Anyone's battery ever go PURPLE?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Nan, Jun 1, 2005.
  1. Tideland Prius
    16,680
    No, the ICE would provide power to the electric motor for extra torque
  2. 8AA
    8AA Active Member
    550
    62
    Maryland
    Keep in mind that there are actually two motor/generators. When you're driving up hills it is common to see both the ICE and the electric motor providing power to the wheels, and no power going to or from the battery. In this balanced state, MG1 is generating power and sending it directly to MG2 to help drive the wheels. This is also a more efficient situation because the inverter is not being used and therefore there are no conversion losses.
  3. sacker1177
    sacker1177 New Member
    Walla Walla, WA
    Thanks, that is something I hadn't thought of. The car is way more sophisticated than I give it credit for.
  4. DanMan32
    DanMan32 Senior Member
    3,799
    27
    Tampa Bay, FL
    Actually, the inverter is being used. Each motor has its own set of power FET transistors connected to a 500V bidirectional power supply. Each motor is a 3 phase AC syncronous motor. Only if they were operating at the exact same speed and phase would it be possible for the inverter to not be in the picture. In the scenario where MG1 powers MG2 without help from the battery, MG1 maintains 500V charge on the 500V capacitor, and MG2 uses that charge.
