Are these the parts I need for an oil filter housing conversion?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by leftovercrack, Nov 10, 2022.
  1. leftovercrack
    leftovercrack Junior Member
    25
    United States
    Hi all, I had a terrible time changing my oil last time. You guys aren't going to believe this, but the technicians at the dealership overtightened my oil filter cap. Unbelievable, right? Taking it to the dealership was a one-off because I was in a rush, I'll be changing my oil myself from now on. However, I want to convert to a spin-on oil filter. From a previous thread I gathered that these are the parts:
    Prius Gen3 Oil Filter Conversion
    • Oil Filter Bracket (15609-0T060)
    • Union (90904-04006)
    • O-Ring x2 (96723-24020)
    • Flange Bolt x4 (91551-F0835)
    • Oil Filter (90915-YZZF2)
    I have a 2011 Prius Two. Is this EVERYTHING I need for the housing conversion itself? Do I literally just take the 4 bolts off, replace the o-rings, put the new one on and that's it? Thanks y'all.
  2. Tombukt2
    Tombukt2 Senior Member
    12,841
    2,307
    Durham NC
    Basically that's correct You're changing an aluminum jig which is the fixture that converts you from the plastic housing with the filter cartridge inside of it to a spin on filter very simple I don't know if all those parts are right I didn't look them up but that's basically the deal so there's two o-rings and a metal or aluminum jig and you can probably reuse the bolts you take out of your original once I have the little stupid oil filter wrench and whatnot and seems silly to mean how to change over to the cartridge spin on what have you then I won't have anything to do with the oil filter wrench and these Toyota little filter inserts I can get those things for near nothing the three or four dollars for a fram spin on
  3. Grit
    Grit Senior Member
    6,573
    4,225
    Wilkes Land
    I don’t believe that one bit.
  4. Paul E. Highway
    Paul E. Highway Active Member
    206
    129
    Hawaii
  5. Mendel Leisk
    41,164
    • you don’t need the “flange bolt”; they’re same as existing, which are reusable.
    • Oil filter you can pick up any time, at any dealership. Just say it’s for 2018 Prius.
    • The O-rings are same as existing, likely existing ok, but so cheap, I’d replace.
    • That oil filter bracket is what Amayama had, one of several spin-on style, and as far as I know they’d all work. It’s the one I got,
    • simplest/cheapest and what I did: shop Amayama, enter your vehicle as a 2018 model year Prius (has spin-on style), go to engine section, pick your parts.
    • Paul E Highway’s linked my shopping list.
    • See also spin-on link in my signature.
    • (Don’t know how to escape bullet points lol)
    Montgomery likes this.
  6. leftovercrack
    25
    United States
    Do you have any suggestions for where I can buy the parts online? I HATE HATE HATE dealing with my dealerships. I tried ordering online and set my shipping address to my parents house since I live in an apartment. I get an email 2 days later that my order was cancelled because of the mismatched billing/shipping addresses. TWO DAYS. and on a friday. Absolutely ridiculous.
  7. Mendel Leisk
    41,164
    I used Amayama. Not being in the States, the US online retailers typically won't ship to me. Amayama was cheaper by far too. A little slow; I just got a small shipment recently, and it took maybe 2 weeks. But very reliable. No import duties or sales tax levied either, just the shipping charge. They ship from either Japan or United Arab Emirates. Try to use only one or the other, to avoid two shipping charges.
    Paul E. Highway likes this.
  8. rjparker
    rjparker Tu Humilde Sirviente
    10,004
    6,188
    Texas Hill Country
    Seems ADM (Car Care Nut) is not an advocate of aftermarket oil filters, metal canisters or spin on filter conversions. Besides the obvious issues, his concern seems to focus on modified or non standard bypass valves.
  9. leftovercrack
    25
    United States
    As much as I like his videos his smugness always gets under my skin. Anyway, he doesn't really address the conversion being attempted here. There is nothing aftermarket being used here, it's just a different housing for the oil filter. But as he mentioned, I'm not 100% sure the canister will bypass at the same pressures. Is there any way to confirm that the conversion will bypass at the same pressure?
