Are people really getting 40+ MPG in Gen 2?
Discussion in 'Gen 2 Prius Fuel Economy' started by timmyjane, Apr 12, 2017.
  1. 05PreeUs
    05PreeUs Senior Member
    1,097
    564
    MSP
    Today's fill.....
    Lie-O-Meter = 43.9
    Pencil-N-Paper = 40.98
    An error of ~7% :(
  2. dolj
    dolj Senior Member
    8,434
    4,285
    Wellington, New Zealand
    While it might seem bad, if you look at it in terms of gal per 100 miles which is linear, rather than exponential as it is in MPG,
    Lie-O-Meter = 2.278 gal/100 mi
    Pencil-N-Paper = 2.440 gal/100 mi
    Still an error of ~7%,
    but in the real world you are talking a difference of 0.162 gals per 100 miles (2.440-2.278) which is 20.736 fl oz per 100 miles or 0.207 fl oz per mile.
    It does not really rate within the margin of error. Not something I'd worry about.
  3. 05PreeUs
    1,097
    564
    MSP
    A 7% error is completely unacceptable in engineering terms.
    The other thing to notice is that, excluding a very few cases, the L-O-M is ALWAYS optimistic and statistics cannot explain that - it must be deliberate.
  4. dolj
    dolj Senior Member
    8,434
    4,285
    I think the discrepancy between the MFD and pencil 'n paper is probably attributable to the bladder that you lucky people have. And I'd venture to say the error is in the pencil 'n paper figure given the variable amount of fuel added between tanks that the bladder affords.
    My experience is MFD vs calculated is very close still optimistic most times but can be pessimistic as well. The other thing I have noticed is those tanks where I get a lot of pulse and glide in, have a higher (optimistic) discrepancy.
    Data Daedalus likes this.
  5. fuzzy1
    10,413
    Fuel gauging in cars is not about engineering. It is about managing driver behavior and expectations.
    That bladder issue can apply only to variations in individual tanks. It can't explain the consistent bias.
  6. 05PreeUs
    1,097
    564
    MSP
    I made no comment about gauge accuracy, the comment was about L-O-M accuracy and that is an engineering concern.
  7. fuzzy1
    10,413
    I see the L-O-M as a part of fuel gauging. And as such, its accuracy is of no more concern than the fuel gauge level accuracy. It is an optional feature that nearly all cars lacked for generations. Unlike the speedometer, it is not important enough to be regulated by the government.
    In many other world markets, even 7% error is well within the government mandated, and industry normal, speedometer accuracy requirement.
  8. 05PreeUs
    1,097
    564
    MSP
    It's is not, but a completely separate feature from the fuel level gauge. Would you have the same opinion if your radio tuner was off by two stations? After all, no one ever ran out of fuel because the radio was off ;)
    You are ok with being deliberately lied to by software that indicates your MPG is higher than actual? I doubt most consumers would agree and in fact a number of OEMs have paid fines for doing exactly that - misstating fuel economy.
    Yea, not. Even a 1% error at a fuel pump of a filling station will get someone in BIG trouble with the law in every state in the union. Misrepresenting FE by even 1% is enough to influence purchase decisions in the real world.
  9. fuzzy1
    10,413
    Back in the analog tuner days, that was normal. And I still have some analog tuners.
    Let me call your bluff. Please give specific examples of car makers who have been fined for optional fuel economy gauges providing misleading results.
    I am well aware of manufacturers being fined for misstating their required EPA ratings on the required Monroney label. That is not at all the same thing.
    Yea, yes.
    2010 Toyota Prius FCD Inaccuracy | Page 6 | PriusChat
    http://www.unece.org/fileadmin/DAM/trans/main/wp29/wp29regs/r039r1e.pdf
    These issues have been litigated many times here on PriusChat. The Search feature will help you find those threads.
    #109 fuzzy1, Jul 28, 2017
  10. dolj
    dolj Senior Member
    8,434
    4,285
    You are absolutely correct, it will average out over several tanks. However, what I had in mind was an individual tank calculation. Mea culpa.
  11. Data Daedalus
    Data Daedalus Senior Member
    1,025
    1,185
    Wembley, London
    Please find attached my latest "Lie-o-meter" (MFD) MPG readings from my last tankful (42.5 litres of fuel used). I'm sure I could have stretched it to 600 miles, but I wanted to refuel at a specific ESSO fuel station, so I filled up before it got too low.
    iPhone ?
  12. yaoaoatgyf
    yaoaoatgyf Member
    32
    27
    Guthrie, OK, just North of OKC
    New to me 2007 with just over 195,000 miles. Only paid $1,000 for it. Did not use any oil between 194000 and 195,000 when I changed oil. New air filter, and new hybrid battery installed a few weeks ago. New Yokohama touring tires, 185 65 18, inflated to 33 psi.
    The only way to accurately know what mileage you are getting is:
    1. Check your odometer against mileage posts on an interstate (re-calculate as needed).
    2. Over several tanks, keep an accurate record of how much fuel you are using each time.
    3. Do the math.
    After 1,000 miles we are getting right between 44 and 45 mpg. We have a 22 mile commute to the office. It is about 75% highway. I do not baby it, but I don't floor it from every stop light either. I try to drive the same as if I was driving Mom's Buick. Highway speed is between 70 and 75. Pretty much 5 over in town, other than residential areas, where I am normally 5 under (would hate to hit a child, right?)
    Don't know how accurate the fuel economy read outs are on the rest of the gen 2 prii, but ours happens to coincide with my real world calculations. Right now, it shows 44.3 since being reset 1000 miles ago.
