Are these the correct tools for replacing downstream o2 sensor?!
Discussion in 'Gen 2 Prius Technical Discussion' started by Dang Pham, Apr 6, 2022.
  1. Dang Pham
    Dang Pham New Member
    Lynnwood, WA
    has anyone tried this before?!
    i've had never own a car until recently so i dont have any tools, but planning to replace the downstream o2 sensor
    looks like the previous owner overtighten it so the adjustable wrench doesnt work, im planning to borrow from autozone. Would the one in the pics are the only tools I need?!
    #1 Dang Pham, Apr 6, 2022
  2. alftoy
    alftoy Senior Member
    1,132
    520
    Saskatchewan, Canada
    ask autozone for the correct downstream sensor and they will loan you the correct tools.
  3. mr_guy_mann
    mr_guy_mann Senior Member
    4,120
    2,018
    NJ-USA
    If you're replacing the sensor then just cut the wires off and use a box end wrench or a deep socket- 22mm or 7/8" . Get a (genuine) Denso replacement sensor. Put a little of the supplied anti-seize compound on the threads and don't over tighten it (I think it's something like 25-30 ft/lbs).
    jerrymildred likes this.
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    I just use a 22mm wrench and the anti-seize that comes with the sensor.
