Arecibo
Discussion in 'Fred's House of Pancakes' started by tochatihu, Nov 9, 2020.
  1. Rmay635703
    Rmay635703 Senior Member
    2,688
    1,725
    Somewhere in Wisconsin
    2013 Chevy Volt
  2. ETC(SS)
    7,511
    If you always do what you always did.......
  3. ChapmanF
    18,964
    I hadn't realized that it got original construction funding from DoD in connection with ballistic missile defense.
    If that source of money isn't there for a rebuild, I duná Žno, might need a bake sale.
    I guess we got along for quite a while with just one 300 meter dish for a planet. Now there's a 500 meter dish. Maybe that's enough?
    Next one on moon? Nice craters there.
    No atmosphere. How often does stuff hit the moon these days?
  4. tochatihu
    tochatihu Senior Member
    9,954
    3,845
    Kunming Yunnan China
    2001 Prius
    I'm sure the issue of salt corrosion is being investigated on cables and fittings. Personal experience with salt on the island, and sticking something up high is a great way to collect more.
    In any case, it could be built stronger if that path were chosen.
    jerrymildred likes this.
  5. ETC(SS)
    7,511
    Less often than stuff hits the earth, if one presumes that the atmosphere is a part of the "earth." ;)
    The atmosphere DOES kinda take care of the small bits though. :D
    The Moon would be a WAAAY better place to put the observatory, except for the "getting all of the stuff up there" part.....
    Holes would be super easy to patch, and there are fewer hurricanes.....
    Salt isn't as big a problem either.
  6. tochatihu
    9,954
    3,845
    2001 Prius
  7. ETC(SS)
    7,511
    Bob Heinlein was right......
  8. tochatihu
    9,954
    3,845
    2001 Prius
    Harsh.
    Dusty too - in a bad way.
  9. ChapmanF
    18,964
    Had not seen this before.
  10. fuzzy1
    10,687
    Little holes (depending on shortest wavelength being observed) don't need to be patched. Significantly larger ones, but taking out only a tiny fraction of the reflector area, may well not be worth patching, if the adjacent reflector surface is not distorted.
  11. tochatihu
    9,954
    3,845
    2001 Prius
  12. fuzzy1
    10,687
    For frequencies 30MHz and lower, which are problematic down here on earth due to our ionosphere, mentioned in the article, and from human-generated "pollution".
    This range does not overlap the spectrum observed by the Arecibo telescope, 300 MHz - 10 GHz, so wouldn't be any sort of replacement for it.
  13. Trollbait
    12,809
    Or lust reuse it in local construction.
  14. Mark57
    2,945
    2,740
    OK
  15. ChapmanF
    18,964
    Link on NSF site:
    Arecibo News Media | National Science Foundation
    Needs script permissions granted to www.nsf.gov, script and frame permissions to players.brightcove.net, and XHR to edge.api.brightcove.com and some akamaihd.net and boltdns.net domains. Then there is even a link to download it. It's a simple 56 MB mp4 video, once you've waded through all that nonsense to get there.
  16. t_newt
    t_newt Active Member
    218
    247
    It is amazing that the drone captured a close up video of the cable right when it decided to snap. Then the drone operator was smart enough to pan over to capture the platform collapsing. I wonder if the cable was making a groaning 'I'm about to break' noise beforehand.
  17. fuzzy1
    10,687
    Considering that they were doing hourly inspections by drone, I suspect it was emitting such signs for quite some time.
  18. Mark57
    2,945
    2,740
    OK
    Probably. I read they were seeing indications that the collapse was eminent.
  19. tochatihu
    9,954
    3,845
    2001 Prius
    Space radar as a means to detect and characterize asteroids etc. heading towards earth may be picked up as a task by US Space Force.
    There are several optical telescopes doing this, but they do not see everything.
  20. Rmay635703
    2,688
    1,725
    2013 Chevy Volt
    If they were expecting this outcome they should have run in the big cranes and cable runners
    my guess is running new cable would have been cheaper than reconstruction
    they could have supported the middle platform via crane then relieved tension on the old cabling and reloomed at their leasure
    things like this are done relatively often in non-remote areas, gotta wonder...
