Are these reputable batteries ???
Discussion in 'Gen 2 Prius Technical Discussion' started by Chris Wolfgram, Nov 30, 2019.
  1. Chris Wolfgram
    Chris Wolfgram Active Member
    425
    169
    Sacramento CA
    2019 Prius
    Gen 3 Prius Battery Replacement WITH NEW CELLS | Greentec Auto
    Seems like a pretty good deal, for 48 month, unlimited mile warranty ? I think that's better than my factory warranty...
    How much would it cost to have it installed ? ... I mean if you knew someone ? My friend / personal mechanic is the best, and my car maintenance savior, but I'm not sure if he would be down with a high voltage job like this.
    52,915
    it's a pretty easy job. he should be willing to do it for a couple hundred bucks.
    you can find video's showing how quickly an experienced mech can do it.
    regarding greentech, you'd be better off with a 'newpriusbattery' from one of our members, 2k1toaster for $1,600.
    regarding a new oem warranty, you may only get one year, but you will get 10 years of troublefree service.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    I'm with @bisco on all points on this one.
  4. Chris Wolfgram
    425
    169
    Sacramento CA
    2019 Prius
    Thank you for that info.
    Only thing though, 10 years of use for a lot of people, might be 2 or 3 years for me. If my 2019 is still on the road in 4 or 5 years, it's going to have 250K+ miles on it.
  5. jerrymildred
    11,517
    14,171
    Tampa, FL
    It seems like the years do more harm than the miles (although both have an impact), so you are probably OK in that regard.
  6. bisco
    52,915
    in that case, i would get the green tech as an experiment, and hope theyre still in business if you need them
  7. dolj
    dolj Senior Member
    8,657
    4,407
    Wellington, New Zealand
    If your 2019 is still on the road in 4 or 5 years time (and why wouldn't it be?), I'd start looking at options then. In the meantime, I wouldn't be wasting my time and energy on a non-problem.
    #7 dolj, Dec 4, 2019
    jerrymildred likes this.
