are you all sure I could use regular gas
Discussion in 'Gen 2 Prius Technical Discussion' started by little foot, Sep 8, 2008.
  1. jcfsusmc
    jcfsusmc New Member
    Lynchburg, Virginia
    Just for further encouragement...
    I always have to test things for myself. Stick with 87!
    Using SPSS for the statistics, I've come up with the following:
    87 octane for six tanks: 53.6 mpg
    89 octane for six tanks: 52.13 mpg
    93 octanne for six tanks: 51.1 mpg
    last four tank of gas; going back to 87 for good: 54.8 mpg!
    All octane "tests" were performed using consecutive tankfulls, no additives. Oil changed, tires rotated during second tank of 89. Tire pressure: 42 front; 40 rear. 650-700 miles a week over hilly rural roads. Average speed: 45-55 mph. 20% city driving.
    Chris
    Meg&Bear likes this.
  2. HardCase
    HardCase SilverPineMica, the green one
    408
    Kalispell, Montana
    I live in western Montana, but go to the eastern part of the state fairly frequently. Over there most 'regular' gas is 85.5 octane. I use it in my Prius with no ill effects whatsoever.
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    Just as a side note, 85 octane is considered regular at high altitudes. An engine needs less octane at higher altitudes, due to thinner air (assuming normal aspiration).
    Tom
  4. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Well, the owner's manual does not say use 87 pump octane gasoline only, it says use a minimum of 87, but don't worry at all, 87 should be just fine in your car.
    Higher octane gas is not necessarily better, it just means that it burns a bit slower which is required the higher the compression an engine has.
