Are mountain descents of 4-5 minutes [getting 99+mpg] bad for the battery?
Discussion in 'Gen 2 Prius Main Forum' started by ski.dive, Oct 18, 2013.
  1. zhenya
    zhenya Active Member
    649
    209
    Ithaca, NY
    2013 Prius Plug-in
    Engine braking will only slow your acceleration, not stop it.
    uart likes this.
  2. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    One question that hasn't been raised in this string is why the OP is not invoking the B Mode when traveling down those long descents. In the old days, it was standard practice to downshift to a lower gear when going down a mountainside. B Mode is designed for that purpose. Or at least that is what the owner's manual states to do.
  3. fuzzy1
    10,458
    It does have some light engine braking, though much less than when in B mode. If you put it in N *** to disable that engine braking, you'll find the speed increasing faster.
    *** Don't do this if there is any chance the engine (ICE) is not already spinning. It defeats the car's ability to protect itself, possibly leading to overspeed damage or destruction of MG1.
    uart likes this.
  4. zhenya
    649
    209
    Ithaca, NY
    2013 Prius Plug-in
    In the case of the PIP Neutral means friction braking only - no regen, no engine braking. Is that different on other cars?
    (I use this mode all the time as I live at the top of a hill, so have to shift to N every morning to avoid firing the ICE when the battery is fully charged)
  5. fuzzy1
    10,458
    No, this should be true for all Prii.
    I believe the safe maximum speed for this, without destructively overspeeding MG1, is higher for the PIP than for the other models.
  6. ski.dive
    ski.dive Active Member
    964
    244
    Hutchinson Island,FL. Mt. Snow,VT
    IMPORTANT: Also remember that before I go down that mountain at 80+mph with my foot off the gas and getting 99+mpg, I had to go up that steep mountain only getting 15-18mpg...LOL
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Big mountains in VT makes me remember going down Killington years ago. Done that many times when I lived there long time ago but never in a Prius. Tricky not to overheat the brakes.
    Wicked steep mountain and all the roads to it.
