Are "public" charging stations faster than 110?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by FirstName LastName, Aug 10, 2020.
  1. FirstName LastName
    FirstName LastName Junior Member
    32
    SoCal
    Hi! Brand new owner of a used 2012!!! Super excited that I already drove 110 miles and I'm still on Full tanks!
    So it takes about 3 hours to charge at home on a 110 outlet.
    Those public charging stations, are they much faster? Looks like my city has lots of them.
    52,819
    yes, congrats!
    assuming they are 240v
    and you can get one for your house. designation: 120v = L1, 240v = L2
  3. FirstName LastName
    32
    SoCal
    Yes, they are 240V. My city has lots.
    52,819
    nice, are they free?
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    Congrats!!! The public chargers you have to pay for get mighty expensive. There's a free one about 3 miles from my house, but I'd probably never use it since it's so close but not as close as the one in my garage. :D
    Having L2 at home can be a big help if you find yourself needing more than one charge a day.
  6. Tideland Prius
    16,678
    Yes, they're typically 240V. It'll cut the time to 1.5 hours.
    However, look for free ones. The PiP has a 2.2kW onboard charger which makes the fees for the station expensive for PiP owners. (Around here, the charging fees are based on you being able to accept the full 6.6kW charge so anything less and it becomes more expensive).
  7. FirstName LastName
    32
    SoCal
    There are a bunch of public ones. Paid for by the city and from the business that are in the area. There are also private ones like inside Work Complexes parking lots. My friend has a newer Prime and charges his while he is at work. Say's likes a buck or 2, or maybe something like that.
  8. FirstName LastName
    32
    SoCal
    Ahhh, I'll remember that next time I go! It's like those drink vouchers at festivals. Here, pay 50 bucks for drinks. Don't matter if you buy 1 or 2 drinks, its 50 bucks!
  9. Tideland Prius
    16,678
    Use plugshare.com (there's also a phone app). It'll let you filter by station type and whether it's free.
  10. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    If it is 2 bucks......and that gives you 40 miles or a bit less.....then you aren't really saving much money.
    Does it not require a different cord to charge at 240 ?
  11. FirstName LastName
    32
    SoCal
    Yah, that's for his prime, so yah, not sure. but I guess, yep, not worth it if it was 40 miles or less, the prime gets 25 miles on 'lectric?
    Does it not require a different cord to charge at 240 ?[/QUOTE]
    No, you pull out the J cord and attach it to your car.
  12. jerrymildred
    11,517
    14,167
    Tampa, FL
    It costs me about 65 cents for a full charge at home, so about 2 cents a mile. No way would I pay $2 to charge the Prime let alone a PiP.
  13. Yea Right
    Yea Right Active Member
    232
    115
    Seattle
    2014 Prius Plug-in
    My work has a few ChargePoint stations with a 1.00 minimum ... I'm usually completely out of charge when I get there, so for a full charge it's usually 1.00 or 1.15 or so.
  14. jerrymildred
    11,517
    14,167
    Tampa, FL
    WOW!! Roughly 8 cents per mile. $1 is four times what it used to cost me to charge my PiP ay home.
  15. Desertdeals69
    Desertdeals69 Junior Member
    44
    23
    Lk Havasu City Az 86403
    I have a 14 plug in and a charger at home. When I first got my charger it plugged in to 120 volt and took 3 hours to full charge. I wired it to 240 volt and it took 1 1/2 hours to full charge.
  16. bisco
    52,819
  17. Yea Right
    232
    115
    Seattle
    2014 Prius Plug-in
    Well ... I'll qualify the location for you. This is Seattle area, high tech, Amazon and Microsoft country.
    The city/location had a median household income last year of a whopping $183,000, putting it at the top of the Census Bureau’s list.
    A bit sobering for most outside this area.
    jerrymildred likes this.
