Argonne nuts on diesel?
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by bwilson4web, Aug 24, 2010.
  1. seftonm
    seftonm Member
    408
    78
    Winnipeg, MB
    For clarification, CERT is what was measured, STD is the limit for the particular emissions bin that the car falls into.
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    I thought STD emissions usually consisted of some sort of drip or discharge, often accompanied by a burning sensation.
    Tom
  3. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Tom - oh you just HAD to bring up my Evil Ex Girlfriend again, didn't you? The proper meds cleared that right up
  4. Ricklin11
    Ricklin11 Junior Member
    65
    N. Oregon Coast
    I face an interesting conundrum with my commercial fishing vessel. We run a 30 KW genset and the main propulsion engine (both diesel) when we are fishing the genset uses about as much fuel as the main.
    I'd like to use the main to drive a larger genset and have a 120 HP electric motor for my main propulsion. We must have AC voltage for lights. pumps, etc, etc. While fishing the main is just loafing at 3-5 knots. When running the load changes, no hydraullics, just lights and incidentals for the 110v power. A hybrid system makes a lot of sense, rather like a small scale cruise ship. Given the different loads a hybrid type of system makes a lot of sense.
    The issue today as a businessman is the payback period for the work to convert. I know I can have a much more efficient system, the cost is too high to amortize the payback.
  5. bwilson4web
    16,476
    This shows the pattern:
    1.8L prius < 2.0L diesel < 2.0L gasser
    What doesn't make a lot of sense, yet, are the relative values. If we convert the data into formulas like:
    Prius = A(COd)+B(NOd)+C(NOwd) :: coefficients are ratio of Prius/diesel
    The scale for the Prius is much greater compared to the diesel as comparing the diesel to the gasser. I'll try to work up the numbers later.
  6. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
