Ask your employers to install charge station?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Francos, Apr 11, 2013.
  1. ryogajyc
    ryogajyc Active Member
    985
    165
    Reseda, CA
    I thought about this as well, but there are a few things that might make it less "simple and logical".
    1) Light posts are only on when dark, so it may not be powered if it is controlled at a centralized controller at a separate location. If this is the case, it would require rewiring the lamp power to always be on and adding a local controller, which may be costly.
    2) Light posts don't typically run at 120 volts, so there would need to be a some voltage conversion, which also adds to the cost.
    Andyprius1 likes this.
  2. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
    I asked about that, too, but the light posts run at a really odd voltage. And it's unlikely that the circuit can handle the added 120V, 15A draw.
  3. jfschultz
    jfschultz Active Member
    639
    115
    Germantown, TN
    2020 Prius Prime
    Interestingly, the PlugShare web site has a grey (unavailable) icon in the middle of a parking area for a charging station at work. The was a picture so I had a good idea of where to look. Sure enough, between to EV delivery vehicles was an empty parking space and a L2 charging station. (It is marked as unavailable because the campus is secured, so only employees can get to it.)
    iPad ? HD
    3PriusMike likes this.
  4. hill
    8,807
    not only do light posts generally run at higher voltage - they are typically put on breakers that would not allow for the extra draw. Their wiring isn't sized for the extra draw either.
