Are the LED headlight bulbs safe
Discussion in 'Gen 3 Prius Main Forum' started by Traindriver88, Sep 30, 2016.
  1. Traindriver88
    Traindriver88 Junior Member
    Augusta Georgia
    Hello everyone I'm new to the forum just bought a 2010 today and would like to get a couple of things for it I saw on eBay where they have Samsung led replacement headlight bulbs and wanted to know if they are safe to use on the car also no ballast just plug and play thanks
  2. kenmce
    kenmce High Voltage Member
    1,509
    493
    NY
    LEDs are very sensitive to variations in current. Over voltage can kill them quickly. Does it come with some kind of LED driver or protective circuitry? What kind of warranty do they have? Are there a lot of conditions in the warranty?
    The existing housing and reflector are tightly designed to the exact kind of bulb that came with the car. Would the new bulb emit light in the exact same spot as the filament of the old bulb? If not, you could get really bad lighting. Test the new bulbs the night you put them in. See if they put light down the road as well as the old ones. Also check if they throw light at oncoming drivers. If they do, you'll have to pull the new bulbs. The parking, running, and fog lights are easy to swap out because they don't need a precise beam shape.
    If there are other cars of your model year that came with LED lights you may be able to swap out your current headlight housings for the other type. By bringing in the entire housing with reflector and bulb you get a factory spec beam and excellent viewing.
    Traindriver88 and Bluegrassman like this.
  3. Bluegrassman
    Bluegrassman Active Member
    229
    184
    US
    Don't the factory LEDs also have auto leveling? Wouldn't this be lacking in a retrofit even if you ordered the factory housings? I'm thinking I read somewhere on here about a leveling switch/sensor in the rear of the car?
    Following this because I'm interested in swapping mine to LEDs as well and I want to do it right.
    #3 Bluegrassman, Oct 1, 2016
    Traindriver88 likes this.
  4. alekska
    alekska Active Member
    435
    138
    Atl
    Any modification of the headlight would be illegal in most states. For a reason. Improper modification, like replacing the incandescent bulb with aftermarket LED, will create improper beam distribution ( and brightness) and likely blind incoming drivers at night.
    Alex
  5. Traindriver88
    Augusta Georgia
    Thanks guys for the responses I'm going to play it safe and stay with the original bulbs
  6. kenmce
    1,509
    493
    NY
    Yes
    Yes.
    Yes. I don't believe it is possible to install a leveling switch on a Prius that didn't come with one. You need to be very particular about getting them level.
    Bluegrassman likes this.
