Argh!! The wife scratched my Prius!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ttabbal, Mar 21, 2006.
  1. ttabbal
    ttabbal New Member
    She was getting into our other car and the door edge scratched my beloved Prius! The result is two small scratches on my passenger side rear door. It appears to have only damaged the clearcoat as they are white looking and I can see the paint color under the damage. They are small but quite noticable scratches I want to clean up prior to my Ziano polish I was planning to get done soon. They are worse than the normal swirl marks and key scratches I'm familiar with.
    Any hints on fixing this would be appreaciated. I've never had a car I wanted to keep nice so much so I just let the little things go before, but I want to get this fixed up as well as possible.
  2. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    Bring her flowers and chocolate and you might be forgiven for parking it where she could scratch it. :rolleyes:
  3. galaxee
    galaxee mostly benevolent
    9,810
    468
    MD
    well... the first damage is over. that's the most traumatic one, i promise.
    i don't know much about paint detailing... maybe PriusEnvy will stop by... he's the detail guru around here.
    however, may i suggest getting those little rubberlike door edge liners (cheap at advance auto parts and the like) for your cars so that it won't happen again.
  4. Rick Grahn
    Rick Grahn New Member
    285
    Illinois
    Ain't that the truth!!!!
  5. bgdrewsif
    bgdrewsif New Member
    497
    Phoenix, Arizona (formerly Bowling Green, Ohio)
    I cannot remember the name of the product but there is a scratch remover gel/wax that you just buff into a scratch and it disappears... I have used it before on my parents car and it really does work as advertised... small scrates on clearcoat will just disappear... huge gouges are another issue though...
  6. RBW111
    RBW111 New Member
    139
    El Dorado, AR
    If you are going to use Zaino then try ZPC. It works great and will leave the surface ready for Z2. Do you have a PC? You may need one for a scratch like that.
  7. ttabbal
    ttabbal New Member
    PC? I don't recognize that acronym, unless you're talking about a computer. :)
  8. Tideland Prius
    16,445
    Meguire's ScratchX?
  9. RBW111
    RBW111 New Member
    139
    El Dorado, AR
    Sorry, been chatting on the Detailing Forum too much. PC=Porter Cable Random Orbital Buffer. Using one of these and some ZPC gives great results. Con you feel the scratch or is it just on the surface?
  10. ttabbal
    ttabbal New Member
    <div class='quotetop'>QUOTE(RBW111 @ Mar 27 2006, 02:59 PM) [snapback]231058[/snapback]</div>
    Ohhh.. okay. I've seen that buffer mentioned before. It's a small scratch that I can just barely feel if I'm really trying to feel it. I'll try ZPC by hand and save the buffer for a last resort, or just ask a detail shop to do it. Thanks for the info!
