Are we really discharging to 6 or 3 volts?
Discussion in 'Gen 2 Prius Main Forum' started by Prius92, Jul 29, 2022.
  1. Prius92
    Prius92 Member
    376
    95
    Iowa
    I am trying to understand the interaction that occurs to further my understanding of rebuilding these modules.
    If you set a hobby charger or discharger to discharge to 6 volts, it will stop applying a current load as soon as it senses the voltage with the load applied hits 6 volts.
    However, once you remove this load, the voltage will creep back up, usually to around 7+ volts when discharged to 6.
    On the other hand, if you could program a discharger to discharge to 6 volts, and then releasing the current load, and continuously reapplying it until it reaches 6 volts and stays there, would this be entirely different?
    Technically speaking, if we discharge to 6 volts and remove the current load, and it "floats back up" to 7+ volts, are we really "discharging to 6 volts"?
    Also, what exactly causes the voltage to spike back up once the load is removed?
    PriusCamper likes this.
  2. PriusCamper
    PriusCamper Senior Member
    11,109
    4,521
    Pacific Northwest, USA
    There's a chapter in a $3K book that explains NiMH in great detail... It's been mentioned on here by Mr. Lol (aka: @tracy ing ). I think that chapter is what we need to see to figure this out. Specifically the footnotes so we can actually get started on a literature review of paper's published. Until then I'll submit that with high quality equipment you don't have to go below 6v, but without it, you do.
