April MPG averages - Post 'em here!
Discussion in 'Gen 2 Prius Fuel Economy' started by Danny, Apr 5, 2004.
  1. JJay
    JJay New Member
    123
    Vancouver, WA (near Portland)
    Superb mileage!
    I can start out that high for the first 10-20 miles, but if I fall into old driving habits, back down in the 40s!
  2. rflagg
    rflagg Member
    947
    Springfield, VA
    Gotcha beat, at least on the miles part!
    Tank Miles: 542 (!!!)
    Overall Miles: 3900
    Avg Tank Mileage: 50.7 (!!!!)
    Overall Tank Mileage: 50.4
    Avg Temp: 50-60s
    Previous amount filled - 11.04 with a good cup+ backsplash :(
    Current amount filled - 10.000 gallons
    Price per gallon: $1.79
    Believe it or not, the last bar was only flashing the last 11 miles too. I sure do wish they'd fix this gauge - the previous tank, I went close to 100 miles over the 'last bar flashing', and this time it's obvious that I couldn't have gone more than 20 miles at most. Oh well, at least the car went a full week without refueling - something I thought I could never achieve!! If I were getting your mpg efusco, I could probably close in on that 600 mile tank! :)
    -m.
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    -m,
    Don't get too cocky....I'm sitting at 58.9mpg with 180 miles on the current tank....If I can maintain that for another 400 miles........
  4. rflagg
    rflagg Member
    947
    Springfield, VA
    haha! Now if I can just figure out your 'secret' for going from getting 50mpg regularly to getting 55+ regularly... :)
    -m.
  5. cybele
    cybele New Member
    406
    Los Angeles
    Tank miles: 368
    Overall Miles: 2,587
    Avg Tank Mileage: 47.2
    Avg Overall Mileage: 45.4
    Fill Amount: 6.001 gallons (last fill was 7.4 gallons and fewer miles)
    Avg Temperature: mid-sixties
    Price per Gallon: 2.15.9 ($12.96 for fill)
    Price per Mile: 3.5 cents
    I'm very pleased at this tank. I got a longer range (last tank was 337 miles with the same mileage). 140 miles were on the freeway and the rest was daily commuting and errands. The temps were still very low for this time of year and I'm confident if it warms up here I'll do much better.
    I was a little disappointed I couldn't put more in the tank. As you can see, by calculation with how much I filled, I got over 61 MPG, so I know that's not right. I just think I wasn't able to fill the tank, either because the nozzle wasn't functioning optimally or my bladder was really tight. I would not be disappointed if I continued to get 375 miles to the tank (or more if my mileage improves), I think that's an excellent range for a car.
    For the record, the add fuel started blinking about 33 miles before I filled. I just filled because it was convenient, though in the future I think I'm going to try to do it when it's warmer if possible (it was only 53 degrees this morning).
  6. N9IWP
    N9IWP New Member
    148
    Southeast MN
    Tank miles: 381
    Overall Miles: 414
    Avg Tank Mileage: 44.4
    Avg Overall Mileage: 44.4
    Avg Temperature: Mid 50s?? (35-78 range)
    Price per Tank: 15.00
    Avg Price per Gallon: 1.749
    Displayed milage: 46.5
    Still had 2 bars left, but was at a convienent place to refill.
    I refilled 600ft elevation higher than home, so tank 2 is currently displaying 57.6 MPG (mostly hiway)
    Brian
  7. john1701a
    john1701a Prius Guru
    12,840
    5,311
    58
  8. oxnardprof
    oxnardprof Member
    250
    17
    Oxnard, CA
    Date Total miles Tank Miles Comp MPG Gallons Calc MPG Total MPG Price Cost Total Cost
    4/12/2004 387 371 45.4 8.8887 41.7 43.5 2.299 $20.43 $20.43
    4/15/2004 825 437 49.4 9.628 45.4 44.6 2.159 $20.79 $41.22
    4/19/2004 1309 484 48.3 10.192 47.5 45.6 2.159 $22.00 $63.22
    _________________
    This is not the best formatting, but it is quick. My first three tanks in Southern California.
