Anyway to open all doors with smart key?
Discussion in 'Gen 3 Prius Main Forum' started by MPGMachine, Jun 10, 2012.
  1. ES44AC
    ES44AC C.A.U.S
    319
    77
    No go there either with the other fob, it acts just like the first one did.
    Thanks for sticking with me, I have no idea what the trouble is.
    Cheers!
  2. markabele
    5,084
    1,782
    Nebraska
    My switch to just clicking the fob once to get all doors to unlock came because of the settings screen on the infotainment center.
  3. SoCalBPrius
    SoCalBPrius Active Member
    563
    118
    SoCal
    Take it to the closest dealer, I'm sure they can fix it for you:).
  4. ES44AC
    ES44AC C.A.U.S
    319
    77
    I misread or didn't understand what the OP was asking.
    I read it as if he/she wanted all 4 doors to unlock using the SKS.
    Now today I find that if I touch my driver's door handle it unlocks the passenger side too! So I guess it did work for me after all. Still have to push the button on the SKS tho' to unlock all 4 doors but touching the handle now unlocks passenger door as well.
    Whew!
    Thanks to all
  5. SoCalBPrius
    563
    118
    SoCal
    Glad u got at least 2 doors to unlock/lock but I didn't even know that was an option as I thought it was 1 door(drivers side) or 5 (all 4 doors plus the rear hatch). Did u check the other doors just to make sure:) ?
  6. ES44AC
    ES44AC C.A.U.S
    319
    77
    [quote="SoCalBPrius, post: 1582797, member: 84227" Did u check the other doors just to make sure:) ?[/quote]
    Yes they all do so I am a happy camper now much easier than the 2 step process!
    Thanks to all :D
  7. srivenkat
    srivenkat Active Member
    596
    93
    IL
    On what models can one open the hatch using SKS? I have a III with solar pkg.
  8. Mendel Leisk
    41,463
    You just need to hold down lock and either the unlock or panic buttons, not all three.
  9. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    On my v, there are two separate 'unlock All' procedures:
    As stated in the video there is a Button Press to make the Fob Unlock all on the first push, rather than on the second push.
    There is also a 'grab the door handle and it unlocks all setting' that is in the multi function display and/or a dealer setting.
    [Edit: And while I was typing Mendel gave the correct info for a Gen 3]
  10. sardog
    sardog Junior Member
    25
    Tampa FL
    Awesome!! Works great on my 2013 II
  11. xliderider
    xliderider Senior Member
    8,140
    3,276
    Honolulu, HI
    On our III with navigation, you have to first unlock the doors before the hatch will open using the rubber button to release the hatch.
    There is a thread on these forums on adding SKS to the hatch and or passenger doors. It involves buying parts and wiring though.
  12. xliderider
    8,140
    3,276
    Honolulu, HI
    srivenkat likes this.
  13. swich2mac
    swich2mac Go Hard or Go Home!
    319
    38
    Franklin, TN
    To clarify, do you hold the panic and unlock for 5 seconds and then press the lock button or do you simply press and hold all 3 simultaneously for 5 seconds?
  14. xliderider
    8,140
    3,276
    Honolulu, HI
    Follow the instructions in post #28 above. ;)
  15. mnsweeps
    mnsweeps Member
    108
    16
    Los Angeles CA
    Beautiful..worked on my 2012 Prius Four.
  16. Magnus
    Magnus Junior Member
    23
    West Coast
    I can't get it to work on our 2011 either, the 4 doors thingey shows up but then when I try to unlock the doors it only unlocks the drivers door. Tried it 3x. I was, however, able to program the drivers door to unlock all the doors.
    I think our Prius may be "special".....the vent system drives me crazy, I still can't figure out how to work it.
  17. Munpot42
    Munpot42 Senior Member
    1,391
    544
    Santa Monica, Ca. 90405
    What this trick does is allow you to unlock all doors by gripping the drivers's door handle, doesn't affect how the remote itself works.
  18. Magnus
    23
    West Coast
    Is there a way to get the electronic key to open all the doors? With just one push?
  19. xliderider
    8,140
    3,276
    Honolulu, HI
    No, you have to push the unlock button twice.
  20. KB3
    KB3 Junior Member
    Sweet!!! Worked on my 2010 III. Thanks.
