Are snow tires worth it?
Discussion in 'Gen 2 Prius Main Forum' started by GreenLady, Jan 25, 2008.
  1. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    It got down to -25 F last night. Supposed to be -35 F tonight, with a "high" tomorrow of -20 F
    You folks now know why I have an insulated, attached, and heated garage
    I had to stick the deicing cable into the plumbing vent stack and plug it in, to keep the vent stack from icing over. Too bad these weren't around when the house was built
    Water Line Heat Trace Freeze Protection For Cottage, Home, Commercial Water Pipe Applications - Arctic Vent
    I still can't believe that most new homes around here do NOT use storm doors. A single door will easily ice up in these temps
  2. chimo
    chimo Junior Member
    81
    Ottawa, Canada
    I lived in Winterpeg for 3-1/2 years - I hear you. Are you looking forward to the other season - "construction"? Cheers,
    Paul
  3. jayman
    13,439
    641
    Winnipeg Manitoba
    No, I am not. And I'm still unsure which season is worse!
  4. Tideland Prius
    16,683
    Wow... for once, Winnipeg has nothing on us hahaha
  5. jayman
    13,439
    641
    Winnipeg Manitoba
    We also have you handily beat in crime too
    In this photo of my FJ studded Nokian tires, on the back of my old Ford pickup
    In the upper corner you can see the Reznor gas heater. Which, in these temps, you can pry from my cold dead fingers