    The bold MPG are the computer mpg, the underlined are the per tank calculated mpg and the italics are the total calculated mpg.
    I use the automatic shut off, lowest pump setting.
    Mixture of freeway (mostly, between 65 and 70 mph) and surface streets with speeds about 40 mph.
    I am pleased with the upward trend in calculated mpg, I am hoping to have a long term rate of 49.
    I usually use A/C, but switch to vent as appropriate. I usually use the cruise control.
    Temperatures here range from 50s to 80s (at least where I travel).
    Another goal is to obtain trips of 60 mpg.
  9. Joel
    Joel New Member
    108
    Houston, TX
    Tank miles: 405
    Overall Miles: 8289
    Avg Tank Mileage: 43
    Avg Overall Mileage: 41
    Avg Temperature: 74F
    Price per Tank: 14.85
    Avg Price per Gallon: 1.65
  10. jimvitz
    jimvitz Junior Member
    94
    Oak Park, IL
    Tank miles: 500
    Overall Miles: 2029
    Avg Tank Mileage: 57
    Avg Overall Mileage: 48
    Avg Temperature: 54F
    Price per Tank: 18.74
    Avg Price per Gallon: 1.98
  11. USK
    USK New Member
    24
    Choshi, Japan
    My last tank
    Tank miles: 810.65 refuel 12.39 gallons (2001-13gallons/tank)
    Overall Miles: 23,705
    Avg Tank Mileage: 68.4 mpg (29.1Km/L) by the screen / 65.4 mpg. by calculation with temperatures in the 55 to 88 degree range
    Avg Overall Mileage: 58.7 mpg by calculation
    Price per Tank: $43.44
    Avg Price per Gallon: $3.50($1=108Yen)
    _______________________
    USK Bordeaux mica 2001
    23,705.93 miles / 403.74 gallons = 58.72 mpg 4/22/04
  12. JJay
    JJay New Member
    123
    Tank miles: 392
    Overall Miles: 1086
    Avg Tank Mileage: 44.2 Calculated: 49.1
    Avg Overall Mileage: 46.0
    Avg Temperature: 55F
    Price per Tank: 16.05
    Avg Price per Gallon: 1.999
    Third fillup. I think I should have gotten another gallon in the tank.
    Only 8.03 gals. with blinking block. Nozzle was way too sensitive at the Chevron station. Thought I'd try Chevron this tank, but paid ten cents more per gallon. We've filled up at ARCO for years.
  13. FredWB
    FredWB New Member
    331
    San Diego, Colli-fornya
    Evan, way to go. You and I are pretty close on overall but your last tank is great! This is my first one over 50 mpg and I'm sure the warmer weather has a lot to do with it. I'm running 40/38 in the tires and planning on going to Mobil 1 at 5000 miles. I just wish we had less traffic and hills here so I could give you a run for your money!! Still I'm very happy with the 51 mpg. I only went 19 miles past the blinking light too so I might have made 500 miles if I was only brave enough, lol.
    How about a quick summary of your technique as a review for us all?
    Tank miles: 447.1
    Overall Miles: 4268
    Avg Tank Mileage: 51.0
    Avg Overall Mileage: 47.8
    Avg Temperature: 70
    Price per Tank: 19.01
    Avg Price per Gallon: 2.169
  14. STPitcher
    STPitcher New Member
    New Hampshire
    Bought my Prius yesterday. I recieved it with a full tank (Thank you!)
    Today, we took a little drive. About 40 miles. Brings the car up to just over 70.
    Today's milage was 54.8 mpg. I thought that was pretty good.
    The fuel gage still shows full.
    I suppose next month, I'll be putting gas in it myself!
