Anyway to open all doors with smart key?
Discussion in 'Gen 3 Prius Main Forum' started by MPGMachine, Jun 10, 2012.
  1. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Yes
    http://www.toyota.com/t3Portal/document/om/OM47685U/pdf/sec_06-02.pdf
    Page 2
    Sadly it requires equipment at the dealership unless you own an OBDII programmer like the Scangauge II or ELM
  2. WilMent
    WilMent diacritic
    369
    149
    New York
    weeeeeeh it works!!!:) Thanks
    Glad I'm not the only one that didn't read a single page of the owner's manual:D
  3. llgeisz
    llgeisz Junior Member
    Sun City AZ
    Just did this on my new Black Cherry Pearl Persona.... The instruction were great and it worked fine....
  4. andreyco
    andreyco Member
    91
    27
    On my 2013 Prius I only had to hold lock & unlock (not panic) to change this setting. An image of the car with 4 doors opened appeared on the speedo cluster.
  5. Fong
    Fong Member
    85
    32
    Arizona
    On the Persona, just hold lock & unlock at the same until remote fob light stop blinking. That if you wanted four doors unlock.
  6. dhendriksen
    dhendriksen Junior Member
    57
    I'm doing this today! All this rune having to open the door and hit the unlock button for passengers to get in!
    Glad I found this thread!
    DROID RAZR HD ? 2
  7. burns_fisher
    burns_fisher Burns
    60
    NH
    Just to clarify in case anyone else is confused :). The video on the first page talks about needing to push all three buttons on the fob to switch the smart key mode. The PDF file a few replies above says only the dealer can do it. On my 2013 model 3, pushing TWO buttons (lock and unlock) and holding a bit switched the car mode so that a single touch on the driver's door unlocks all the doors. I did not see any display but I might have missed it. Perhaps things changed from requiring all three buttons some year between 2010 and 2013!
    Thanks for all who contributed to this thread!
  8. Barryaz1
    Barryaz1 Junior Member
    Scottsdale AZ
    So on my 2015, Type 2, these procedures don't work, even though I do get the 4-doors open on the display. Thoughts?
  9. bisco
    51,944
    welcome! they've probably changed it. what does your o/m say?
  10. Montgomery
    Montgomery Senior Member
    2,254
    2,241
    Orange County, CA
    I just click my fob twice and all four doors unlock. If I don't want the other doors unlocked, I just touch the driver door handle, it unlocks and get in.
  11. Barryaz1
    Scottsdale AZ
    The manual says "see the dealer." Not my first choice - they'll probably charge for it.
    And I want it to work by grabbing the handle. I know I can press the remote button twice.
  12. Barryaz1
    Scottsdale AZ
    So I guess 3/4 of a loaf is better than none - what does work now is that grabbing the driver door handle opens all 4 (actually 5); but I really want to be able to grab the passenger door handle and have everything unlock. Oh well...
  13. Montgomery
    2,254
    2,241
    Orange County, CA
    I don't think the other doors have the touch sensor installed in them. I just reset mine so when I touch the drivers door, the others open.
  14. bisco
    51,944
    some models have 3 door sks.
  15. solrunner
    solrunner Member
    114
    37
    Reston, VA
    There is a way to do this. I think I did it by getting in the car and holding down the unlock button on the fob while sitting in driver seat, or something like that, which changes the setting. You can alternate the setting to make the handle open just the driver door or all doors. If you google it there's probably instructions somewhere.
  16. Barryaz1
    Scottsdale AZ
    I've got that working. I wanted to be able to grab the passenger door and also have that unlock all 4. The 2 seems to not have the needed sensor on the passenger door handle.
  17. Munpot42
    Munpot42 Senior Member
    1,391
    544
    Santa Monica, Ca. 90405
    Just not the 2
  18. xliderider
    xliderider Senior Member
    8,140
    3,276
    Honolulu, HI
  19. solrunner
    solrunner Member
    114
    37
    Reston, VA
    Oh, right. I have a 2013 Two. The sensor is only on the driver door.
