Anything need to be greased on a prius???
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Dale Earnhadrt, Apr 15, 2015.
  1. Dale Earnhadrt
    Dale Earnhadrt Junior Member
    chicago
    I have a 1996 ram cummins diesel pick-up and every time I change the oil I hit all the zerks with the grease gun.
    I also own two priuses, (priusses? priaaia?...whatever) an 07 and a 2010. Any grease points on this vehicle?
    As long as were talking about it, what do y'all use to grease the door hinges, etc. White lithium seems kind of messy for these vehicles.
    Any other stuff to lube?
  2. Mendel Leisk
    38,717
    I've used garage door roller lube on the door hinges. It goes on liquid and then kinda gels. Put it on very sparingly, just kinda bleed it in right at the joint, with a straw extension on spray can. Did it when car was new, and again just now, four years later.
    There's no grease nipples. But what you might do is coat every bolt and screw you can get at on the underside, even the ones just holding plastic trim. And all the main suspension pieces. With some sort of wax/oil protectorant.
    With all the minor trim holding fasteners, back them out and saturate.
    Rustproofing the suspension | PriusChat
    #2 Mendel Leisk, Apr 15, 2015
  3. KenSoren
    KenSoren Junior Member
    31
    Yucaipa, CA
    Some think it is important to clean and lube the disk brake slide pins every 30,000 to 50,000 miles, especially if you live in cold country where they use salt and sand on the roads during the winter.
  4. Former Member 68813
    3,524
    981
    US
    interesting. i didn't know something like that existed. but, i thought garage door rollers/tracks should not be lubed?
  5. bisco
    49,469
    they sell it at the garage door store, must be something special. you don't want to attract debris.
  6. Mendel Leisk
    38,717
    This is the stuff. A guy replaced our garage door opener, used it on the rollers, hinges and the chain drive, and left me the can. It seems similar to bike chain lube. He suggested to relube the rollers periodically.
    Fehr Brothers Industries,Inc - Fehr Multi-Purpose Lube (Blue) X 12 Cans
    I see it contains methylene chloride, which can cause cancer, but only in California. :ROFLMAO:
    Hmm, trying to think: are the hinges inside or outside of the door seal gasket? I think outside.
  7. Former Member 68813
    3,524
    981
    US
    well, methylene chloride is also used as paint stripper. i wouldn't use it on anything painted.
  8. Mendel Leisk
    38,717
    Think I'll use something else next time. :oops:
  9. Robert Holt
    Robert Holt Senior Member
    1,313
    888
    For hinges on my aircraft's ailerons and flap guides, I used a curious spray-by-tube lube called LPS2, which comes out of the tube as a kind of foam which then evaporates and leaves a clinging film of oily lube. This application can be done even upside down as the clinginess is very good. So I will use that on the door hinges.
  10. frodoz737
    frodoz737 Top Wrench
    4,297
    2,348
    33
    BMS-33 on big planes though. ;)
    Robert Holt likes this.
  11. Robert Holt
    1,313
    888
    ^^^can we buy that?
  12. Mendel Leisk
    38,717
    Just tell 'em frodoz sent you. ;)
  13. milkman44
    milkman44 Active Member
    591
    386
    Ky
    I lube the hinge on the gas filler door, it' opened so infrequently, I'm afraid it will freeze shut.:ROFLMAO:
  14. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    I manage to grease the driver of my Prius, plural Prii, with copious amounts of beer and steak several times per month.
    It seems to help!
  15. frodoz737
    4,297
    2,348
    33
    You do not want your car smelling like that grease...trust me!
  16. Mike500
    Mike500 Senior Member
    2,593
    764
    I've had a gallon of the thicker LPS3 and have success with it for nearly 30 years.
    Boeshield T9 is good for lighter weight applications. I've got a gallon of that, too.
