Anyone waiting for PIP getting the "itch" to consider a Chevy Volt instead?
Discussion in 'Chevrolet Volt' started by Juni2012, Feb 13, 2012.
  1. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    How about for an extra $2,500 after tax credit?
    51,791
    someone said $2500. difference.
  3. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    Somebody mentioned electricity prices in Calfornia at 40 cents per KWH. I have SCE, and the rate depends on how the metering plan selected (on one or separate, time of day charging, etc) but runs from 10 to 13 cents. Where is it 40 cents, does anyone know?
  4. john1701a
    john1701a Prius Guru
    12,817
    5,303
    58
    How is Volt different?
    That implication is misleading. It gives the impression a redesign is needed. When in reality, power-carrier size & ratios along with voltage increase would expand EV ability. There isn't a need to introduce new clutches. What do you want to optimize for?
    Remember, the PHV we get isn't the full implementation. Even more power can be delivered from the existing system. The "EV City" button demonstrates that.
  5. Jeff N
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    It gets up to the 40 cent marginal rate if you use lots of electricity and end up at the top tier. As you know, CA uses a tiered rate scheme that charges more for higher levels of energy use in order to encourage conservation. When you throw in TOU rates it gets even more complicated....
    I'm billed by PG&E in Northern California at the E9a Time of Use rates. I charge at night using 120V when the rates are low and end up using about 1/3 of my 3rd tier. I also do laundry and run the dishwasher during low-rate periods at night or over the weekend. Because E9a applies to my entire household use, I compare my electric bills with the same period in the two previous years before I started charging my Volt.
    The bottom line is that, on an annualized basis, I pay about $15-20 more per month now for an extra 150-200 kWh used to charge the car. So while the marginal 3rd tier is "high" I am effectively paying about 8-10 cents per kWh for the extra power I am using now. On an annualized basis I get about 3.3 miles per kWh so that works out to about 2.5-3.0 cents per mile. If I charged at 240V it would be around 7% more efficient and cheaper but then I would have the initial expense and hassle of installing it in my garage. Driving EV is actually a bit cheaper per mile since I end up getting several free opportunity charges during the month while shopping and dining in nearby cities on my way to various events.
  6. Jeff N
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    It isn't. My point was that most of the complexity concern about the Volt applies to the PiP (and therefore mostly to the non-plug Prius as well).
    I'm not an armchair transmission designer. I'm less sure about that than you are. Some of the same GM engineers who designed the Volt transmission also designed the 2-mode heavy duty hybrid transmission which includes input-split powerflow as a subset of its design. One them also filed the 1995 GM patent which describes the clutch-free input-split transmission design used in the Prius. They understand the various engineering trade offs far better than we do. In any case, I never said Toyota would add clutches. I speculated that Toyota would stop doing "blended EV" when they no longer had to because of battery limitations.
    Have you driven the production PiP with the "EV City" button (with a scan gauge attached)? I'm doubting that it actually uses more battery kW than the 27 kW or 38 kW that have been variously reported for the PiP. I think it is more likely that it just remaps the accelerator pedal in a way that makes it less likely for the gas engine to start unintentionally. In any case, that button doesn't prevent the gas engine from starting when needed and it wouldn't necessarily imply high continuous output even if it allowed a momentary higher kW pulse.
  7. rogerv
    1,639
    317
    Thanks for the explanation. I hadn't considered the ramifications of going into the higher tiers, but just looked at what SCE indicated the difference would be between one and two meters, with the extra one being for ev charging only.
  8. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    If you have a commute where most of the time you're driving at 65mph, you might ask yourself what's the point of paying over $4,000 to get a plug-in facility you can't take full advantage of.
    If you live somewhere where most other trips will put you on the highway driving at 65mph you might ask yourself what's the point of paying over $4,000 to get a plug-in facility you can't take full advantage of.
    If you live in a northern state with a long freezing winter, you might ask yourself what's the point of paying over $4,000 to get a plug-in facility you can't take full advantage of.
    If you haven't heard requests for EV purity it's because this is an Internet forum with text so you've only read. Or if you mean it metaphorically it's because you have your finger in your ears saying lalalalala. I'd have thought that DaveInOlyWA's posts and purchase of a LEAF made it pretty clear that he really didn't want to burn gasoline and he'd very much have liked to be able to buy a Prius BEV.
    Oh, and add me to the list for EV purity. It's not a matter of it being an absolute, it's that I'd like the choice. For example, I'd really like to be able to pick EV if we hurry the 3 miles across the city at 65mph on the Interstate. (Not that it matter that much for 4 or 5 months of the year since the gas engine would be on for heat.)
  9. bisco
    51,791
    i thought you could pick ev on the pip?
  10. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    You can pick EV (The car defaults to it) in the PiP and hurry across the city on the interstate at 62mph or less.
  11. Juni2012
    Juni2012 New Member
    Orange County, CA
    Guys - as the originator of the thread, this is amazing reading with testimonials on each side of the fence. I really appreciate your input. At this point, I have decided to wait until I try the PiP (once available in the next month or two) to make a decision. Mine has a manufacturing date of Mar-Apr, but I hope the car is available for a test drive at any car dealership soon. Thank you all again.
  12. ItsNotAboutTheMoney
    2,287
    460
    Maine
    I know. I could also not hurry across the city. The point is that I'd have more than enough capacity to do it but the car wouldn't let me. It means yet another compromise or diminished value of an expensive car.
  13. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Ah, ok. From what you said it sounded like you were not aware that the PiP could do EV on the highway up to 62mph.
    Even from your above quote, what do you mean by "The point is that I'd have more than enough capacity to do it but the car wouldn't let me." If you have more than enough capacity to do it, how will the car now allow you to do it? Because it will do 62 and not 65mph or more?
  14. bisco
    51,791
    thanks P, i was getting concerned. miss the thanks button already! i can live with 55mph, we have very few 65mph in the greater boston area.
  15. sxotty
    sxotty Member
    224
    28
    Pittsburgh
    Do you honestly think that the owners of the volt are GM enthusiasts? I highly doubt they were classified as such prior to the Volt. The Volt appeals to EV enthusiasts. It certainly greatly appeals to me from a drive train standpoint, they vehicle just doesn't happen to :) I was certainly not a GM enthusiast prior to this either. The last GM I wanted to get in before a Volt was a Nova to strip off some parts for my corolla :)
  16. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    If you hurry, meaning putting the pedal to the metal or close to it, the ICE will start!:mad:
  17. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    If the Volt was able to get near the PiP's MPG once in HV mode or charge sustaining mode I would have given it serious consideration. But low 30mpg's in charge sustaining mode kill it IMO.
  18. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    I have driven the car, once for a week (the 2010 demo) and the pre-production unit in San Francisco last year... I personally don't see it as a big deal, after having had one as described.
    If you really have to floor it for some reason, any reason, big deal it starts the engine. It turns off anyway in a very short amount of time. Of course it'd be gimmicky to say it doesn't come on but for me it's not a OMG kind of thing.
  19. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    If you are going somewhere 3 miles away and you need to constantly floor the pedal, it'll hard on any car. Volt's battery will take a lot of abuse.
  20. bisco
    51,791
    one concern i have about the volt is long term reliability. at this point, with 8 years of no issues on my two pri, two camry's and a hycam, i trust toyota to do it right. gm is gonna have to prove it to me before i lay down 32 smackers. my last gm was an olds intrigue in the late 90's and they canned olds within months after i bought it. the dealership disappeared in the middle of the night.
