Are you surprised my stock 12V battery is still working ?
Discussion in 'Gen 4 Prius Main Forum' started by Chris Wolfgram, Oct 21, 2021.
  1. Salamander_King
    Salamander_King Senior Member
    11,019
    8,954
    New England
    Thanks. That's a great tip. I must give it a try next time. Yeah, for now, I have no problem with ~30lb Prius 15" wheel and tire, but with 21" Pathfinder tires and wheel, the job is tough. I don't know how heavy it is, but trying to align the holes while holding the wheel in the air is not easy.
  2. robsnyder20
    robsnyder20 Active Member
    378
    302
    SW Florida USA
    The most I ever saw my amperage draw according to my Scangauge is like 9A with the AC on Max FYI. Its a custom setting that someone gave me here on Prius Chat for the Scangauge II. The AC varies since it is an inverter from like 1A-5A normally
    Mambo Dave likes this.
  3. Chris Wolfgram
    Chris Wolfgram Active Member
    422
    169
    Sacramento CA
    2019 Prius
    Yea, that's really low ! I'm sure its one of the most efficient systems out there. I bet my 08" F150 uses 5 X's as much :) lol
    ....but for this discussion, my 2019 Prius LE might also use 5 X's as much > all because of my stereo amplifier, which again, is fused for 100 amps, so Id have to guess I'm pulling 30-40 amps just for it, on a regular, sometimes constant basis ? :( Hmmm...
  4. kc5dlo
    kc5dlo Active Member
    266
    163
    DFW TX
    2021 Prius
    If i was concerned about possibly losing $1500 if the 12 v battery were to fail, I would INVEST in a small booster pack that would fit in the glove box or stashed somewhere else. I have a small one that also has a tire inflator and a light. I have not used the light or the inflator but have started our Suburban several times with it.
  5. privilege
    privilege Active Member
    659
    169
    Birmingham
    it takes about thirty minutes to replace a 12v battery. how would you loose an entire weekends worth of fares from thirty minutes of downtime ?
    if you're concerned about it dying, carry a jump pack