    - stp :)
  15. rflagg
    rflagg Member
    947
    Springfield, VA
    Tank Miles: 501mi
    Overall Miles: 4406
    Avg Tank Mileage: 52.4mpg
    Avg Temp: 60-80's
    Gals filled: 10.15gals (1st clicked off at 8.7 gals)
    Cost per gallon: $1.71
    -m.
  16. efusco
    19,891
    1,196
    Nixa, MO
    I've got some relatively significant hills here in the Ozark Mountains to deal with myself! Traffic tends to help a lot of the time.
    I've reviewed my technique else where, but lately the biggest change has been getting into a 'coasting' mode ASAP after reaching or nearly reaching my intended speed. Thus, if the speed limit is 45 I moderately accelerate up to about 44-45mph, take my foot immediately completely off the pedal than very gently put it back down. If there is a slight downhill slope I go into a 'no arrows' or charging arrows state (depending on the steepness of the slope), if it's flat or up hill I go into battery to wheels arrows (when possible). Sometimes the ICE has to kick in, and that's fine, but when I know I have a stop or slower zone coming up I've very careful to avoid the ICE coming back on whenever possible.
    I use the EV button at the very end of some trips to be sure ICE doesn't come back on unnecessarily...and the very beginning on occasional trips where I know I'll have multiple stops over a short distance before I get into an area I can go steady speeds--this REALLY helps the first 5 minute mileage.
  17. jkash
    jkash Member
    889
    West Hills, CA
    Weird fill-up today. The gas-gauge thing is a bit off.
    Tank miles: 380
    Gallons pumped: 8.67
    Price: $2.12 a gallon
    Overall Miles: 2054
    Tank Mileage: 43.8
    Display Avg: 53.6
    Avg Overall Mileage: 49 tank, 52 display
    Avg Temperature: high 60's in morning to 102 on the way home today.
    This is what freaks me out a little:
    Tank Mileage: 43.8
    Display Avg: 53.6
    I think the pump has a lot to do with it. I put in 2 more gallons today than usual. The pump clicked off the first time at just over 6 gallons. I removed the hose and inserted it again, turned it on and it pumped over 2 gallons more. I had to stop it because I could hear it gurgling. Fortunately, the gas didn't come spurting out like I have heard happened to other people. I guess the next tank will tell.
    Jeff
  18. m4prius
    m4prius New Member
    59
    Ohio
    wow...low of 24mpg to high of 61 mpg...however most of the post show around 50 mpg.
    The low in Albany NY of 24 mpg I don't understand???...
    what's up????????? Underinflated tires and high speed and excess weight????????
  19. Brian
    Brian Member
    480
    Bakersfield
    Jkash wrote:
    When the average varies from the tank to the screen, it is because you can drive for 200 miles at 35 mpg and the average becomes 35, then say you drive really nicely and the average jumps up to 45 mpg. Then fill up at 300 miles. The average tank miles would be about 37.5 or something. What I am trying to say is that, the average is mostly the current. The tank average is the whole tank miles.
  20. Mat
    Mat New Member
    26
    Duke University
    I seem to never be able to get up to 45 mpg. I'm currently at 42, and that is only through very careful driving, maximal coasting, never going above 60 mph, briskly but not aggressively accelerating and then using the cruise control once at target speed.
    I'm in NC, where the temperature lately has been in the 70s and warm.
    I just don't know what to do differently, I've really tried to maximize my mileage based on the driving tips I've read from John and others. I haven't optimized the synthetic oil or tire pressure, but I feel like I'm very carefully monitoring my driving.
    I wonder if anyone else has experienced similar frustration. Although, its always difficult to complain when i'm getting 40 mpg at all compared with other non prius cars. And yet, i still feel a little nagging feeling when i recall reading off 43 mpg on my 2001 Prius classic as compared to this current 42 mpg on my 2004 Prius now. I'd hoped to see at least a bump up, not a marginal shift down. I haven't changed my driving style beyond following tips i've seen here and elsewhere.
