Anyone using 225-40-R18 on their 2017 Prius?
Discussion in 'Prime Accessories and Modifications' started by FSAzhar, Jun 21, 2018.
  1. FSAzhar
    FSAzhar New Member
    Dubai
    Hey there,
    I just bought my 2017 Prius here in Dubai, UAE.
    I am replacing my standard rims with Enki 18x7.5J Alloys and suspension with Tein Street Basis Z Coilovers.
    Question is :
    (1) Should I put 215-40-R18 or 225-40-R18. Will 225 fit or are they too wide?
    (2) How much should I drop front and back? 30 mm? I dont have any body kit on it at a moment.
  2. Rob43
    Rob43 Senior Member
    1,110
    771
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    Welcome to PC.
    Tires: When using a 18x7.5" wheel, a 215/40-18 is the better choice, plus that size tire weighs less which is a good thing.
    Coilovers: Roughly ~30mm's sounds reasonable, just remember two basic rules when lowering. 1) The lower you go, the more
    negative camber you automatically get. 2) If you lower a coilover system "to much" or close to its maximum lowest setting, they function poorly & handling / ride comfort suffers a lot.
    What is the offset (ET) & weight of your Enkei wheels ?
    Rob43
  3. randomwalk101
    randomwalk101 DYI'er
    530
    252
    texas
    Go with Volk ZE40 attack wheel instead. Much better.
  4. Rob43
    Rob43 Senior Member
    1,110
    771
    2013 Prius v wagon
    Let me get this straight......
    You're recommending an ~$800 Each wheel with a poor offset ?
    Rob43
  5. randomwalk101
    530
    252
    texas
    Stock is +43 (??) or so...the volk is +47
  6. Rob43
    Rob43 Senior Member
    1,110
    771
    2013 Prius v wagon
    Stock is ET +40, the Volk ZE40 in a 18x7.5" / 5x100 is ET +48.
    Technically ET +48 will work, but that extra ~1/3" offset is moving the wheel & tire Inward toward the suspension strut.
    Concerning wheel pricing: Don't get me wrong, I like quality products & expensive items, but at roughly ~$4000 Dollars
    for a set of new wheels & tires......I'll pass.
    Rob43
  7. sg333
    sg333 New Member
    CA
    Is there a link for the Tein street basis coilovers for the prime?
  8. FSAzhar
    FSAzhar New Member
    Dubai
    Thanks for your reply. Offset is 45 and weight is 19lbs per wheel
  9. FSAzhar
    FSAzhar New Member
    Dubai
    I took the measurement, I will drop the car by 30mm
  10. Starship16
    Starship16 Senior Member
    1,348
    1,433
    Beach Christmas
    One of the Priuschat boys?
  11. Rob43
    Rob43 Senior Member
    1,110
    771
    2013 Prius v wagon
Loading...
