Anyway to change 2019 LE Awd Smartkey to open from any door (not just driver door)?
Discussion in 'Gen 4 Prius Accessories and Modifications' started by K S from Seattle, Mar 16, 2020.
  1. K S from Seattle
    K S from Seattle New Member
    seattle
    2019 Prius
    LE AWD-e
    I was wondering if there is a way to reprogram the key or car to allow the 2019 Prius aWD LE smartkey open doors when near any door rather than just the driver door?
  2. Mendel Leisk
    40,586
    Not quite sure what you mean, maybe this:
    alanclarkeau likes this.
  3. The Professor
    The Professor Senior Member
    598
    809
    UK
    Excel
    Only the front door handles have the sensors on them to detect a hand behind them, so you can't use the rear handles with smart entry.
    Whether you have the sensors and antennas necessary near the passenger door, will depend on what trim level you purchased. Some vehicles only allow smart entry via the driver's door.
    EDIT: Above is based on my 2017. May be different on the newer models of course.
  4. K S from Seattle
    seattle
    2019 Prius
    LE AWD-e
    Thanks...if the sensors aren't on each door handle (they aren't on my trip) i guess a hack to the smartkey wouldn't grant the ability for proximity to any door to open all 4 doors - hadn't thought of that.
  5. Salamander_King
    Salamander_King Senior Member
    11,009
    8,935
    New England
    I believe LE trims comes with 1 door SKS. As stated the sensor is located only on the driver side front door. If you opted for higher trims, 3 doors SKS will allow opening passenger side front door and the hatch door, but conversion is not easy. I wouldn't say it's impossible, but would not be cheap or easy.
  6. K S from Seattle
    seattle
    2019 Prius
    LE AWD-e
    Thanks....doesn't seem feasible ;-(
    krmcg and Salamander_King like this.
  7. bisco
    51,155
    probably not. it has been done in previous gens, but a lot of work adding antennae and such