    I know I could do better by over inflating tires, and by driving 60 - 65 on the interstate. Just not worth the trade off to me. I realize a LOT of Prius owners driver the Prius much differently than they do a "regular" car, and I think that is where some of the numbers get horribly skewed, as it is not a fair comparison driving your Prius 60 on the highway, and driving your other cars 70 or better.
    Still, with no more than I have in this car, 45 mpg is pretty darn good. Gas prices are almost certain to rise, at least short term. The more expensive gas is, the more the Prius makes sense.
    05PreeUs likes this.
  13. dolj
    dolj Senior Member
    8,434
    4,285
    Congrats on the new to you Prius. Some good information there.
    Most people here find the MFD average MPG about 5% optimistic, but for myself I find it pretty close (but still on the high side), and close enough for me. I have had it pessimistic on a few occasions as well. I get my real figure off Fuelly, and the MFD gives me a good enough estimate as I go.
    The only thing I'd pick up on is 33 PSI for your tires, not sure where you got that from, but that is under inflated, for the front anyway, unless your tire wear pattern shows otherwise. The placarded pressures are 35 PSI front and 33 PSI rear. Most people find that tire wear shows this to be under-inflated and about 37F/35R to 39F/37R to be somewhere in the right region. A lot do run even higher pressures than that chasing better MPG, but I figure that any saving in fuel is lost by premature tire wear. I run 38F/36R and find that gives me an even tire wear pattern. I have found this does also give me a good MPG, but I see that as a side benefit. I have in the past run higher pressures, but found it was giving a wear pattern that indicated over-inflation, so dropped it back Never noticed any significant MPG change in doing that.
    Those are my data points, as always your milage may vary.
    #113 dolj, Sep 9, 2017
    Petrodollar and Data Daedalus like this.
  14. LDPosse
    LDPosse Member
    35
    27
    Hershey, PA
    I’m pulling 48.6 so far on this tank on my 07, I even did a little trailer towing, and about 80 miles were with my hitch mounted utility rack on the back.
    I’m at 192k miles, all original driveline and HV battery, original plugs, non-low rolling resistance tires, and Mobil 1 0w20 oil. Just replaced the original 12v last month.
    08AE1767-C102-415F-B179-4EA2A9352C39.jpeg F9C10D42-8464-49F0-8D22-61405DD8DFF4.jpeg
    jerrymildred, wjtracy and WilDavis like this.
  15. wjtracy
    wjtracy Senior Member
    11,366
    3,608
    Northern VA (NoVA)
    Sweet.
    Hauling chocolate bars up there in Hershey?
    You are livin' on the wild side with that 0W-20
    Can't argue with success.
  16. jerrymildred
    jerrymildred Senior Member
    11,517
    14,149
    Tampa, FL
    My wife just told me today that, so far on this tank (over half way through it), she's showing 52 mpg on her 2007's MFD. Odometer is at 122k + miles. She uses no special techniques and tends to make lots of short drives with several 20-30 mile ones sprinkled in here and there. I just changed the oil from 0-W20 to 5-W30 (Mobile1) about two weeks ago.
    Mendel Leisk and WilDavis like this.
  17. LDPosse
    LDPosse Member
    35
    27
    Hershey, PA
    LOL I’ve hauled more with this Prius than many folks do with their full size pickups. I switched to 0w20 several years ago, after I noticed I was starting to burn a little oil. Surprisingly, it seems to consume less of the thinner oil.
    Since I tow with it frequently, I change the trans fluid every 2 years, and send it off for analysis. So far, so good.
    This is truly the most reliable vehicle I have ever owned.
    jerrymildred likes this.
  18. LDPosse
    LDPosse Member
    35
    27
    Hershey, PA
    Nice to hear there are other folks out here getting great MPG with their older Prii! Does your wife’s car have low rolling resistance tires on it? Have you noticed any difference yet with the change in oil viscosity?
    I have been watching how I drive, there are lots of hills and a few mountains on my daily commute, and I try to gain momentum on the downhills and let that carry me back up the next one.
    The temps here have also been mild, meaning I haven’t needed to run the AC or heat. Once the oppressive heat of summer arrives, I’m sure I will see a drop back into the low 40s.
  19. jerrymildred
    11,517
    14,149
    Tampa, FL
    Yes. Yokohama Avid Ascend with about 25k miles on them. Showing little, if any, wear so far. I keep them at 42/40 or just below that, depending on how long since I last checked the pressure. I haven't seen any change in mpg after the oil change, but I'm withholding judgement till she's run a tank or two through it. Her travel routes are pretty variable. Plus, it's warmer now, so engine warms quicker, but A/C runs more. Probably a pretty even trade.
    We try to do the same on trips to places that have hills. The only hills around here are overpasses. LOL! Well, the Sunshine Skyway Bridge is a pretty big hill, but we practically never need to go that way.
    Right now, it's pretty average for us. Need to run the A/C almost every time we drive, but not very hard. It might actually be hotter where you are in the summer. It's just that here, it's hot longer.
    By the way, we drove through Hershey a few years ago. Boy!! Did it ever smell good! Wish there had been time to stop and play tourist for a while.
    LDPosse and Raytheeagle like this.
  20. srellim234
    srellim234 Senior Member
    1,201
    1,694
    Laughlin, Nevada
    I was fortunate to have been in Hershey on a 5 day business trip during the Christmas season around 1999. Between the sights and the smells I wish it had been at least 10 days. That is really a neat place.
    LDPosse, jerrymildred and Raytheeagle like this.
