scanner available currently? Does it do ecu coding to enable/disable features in the car? What about others like Carista, Carly, etc.?
    Looking to buy something ASAP. Thanks!
  8. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    It may be overkill. I have been using OBDLink LX for years to capture data for video. It works fine and doesn't cost anywhere as much.
  9. VFerdman
    1,200
    1,218
    I am using Carista with my iPhone 8 and it works just fine. $20 or so. Bluedriver is what? $100? I am not sure it has more capabilities, but I may be wrong. I have not found anything I can't do with Carista yet. Before Carista I had a an inexpensive dongle (still have it, actually) that worked just as well as Carista with Android, but once I got an iPhone it could not connect to its bluetooth for some reason. Carista connects to iPhone and Android just fine. Also inexpensive and works with the apps I use it with like Dr. Prius.
    Sanchan likes this.
  10. Leadfoot J. McCoalroller
    8,288
    7,800
    Pennsylvania
    2018 Prius c
    There aren't many software-accessible options in a Prius. I don't think I'd want to spend much on a tool I'd be done with in 8 minutes.
    VFerdman likes this.
  11. DAVID 4
    DAVID 4 Junior Member
    45
    Slovenia
    I have Carista and BlueDriver.
    Bluedriver get you into more details, gives you more information abouth engine. But is gives you almost no information on hybrid battery. And the biggest downside is that it does not support alternative apps, so no dr. Prius or Hybrid assistant.
    Carista on the other side gives you decent information, but not as much as BlueDriver. Best side is, that it support additional apps, so you can use dr. Prius and hybrid assistant. with carista you get best inview into hybrid battery.
    As for price keep in minde that carista app has subscription, so in long term it is more expensive than bluedriver. Also many apps has it own subscription if you need more tools. Bluedriver has no subscription, so you just buy the dongle and you have full and detail inview into you car.
    To conclude, if you have only prius (or other hybrid) than carista is best for you to keep your hybrid battery in good condition. But if you have other cars as well than bluedriver is best choice. I have older car and carista show me no info, bur bluedriver has no problem.
    hill likes this.
  12. VFerdman
    1,200
    1,218
    You do not need to have a Carista subscription to use it with other apps. It's just $20 or whatever for the hardware and you're good to go. It's worth mentioning that Carista connects to iOS devices as well as Android. Not sure about BlueDriver, but another inexpensive adapter I have that works very well does not connect to iOS, only Android.
  13. Willl
    Willl Junior Member
    34
    Orlando
    Does anyone happen to know the fastest or lowest latency odb2 dongle to be able to use with third party apps?
    It is dealt a shame that there is no way to use bluedriver with any third party
    Longinus876 likes this.
  14. hill
    9,036
    yes - BlueDriver works on both OS's -
    don't know about ALL 3rd party apps - but the couple we tried work fine w/ BlueDriver .... currently using it w/ the 'MyGreenVolt' app.
    #14 hill, May 24, 2021
  15. Canard
    Canard Member
    223
    Ontario, Canada
    Is there a way to get the BlueDriver "Live" tab to graph out the data for MG1 and MG2 speeds? I can't seem to find it, but I know my old Scangauge could read those values and spit them out on the screen.
  16. Longinus876
    Longinus876 Member
    105
    Long Island
    As good as TechStream equipment is, there are still problems with the culture at dealerships. Some people would rather avoid dealers at all cost.
  17. Longinus876
    Longinus876 Member
    105
    Long Island
    I'm thinking of getting Blue Driver to use on a gen 2 Prius that is sidelined due to HV battery problems and other issues. Is that not a good way to go? What 3rd party app were you looking at? I only know Dr. Prius and Torque Pro being applicable to this.
  18. Brian1954
    Brian1954 Senior Member
    2,674
    1,071
    South Central PA, USA
    Autel AP200 for about $60 at Amazon is a better option to read all the possible trouble codes for your Prius. https://priuschat.com/index.php?posts/3290690
