Asking for advice on buying and owning a Prius C.
Discussion in 'Prius c Main Forum' started by Isaac Zachary, May 29, 2018.
  1. Isaac Zachary
    Isaac Zachary Senior Member
    1,877
    888
    I originally was interested in a new Prius Prime because of the federal and state discounts (up to $9,500 off). Although I'm still playing with the idea, I've also been thinking about getting a Prius C instead. I'm looking for one with less than 50,000 miles and for around $10,000.
    Any suggestions as to what to look for and what to avoid?
    My own personal circumstances are that I live in the Rocky Mountains in Colorado in one of the coldest towns in the state. I average 60 miles per day, usually in one run. (60 miles there, stay the night, 60 miles back. Something like that.) In such a run I can go up and down some 4,000 to 6,000ft over mountain passes. I'm concerned that perhaps the cold might hurt the traction battery. Temperatures well below 0°F (about -15°C) during the winter are common, with it reaching -40°F (-40°C) on occasion. This morning it was 32°F (0°C), but I can also drive through places as hot as 104°F (40°C) at times. Would any of that be of concern for driving a Prius, especially a Prius C?
    I usually don't have much of a problem with the snow and usually get a set of studded snow tires on a separate set of rims. But on occasion I find I need to use tire chains. Has anyone else used tire chains on a Prius C?
    Basically I'm wanting to replace a 500,000 mile VW Golf diesel that gets 55mpg for me. A Prius seems the best option.
  2. Isaac Zachary
    1,877
    888
    Also I'm trying to figure out how battery degradation might affect me. I've seen quite a few Prius cars for sale with dead batteries. I was wondering if the bitter cold around here might be doing that.
  3. NY[Prius]C
    NY[Prius]C New Member
    Brooklyn
    2015 Prius c
    I found my Prius C in great shape with under 50k miles at Hertz Car Sales. They had a few, and they have a bunch of locations, so that might be worth a look for you.
    Isaac Zachary likes this.
  4. Isaac Zachary
    1,877
    888
  5. bisco
    49,500
    battery degradation is caused by heat, not cold. cold will affect your mpg's as with any car, plus the battery becomes less effective.
    we have many colorado members, and i don't recall many battery complaints. i think i would want to test the c on your route as it is a city car more than a cruiser.
    prime would probably be perfect.
    Isaac Zachary and dubit like this.
  6. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Going downhill rapidly can over charge the HV Battery. Using B mode slows battery charging by adding engine braking, keeping it cooler. Use A/C when you feel hot, you are cooling the battery, too. Park in shade, or use window tint and window shades.
    Colorado Tint Laws - 2017 & 2018 - Car Tinting Laws
    If you do not tint the front side windows, you can go as dark as you wish on the rear sides and back windows. I am not sure if the factory tint qualifies you. I would check locally.
  7. orenji
    orenji Senior Member
    5,884
    3,486
    I owned 2012 PriusC. It was an excellent car, and really enjoyed. But then I sold it and got a Gen3. The Prius classic is so much better of a car. It's bigger, more comfortable and most important more powerful. Living in the mountains you may find it underpowered.
  8. Isaac Zachary
    1,877
    888
    Thanks for all the help from all!
    As far as underpowered goes, I'm coming away from two cars. A 1985 VW non-turbo diesel that litterally has less than 40hp at this altitude and a Nissan Leaf that I have to drive 30mph down a 65mph highway if I want to get it out of town to the next charging station.
  9. Isaac Zachary
    1,877
    888
    It sounds like the Prime would be less likely to overcharge the battery going down hills??
  10. roadrunner
    roadrunner His (blue) and hers (black).
    61
    36
    Perkasie, Pennsylvania
    2015 Prius c
    Hertz no long rents the Prius c from what I see. They currently have 1 used Prius c for sale at this time. We too bought from Hertz our two Prius c's. They have been problem free.