  10. Mendel Leisk
    41,164
    Maybe use the gen 4 parts, say from 2018 or newer. There’s 4~5 part nos for the main bit, fwiw. AFAIK it’s just passages, and interface with the filter, the pressure is by the engine. When getting parts at dealership I ask for oil filter for 2018, and explain what I’ve done.
  11. leftovercrack
    25
    United States
    Are the oil filter bypass valve specs known for both sets of filters? The convenience of a spin-on oil filter isn't worth the risk of using an oil filter that is out of spec, for me. As AMD said the oil system is a crucial system that isn't worth taking risks on. If the specs are basically the same I'll definitely go with the conversion, but I'm not sure if anyone knows the specs. I can't find them anywhere.
    Found this good write up on toyotanation:
    OIL FILTER BYPASS VALVE
    Oil filter bypass valves come in various pressure specs, depending on the manufacturer and the filter media restriction. Some pressure specs you may find, include 8 psi, 16 psi, and 22 psi. But, here is where many people get confused, because they don’t understand what these pressure specs mean. Some people think the bypass valves open at those pressures due to the pressure generated by the engine’s oil pump. And since engine oil pressure is far higher than those pressure settings, they think the bypass valves are always open, but they are not sure. So, let me clear up all that confusion.
    Those bypass valve pressure specs refer to oil pressure “differences, also called delta or pressure drop” between the OUTSIDE of the filter media where engine’s oil pump pressure is pushing on it, and the INSIDE of the filter media AFTER the oil has passed through it. Oil filter media by definition will always create some restriction, and therefore some oil pressure drop. This pressure drop is the actual oil pressure that the engine itself see’s AFTER the oil filter (so, oil pressure gauges must be plumbed in AFTER the oil filter). The less restrictive the filter media, the less pressure drop you will see, and the more restrictive the filter media, the more pressure drop you will see. When there is a pressure difference equal to or greater than the bypass valve pressure spec, the valve will open.
    Here’s an example:
    Let’s say we have an oil filter with a 10 psi bypass valve spec. And say our engine’s oil pump relief valve allows the oil pump to produce no more than 65 psi, with hot or cold oil. With cold oil, the oil pressure can easily reach 65 psi even at lower rpm, while hot oil will take more rpm to reach 65 psi. So, we fire up a stone cold engine with cold thick oil, and the outside of the filter element see’s that 65 psi. But, because cold thick oil has a much harder time passing through the oil filter element, there would be a pressure drop from the outside of the filter element, to the inside of the filter element, of MORE than 10 psi, so when the pressure drop reaches 10 psi, the bypass valve opens and your engine is getting unfiltered oil.
    So, as you can see, the oil filter bypass valve opens semi-regularly during cold start-up and during warm-up, if the engine is run too hard before the oil is up to normal operating temperature. The fact is, the filter media is highly restrictive to sufficient oil flow, when the oil is cold and thick, if the engine is run too hard during that time. So, oil filter bypass valves are designed to open under cold oil and/or aggressive cold oil driving conditions, in order to prevent oil starvation to the engine. Once the oil warms up and thins out, the bypass valve will typically not be open because the pressure drop will be less than the bypass valve’s spec. To minimize the amount of unfiltered oil going through your engine, you should always run an engine easy until it gets up to normal operating temperature.
    It is a total MYTH that the bypass valve only opens if the filter media is totally clogged up with debris. If the filter was totally clogged with debris, an open bypass valve would be the least of your worries, because that would mean your engine has been badly damaged or destroyed, unless you had not changed the oil filter for countless years and it had an enormous number of miles on it. If an oil filter is changed at any kind of reasonable interval, it will never get clogged with debris unless the engine is badly damaged.
    douglasjre likes this.
