Anyway to increase the braking force of the Prius C
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by deckbuild, Oct 3, 2015.
  1. deckbuild
    deckbuild Junior Member
    42
    Singapore
    As per title, anyway to adjust it?
  2. se-riously
    se-riously Active Member
    263
    114
    SF Bay Area
    2014 Prius Plug-in
    What do you mean by "braking force"? If you can activate anti-lock brakes, then you can't exert any more "force". If you mean you want better brake feel, then the solutions involve different brake pads, braided brake lines, etc. I personally think none of that is worth it on a Prius on the street, because all of that comes into play only after you've crossed the regen braking threshold.
  3. SwhitePC
    SwhitePC Active Member
    495
    214
    ca
    do a project to replace the rear drums with disc brakes? =P
    you can't be pushing your prii that hard to require that much braking force? other than that you're probably better off just replacing the tires
  4. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    People are running Prii with stock brakes in autocross and not complaining, what exactly is the issue? Not enough brake force or pedal is hard to press? Brake fade in repeated use? If it is the force needed I think you can look into aftermarket brake pedal
  5. Mendel Leisk
    38,732
    Which direction? :)
  6. CR94
    CR94 Senior Member
    2,642
    1,138
    Northwestern S.C.
    Yes. Press harder on the pedal.
  7. Lucifer
    Lucifer Senior Member
    1,014
    485
    Nh
    More air in your tires will give more overall response, including braking.
    But if you have a soft pedal, see a dealer.
  8. deckbuild
    42
    Singapore
    Yep, the brake pedal is rather soft now, am thinking how to address this issue, don't intend to change any physical components of the brakes.
  9. bisco
    49,504
    have you checked the fluid level?
  10. Toppcat
    Toppcat Member
    223
    69
    Northern California
    If all others fails! I know one thing that will work for sure! Start working out! Leg press! After a while you be able to smash that brake pedal through the floor pan!
    merged
    Jk. If you have a soft pedal. there could be air trapped in the brake fluid system. Suggest having it look at by experience ABS toyota mechanic.
  11. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    It's been done! Almost, anyway - a Prius c driver here mashed the brake pedal so hard in an emergency stop that it had to be replaced:
    Stuck My Foot In It - REALLY Hard | PriusChat
  12. iplug
    iplug Senior Member
    2,455
    1,703
    Rocklin, CA
    It's a bit much, but this might work:
    dbcassidy likes this.
  13. DKTVAV
    DKTVAV Active Member
    510
    101
    In case, it's still not enough there's this:
    J/K.
    I think you need to go to a reliable repair shop. Braking is the most important thing in driving.
  14. Mr Incredible
    Mr Incredible Chance favors the prepared mind.
    955
    506
    Neb
    Yeah, that was me. Someone pulled out in front of me and it was an emergency stop situation. I mashed the brake so hard that it bent the bracket that holds it to the car. The brake lights wouldn't go off is how I discovered it. Fixed under warranty.
    For a stock car, and without expensive modifications, I would recommend you simply put on stickier tires. They're pretty good as-is, but some circumstances warrant three feet less stopping distance!
    Also, stop driving in such a fashion as would require better brakes. Look ahead and anticipate other drivers' actions. I've been driving motorcycles for decades and have taken two MSF courses. You learn how to see what's coming and what other drivers will do before they even do. Sometimes it still isn't enough, but it helps the other 99 percent of the time.
    ftl likes this.
  15. dbcassidy
    dbcassidy Toyota Hybrid Nation, 8 Million Strong
    1,581
    290
    Middlesex County, MA
    Unless your're towing or hauling weight in the C, disc brakes don't buy you much more in braking. Besides most of the braking occurs in the front.
    DBCassidy
    CR94 likes this.
  16. Mendel Leisk
    38,732
    Always a good ploy, good for mpg too. :)
  17. LDB
    LDB Member
    279
    71
    Friendswood (Houston south suburb)
    As suggested, get the brake system checked by an experienced and reputable mechanic. If the system is all within specs with good fluid then check your tires. Are they worn or over/under inflated severely and/or unevenly? Then consider changing tires for something with a better contact patch and better handling/braking performance. Finally, carefully inspect the BC, the braking controller / brain cells to be sure they are keeping the go too fast follow too close lever, the foot, from causing the car to go too fast and/or follow too closely and thereby require harder braking.
    CR94 likes this.
  18. Silver bullit
    Silver bullit Right Lane Cruiser
    608
    210
    San Diego, California
    How about Fred Flintstone's method?
