As our Prius Car ages?
Discussion in 'Gen 2 Prius Main Forum' started by shaneprius2005, May 23, 2012.
  1. shaneprius2005
    shaneprius2005 New Member
    Williamsport, Pa
    So based on reports here and online how have the traction batteries been holding up in the second generation Prius? Are the replacement of these batteries still low on average? Recently I purchased an 05' Prius, produced in Feb, 05', with 117,000, and it's in great condition, having all the recalls performed as well as all maintenance per the manual. Just wondering if I can get many more years out of the traction battery if it is taken care of? I know this is a tough question to answer but one I think about. Maybe I should be less worried since I live in Pa were the weather never gets really hot. Plus I don't travel many hills. I've read hills, hot temps, and a clogged fan can cause the traction battery to fail. OK I guess I've covered enough info for now LOL. :)
    52,647
    of course, you mostly hear about the failures here. but given the small amount of complaints, and the thousands of gen II's on the road, i would guess you're likely good for another hundred thousand miles.
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,836
    Clearwater, Florida
    I would worry more about the transmission especially if the car has been maintained "per the manual". As far as the manual is concerned you never change the trans fluid. We now know thats just not true.
    And that puts you way way overdue. Since your worrying.
  4. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    You can have the dealer do a battery evaluation. It should cost around $100-$200. It can tell you if the battery is getting unbalanced. When the modules get unbalanced that's the first step to failure. They can be re-balanced but I'm not sure how much more time that would gain (whether they would stay balanced after that).
    While the battery is not cheap, it's not the life ending failure many portray it as. You can get a new one for around $3000. Ask how much an automatic transmission is for any other car.
    Make sure both coolant systems have had the coolant replaced, and have the HSD oil replaced. It's special fluid in both cases, so make sure they use the correct Toyota fluid.
    That and the above test are about all you can do to ensure long life.
  5. shaneprius2005
    Williamsport, Pa
    Transmission fluid has been changed twice. Once around 15,000 miles and again at 60,000. So I probably will have that done again. I'll skip the battery test and just drive the car. It seems many are going 200,00+ on their original batteries so I may be just fine down the road.
  6. eliteconcept
    eliteconcept 700 mile club, top tank mpg 69.5
    449
    186
    Indiana
    2022 Prius Prime
    may i ask how you found out what month your prius was built in? I've been curoius to find that out about our recently aquired 2005
  7. stillageek
    stillageek Junior Member
    52
    Look on the driver side door jamb. My 2004 Prius was made in August 2003...
  8. eliteconcept
    449
    186
    Indiana
    2022 Prius Prime
    Ahh cool thanks. I also found this tidbit if information regarding battery aging
    "As the Prius reached ten years of being available in the U.S. market, in February 2011 [ame="http://en.wikipedia.org/wiki/Consumer_Reports"]Consumer Reports[/ame] decided to look at the lifetime of the Prius battery and the cost to replace it. The magazine tested a 2002 Toyota Prius with over 200,000 miles on it, and compared the results to the nearly identical 2001 Prius with 2,000 miles tested by Consumer Reports 10 years before. The comparison showed little difference in performance when tested for fuel economy and acceleration. Overall [ame="http://en.wikipedia.org/wiki/Fuel_economy_in_automobiles"]fuel economy[/ame] of the 2001 model was 40.6 miles per US gallon (5.79 L/100 km; 48.8 mpg-imp) while the 2002 Prius with high mileage delivered 40.4 miles per US gallon (5.82 L/100 km; 48.5 mpg-imp). The magazine concluded that the effectiveness of the battery has not degraded over the long run"
  9. LIPriusFreak
    LIPriusFreak Can I haz JDM?
    449
    34
    Long Island, NY
    these cars are VERY reliable to well past 500k (as 2fast4u can attest to)...but key for ANY car to go over 200k these days is OEM maintenance.....
  10. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    I would amend "thousands" to "about a million". Remember the badges that went out a year or two ago were for the million+ mark being hit. Most of those are GenII's.
  11. veggieranger
    veggieranger Junior Member
    37
    Peachtree City, GA
    I have a 2004 Toyota Prius with 142,000 miles that has spent its life in the heat of Atlanta, GA. The hybrid battery failed about a week ago. The dealer wanted $3,200.00 for parts and labor to replace it so I drove the car home and ordered a reman battery from Hybrid Battery Depot in Pontiac, MI.
    I have the car stripped down and the old battery out awaiting the arrival of the reman battery. I'm video-taping the full procedure and will post it on Youtube when I'm finished.
    Just wanted to add some more real-world experience up here on Gen 2 battery life.
    -VR
    P.S. - I have a couple of friends who drive Nissan LEAF electric vehicles here in Georgia. I bet they'll be in for a shock in ten years when it's time to replace their battery pack!
    spalmer and penquin230 like this.