  12. leftovercrack
    25
    United States
    So I found that for engines that use the 90915-YZZF2 are specced for 8-11psi bypass valve, according to Wix. Is there any way we can find out the bypass valve psi for engines that use the original oil filter?
  13. rjparker
    10,004
    6,188
    Texas Hill Country
    I am sure a test rig could be setup to measure the bypass valves. I lean to leaving it factory.
    Two observations. First, for a new channel, AMD is doing quite well with almost 500,000 subscribers. This video alone has over 100,000 views in two days so he's getting something right. I think it's primarily the expertise he has and his ability to demonstrate it on video.
    Second, he's a Toyota master tech that goes by the book in most cases. He does back up his opinions with training and experience when a focus on getting it right the first time. That's good enough for me.
    #13 rjparker, Nov 17, 2022
  14. leftovercrack
    25
    United States
    Not sure why you keep calling him ADM, it's AMD. Second I never questioned his expertise, I said he's smug. He always frames things as if to say "Yeah you probably didn't think of that, huh". Especially in that video, his attitude is just irritating. Third, as I said previously, he doesn't address this conversion in his video. This is using all OEM parts. As I just found out, if you look at the 2018 Prius oil filters, some models have the same oil filter as my 2011 and some have the oil filter I'm converting to. That would indicate that the two systems are specced to be reasonably close, so much so that they're interchangeable on the same engine. Still hoping someone can give more concrete confirmation on that, though.
    Foxglove likes this.
  15. Mendel Leisk
    41,164
    The bypass is in the spin-on filter? I’m using stock 4th gen filter.
    as are quite a few other 3rd gen owners here; doesn’t seem to be any issues.
  16. Tombukt2
    12,841
    2,307
    Durham NC
    Yeah I was going to say the bypass valves are in the filters whatever pick your poison fram K&n whatever we've been through all this probably more times than needed I don't think there's an alternative bypass in that in the factory oil filter housing there used to be earlier not in this vehicle but on others where that spin on filter block bolted up to the engine and had a big bolt on it with a spring and a metal ball. But all that's gone now and I think everything is built into the filter so if you're running a Toyota filter and you're running the stock bypass valve rating I guess would oil filter manufacturers just randomly change that? I would think they would want to stick close to what the factory recommended or maybe for a certain type of media a certain type of bypass valve pressure is recommended.?
  17. leftovercrack
    25
    United States
    Yes I understand the bypass is in the oil filter. However different oil filters are made for different bypass pressures. If an oil filter system is designed to idle at 20psi and you install a 10psi oil filter, you will always be bypassing the oil filter. Unfortunately I can't find the bypass specs for the 3rd gen engine. But looking at Toyotas history and the filter interchangeability on 2018 4th gen, I think it's safe to say it won't cause any issues. I would love to hear someone chime in with solid facts, though.
  18. leftovercrack
    25
    United States
    I understand what you're saying. I know the bypass valve is in the filter, the issue is that different filters are set to bypass at different pressures. It's important to go for a filter that bypasses at the same pressure. As stated previously I think it's safe, but still no hard confirmation. I finally ordered the parts, however.
  19. Mendel Leisk
    41,164
    IIRC 4th and 2nd gen Prius use the same spin-on filter. And it’s used in Corolla too. Part number:
    90915-YZZN1
    #19 Mendel Leisk, Nov 17, 2022
    leftovercrack and Montgomery like this.
  20. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    The oil pressure “seen by the engine” is the difference between the pressure outside the filter and the pressure drop, not the pressure drop itself. The filter media is the one experiencing the pressure drop. (This is why there is always some sort of metal screen on the inside of the filter, to prevent it from collapsing as the pressure inside is less than outside creating a vacuum effect on the media). The spring guarantees that the engine sees 20 PSI pressure or above at a setting of 20 PSI. The valve opens at 20 PSI so the engine sees full pressure. When the engine is idling (low pressure) the oil is being filtered. When the engine is running hard it is not being filtered.
    The question is how much of a difference from stock should we worry about with this understanding….
    iPhone ?
    leftovercrack likes this.
