1. The site is migrating to a new server this week, so there will likely be some downtime during that process. You can follow along here for updates.
Apple CarPlay in 22 prius
Discussion in 'Gen 4 Prius Audio and Electronics' started by djmbbandie, Sep 20, 2021.
  1. djmbbandie
    djmbbandie New Member
    Ventura County
    2022 Prius
    Is it normal for CarPlay to only load only when starting a vehicle with the USB plugged in before starting? Whenever I detach it while traveling and want to reattach it while the engine is running CarPlay doesn’t load (example taking pictures outside of the car). Is this normal? The phone I use is an iPhone 11.
  2. MPGboss
    MPGboss Member
    Los Angeles
    2021 Prius
    Carplay should load every time you plug it into the USB. As long as the car is ON / running, you're good to go.
    If you'd rather just jump into the car and let it load wirelessly, get this:
    I really like it and it works as advertised.
Loading...
