Approximate Cost for 30k Maint?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by mbarrows, Dec 4, 2011.
  1. mbarrows
    mbarrows Illini Bird
    210
    17
    Frankfort, Illinois
    Has anybody had the 30,000 mile maintanence done on their 2010 Prius at your Toyota dealer? If so, what was the approximate cost and what did they do?
    I can see in my warranty manual what it is supposed to include but it seems everytime I go into my dealer for scheduled maint. they always want to do a lot more (at a higher cost).
  2. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    You need to take control of your service. Take the manual, explain that THAT is what you will pay for, no matter how much more they do.
    In a Gen 2, about $50 for oil, filter, tire rotation and multipoint inspection at my Toyota Dealer, you will have synthetic oil in a Gen 3, so about $20 more. If the air filters need changing, that can be $30 more.
  3. mbarrows
    210
    17
    Frankfort, Illinois
    Oh I have done just that! I have my manual and won't let them do anything else. I still am curious though because the 30k maint is a major one where they replace the indoor cabin air filter along with oil change, tire rotation etc. There are a lot of things that need to be checked.
    So again, has anybody had this maint. done and what did it cost you approximately?
    Here's what is supposed to be done:
    Clean cabin air filter (solar power ventilation system only)
    Replace cabin air filter (except solar power ventilation system)
    Replace engine air filter
    Replace engine oil and filter ​
    Rotate tires​
    Inspect the following:​
    __ Automatic transmission fluid
    __ Ball joints and dust covers
    __ Brake lines and hoses
    __ Brake linings/drums and
    brake pads/discs ​
    __ Drive shaft boots
    __ Engine/Inverter coolant ​
    __ Exhaust pipes and mountings
    __ Front differential oil
    __ Fuel lines and connections, fuel tank
    band and fuel tank vapor vent system
    hoses
    __ Fuel tank cap gasket
    __ Radiator, condenser and/or intercooler
    __ Steering gear box​
    __ Steering linkage and boots
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    Don't let the dealer take advantage of you. For my Gen II, I paid about $50 for 30,000 service. It should be similar for the Gen III. It will be a bit more if you have them replace the filters, but that is an easy DIY project.
    Tom
  5. Judgeless
    Judgeless Senior Member
    1,821
    257
    Cleveland, OH
    Here is what Toyota recommends.
    Most people can inspect their own mats, the cabin filter is $10 and takes about 3 min to change. To inspect the fluids open the hood and make sure none of them are below the low line. The engine air filter is $8 and to replace it you flip two clips. For a Lube stop to do an oil change with synthetic oil you are looking at $50 and about $20 to rotate the tires.
    That comes to $88 total. I bet the dealer will want over $500. Save your money and go to Lube stop.
  6. Mendel Leisk
    42,101
    It will make a difference if your cabin air filter is due for cleaning or replacement (refer to Judgeless' helpful posting above). Then there's engine air filter replacement, they cost something, maybe $20?
    Replacing oil and filter should be in the range $40~60.
    Rotating the tires and visual inspection of brakes: try doing that one yourself, there's a fair bit of effort in removing and installing 4 wheels, and a decent visual inspection of brakes takes time. $100?
    To go through the remaining checklist, while it's on the hoist? $50?
    Throw in $20 for "shop supplies", I'd guesstimate $250~300, depending on just what filters get replaced.
    Put yourself in their shoes: would you do all that, responsibly and completely, for under a $100? The places that will are bs'ing you and cutting corners, and trying to upsell you, once they've lured you in.
    BTW, looking at that list above, I've often wondered: what the heck is "front differential oil". I think it's just a typo. Or?
  7. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    I just reached 30k with my Gen II. I paid under $30 bucks for the 30k service. You can do 90% of the work your self. I just brought in 3 1/2 bottles of Synthetic Oil, a filter.
    I mentioned don't screw with the Gas Pedal, or the mats. They work just fine!
    The filters are a snap to replace, it took me under 10 minutes!
  8. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    The dealer here wants $275 for a basic 30k. That includes the 0w-20 oil change, tire rotation, engine filter, cabin filter, inspections and adjusting the e-brake.
    I would instead, do the engine and cabin filters yourself and just pay them for a minor service (oil change and rotation) so that the inspections get done.
  9. mbarrows
    210
    17
    Frankfort, Illinois
    Thank you for the information. I am LONG PAST doing this work by myself (used to do all the work on my cars years ago) and will pay the dealer for the things listed in the book.
  10. mbarrows
    210
    17
    Frankfort, Illinois
    Thank you for your estimate and I agree about the places BS'ing.
  11. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I am at 80,000 miles, even including both air filters, I have never had a service exceed $110 unless I asked for items beyond the manual. (I have a Gen 2 so my oil is cheaper, but I have to change it twice as often)
  12. LulzChicken
    LulzChicken Prius Enthusiast
    791
    135
    Alabama
    The only things you should probably be doing are: a tire rotation, oil change, and replace your cabin and engine air filters.
  13. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    38
    Santa Fe, NM
    One of the ABQ dealers just mailed 30K service coupons, $159.95 + tax and shop supplies, for oil, all filters, tire rotate, fluid top-off, and inspection.
  14. Den49
    Den49 Member
    498
    272
    Maryland
    Regardless of what others do and pay, you are left with your own specific options. Since you don't plan to do any of the maintenance yourself, your best strategy is to use this as an opportunity to shop this service among the dealers and qualified independents in your vicinity. Hopefully, you have three or four that you would trust to do the work. You may be amazed at the difference in price between them and find a good alternative source for future work. There are good independent shops that do good work on the Prius. You don't have to use the dealer for nonwarranty work.
  15. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    My 2010 just hit 30,000. Many people here believe that the transaxle fluid should be changed at 30,000, even though Toyota doesn't say so.
    Also note that the $20 Engine air filter is up for replacement at 30K miles, which you can easily replace yourself without tools. It's the black square box right in the top middle of your engine. Pop off the two clips holding the lid in, lift the lid, remove old filter and replace.
  16. Judgeless
    1,821
    257
    Cleveland, OH
  17. The Critic
    3,193
    2,333
    CA
    Saw a coupon in SF advertiser this morning for a 30k service, $159.88, at City Toyota.
  18. chota
    chota Junior Member
    50
    Denver
    I have a Prius III with Solar roof option. Anyone know why the list says to clean the cabin filter for solar ventilation system rather than replace it? Does the solar system have a different cabin filter?
