Are HV battery ECU'S interchangeable?
Discussion in 'Gen 2 Prius Technical Discussion' started by lmarcucci, Jun 7, 2013.
  1. lmarcucci
    lmarcucci Junior Member
    53
    hershey
    Hi everybody,
    I heard a rumor that HV battery ECU's(the computers in the battery packs) are not interchangeable, and they are programmed specifically to mate with the VIN of the prius(or the main ECU). Is there any true to this? Or can you swap full battery pack assemblies on the fly?
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    I have read of people on here replacing the full HV Battery assembly from a wrecked car. I do not remember any reference to having any issue with doing this.
    Hopefully someone that has done this before will correct me if I am wrong.
  3. lmarcucci
    53
    hershey
    I'll be finding out in the next day. If no one posts, I'll post the results for science.
    jdcollins5 likes this.
  4. Patrick Wong
    18,213
    6,530
    You can swap the entire traction battery assembly without a problem.
  5. vincent1449p
    vincent1449p Active Member
    894
    332
    Singapore
    Hi lmarcucci,
    That is not true, I've replaced just the Battery ECU and not the whole pack in my previous Gen1.
    Vincent
  6. lmarcucci
    53
    hershey
    awesome, thanks, guys.
