App for OBD2 -2009: historical and battery issue
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ccna101, Jan 16, 2024.
  1. ccna101
    ccna101 Member
    122
    29
    SFO/IAD/DCA
    2020 Prius Prime
    So I am looking at a 100k+ used Prius 2009 : I have multiple obd2 ( LElink, Blue-driver,...) as well as TS.
    I am assume that TS is over-kill ? I just want to read/make sure there is no pending / historical issue , and may be, some individual batteries information .
    Thought ?
  2. pasadena_commut
    pasadena_commut Senior Member
    2,996
    930
    Southern California
    TS might be over kill, but many OBD2 readers have problems getting to all the codes on a Prius. Better over kill than under kill.
    ccna101 and Brian1954 like this.
  3. black_jmyntrn
    black_jmyntrn Senior Member
    1,729
    410
    2013 Prius Plug-in
  4. ccna101
    ccna101 Member
    122
    29
    SFO/IAD/DCA
    2020 Prius Prime
    Thanks, guys: all is good, my TS read and it has a very decent (good reading ) battery, original CAT with cat shield... all in very sound mechanical condition...
    I am reviewing the data now... stand by.
  5. ccna101
    ccna101 Member
    122
    29
    SFO/IAD/DCA
    2020 Prius Prime
    So it is dark, and I don't have all the tool with me (yet) ... I do not want to put the car in drive and back, but here is the scope:
    It is a 2007 Prius, 60k miles or so, with weak ( need jump start )battery, visual brake system warning light and ABS light on, no other light are active :)
    Course of action:
    -Read TS for battery health, replace if needed ( never been replace ).
    -Read TS for ABS and brake system light issue : I should expect my brake fluid to be clean and above minimum mark ?
    Any additional troubleshoot I should do, before reset the lights, and restart ???
    TIA,
  6. bisco
    52,761
    what happen to the 09 with 100k?
  7. ccna101
    ccna101 Member
    122
    29
    SFO/IAD/DCA
    2020 Prius Prime
    No good... I discovered tampering with odo ... I runaway from the car :)
  8. ccna101
    ccna101 Member
    122
    29
    SFO/IAD/DCA
    2020 Prius Prime
    So I have couple of option for 12V battery: Toyota dealer or AGM ... there is a NAPA nearby with 9A51P as next day pick up ( $250-25 rebate) !!! Can someone confirm the 9A51P is the direct fit or I need to -press fit- ?? LOL ...
    Location is near MIA airport, if that is help !!!
  9. ccna101
    ccna101 Member
    122
    29
    SFO/IAD/DCA
    2020 Prius Prime
    Update:
    Since the original driver are no longer answer any question, and no maintenance record of any kind ( LOL), I have to improvise !
    The girl is fine: somewhere in PC there is a used Prius Gen2 checklist and I used it with some modification ... Before turn on ignition, I check all tires, front brake and hand brake, 12V battery, engine overall ( air filter, oil, ... ) .. all are good and it have not been driven for 10-14 months. Both brake fluid, engine fluid and hybrid fluid level are good.
    Try to turn it on ... nada, a jump quickly correct it... IG, good, ACC, good with multiple brake/ABS/brake system on. I can not get TS to read anything (???) . I did a manual clear on pin. 4-13 and all system is ready !.
    12V battery read after charge seem to be fine, so I will not replace it for now. May be later .
    Now I can see TS read fine with no pending code, LOL: can not be this easy ?!!
    I took it for a short 5 minutes, no issue ... then another 50 minutes drive ... no issue, WOW.
    On another subsequent over an hour drive ( over 50 MPH ) the triangle of death, engine check, and system warning light on... but the girl keep going ... I pull off and pull a P0A93. I can see no bubble in the inverter reservoir and this must be it, since I manually touch the inverter pump and feel no vibration !!!
    I head to Stealer, hand them over 250 bucks for the pump ... Installing will be additional 550 bucks and I have to leave the car for a day ??!!! WOW ! I pick up a coolant bottle for 30.
    I drove to my (new) homeboy, hand them the part, they took and install it for 100 bucks, within 25 minutes - including refill the coolant !.
    Car on it way on a truck heading West...
    I think it is a decent deal with 2007 base Prius with 60k miles, and original OEM for less than $8k, with no adventure !
    FYI: I can not get any hybrid battery reading on TS, and of course, my Bluedriver did not . I will have to pay for Torque Pro or one of the app to to check on the hybrid battery . I will update ,
    EV-
