AS temperature control question
Discussion in 'Prius v Technical Discussion' started by RAM v, Jul 31, 2015.
  1. RAM v
    RAM v Junior Member
    72
    St. Paul, MN
    2014 Prius v wagon
    I have a 2014 v three. My question is: When running the AC and I set the temperature knob to a higher setting does the compressor run less or (like the wife's minvan) is the air just heated back up a bit by the car's heater?
  2. fuzzy1
    10,170
    The Prius has a more efficient AC system than prior standard designs. I have understood that it modulates the cooling power without reheating the air.
    The 2010 introduced a new efficiency component that had never before been used in passenger cars:
    New Prius A/C system first car to use ejector technology | PriusChat
    Unfortunately, the article linked from that thread is no longer available.
  3. rjparker
    rjparker Tu Humilde Sirviente
    7,975
    4,716
    Texas Hill Country
    The electric driven AC compressor is variable speed inverter driven so it is not necessary to add heat to control the cooling temperature. It will run at various speeds or shutdown as necessary. As indicated above, this AC system is far more efficient and utilizes a number of ambient temperature, humidity and sun load sensors in it's auto mode. The Prius v AC design is also higher capacity than the standard Prius.
    #3 rjparker, Aug 1, 2015
  4. rdgrimes
    rdgrimes Senior Member
    1,740
    446
    New Mexico, USA
    2018 Prius Prime
    The compressor doesn't run at all unless its needed.
  5. bisco
    49,490
    unless you have defrost on, including floor/windshield vent setting.
  6. RRxing
    RRxing Senior Member
    2,520
    1,791
    NEPA
    fuzzy1 likes this.
  7. RAM v
    RAM v Junior Member
    72
    St. Paul, MN
    2014 Prius v wagon
    Thanks for the replies and info. I guess this is just another reason I really like my Prius.
