at 150k miles the egr valve cooler assembly should be cleaned
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by tankyuong, May 30, 2017.
Tags:
  1. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    depends on your driving
  2. mjoo
    mjoo Senior Member
    1,156
    1,328
    Michigan
    The EGR pipe seems to be the canary in the coal mine. My opinion is with "severe duty" (cold starts, short trips, bad fuel, oil burning) I'd expect the recommended cleaning is closer to 70k. For "light duty" (highway miles, high miles/year, no oil burning) expect 120-150k to be the appropriate time.
    The exhaust condenses on to the cooler internals the most when the engine coolant is cold. Also the best remedies I have found for removing carbon out of the engine are distillates that tend to dissolve oil. Examples are brake cleaner, acetone, brake fluid (ether), purple power. This is why I tend to think that oil burning would exacerbate the carbon in the EGR system. Oil seems to attract carbon. This is analogous to flies and fly paper.
    Pixel XL ?
    m.wynn likes this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    I replaced the egr valve and cooler at ~120 k miles. I plan to do a similar replacement at 200 k miles when the engine coolant is due;).
    Since I will be removing the windshield wiper cowling, I will also do the spark plugs to pool jobs together ;).
    I bought a spare egr valve and cooler so I didn't rush the cleaning process. It had come in handy and my original cooler now resides in service in @Rebound 's engine:).
    But to answer your question, every 100 k miles when the engine coolant is done is my plan going forward (y).
  4. Mendel Leisk
    41,474
    I think @NutzAboutBolts 's video agrees with you: he mentions something about not removing one last stud.
    Yes.
    There was some discussion as to when the EGR valve opens/closes, how much, at what rpm, and what speed. Someone monitoring an EGR system value noted significant numbers even at highway speed, albeit lower? I can't really recall what conclusion if any was drawn. Maybe only that how much and when it clogs can vary, and the factors involved are still somewhat up for grabs?
    #64 Mendel Leisk, Jul 22, 2017
  5. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
    Let me know if you'd like some help when the time comes.
    Raytheeagle likes this.
  6. Mendel Leisk
    41,474
    You're starting to sound like a midwife, lol.
    (Except atttending at a birth is probably easier...)
  7. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Probably 2 years from now, given I am at 159 k currently;).
  8. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    There is "labor" involved:whistle:.
    mjoo and Mendel Leisk like this.
  9. Rebound
    3,996
    2,644
    Portland, OR
    Midwives get paid
    Mendel Leisk and Raytheeagle like this.
  10. AzWxGuy
    AzWxGuy Weather Guy
    1,055
    538
    Tucson, AZ
    2021 Prius
    And they provide a valuable service.
    Raytheeagle and Mendel Leisk like this.
  11. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    "Birthing the EGR" has a certain ring to it . . .
    mjoo and Raytheeagle like this.
  12. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Just hopefully less crying;).
    m.wynn and mjoo like this.
  13. Luckykat32
    Luckykat32 Junior Member
    22
    So Cal
    Where did you find the 20g wire to get into the egr cooler fins?
    I have 226k & ive never cleaned the cooler, but have it out now & I'm just trying to figure out if i should buy a new one or keep soaking & cleaning (I've already let it soak 3 different times over night & every time I spray water in there I'm still seeing a little bit of black come out the other end).
    I heard that I should be able to see light through the cooler...I cant
    mjoo and amos like this.
  14. danlatu
    danlatu Senior Member
    533
    1,363
    maryland
    20 awg solid copper wire came from some old lighting ballast's I had laying around. I tried soaking and power washing, the egr was completely blocked and would not work. Poking the egr cooler without spinning would bind the copper. With the copper on the drill slowly spin and push, carbon will come right out. It works similar to a plumbers snake when cleaning out a clogged drain.
  15. FrankB
    FrankB Member
    117
    53
    Cleaned the EGR circuit on my 2010 with 97k this past weekend. It burns a small amount of oil but less than a quart per 5k that I do the oil changes on.
    The cooler was not plugged but it was full of soot such that you could not see much through it but some light was visible. I used oven cleaner for the cooler and brake cleaner for the pipe and valve and oxi-clean for the intake manifold. Everything is spotless now, well except for the intake manifold.
    @NutzAboutBolts videos were invaluable.
    amos, JC91006, mjoo and 1 other person like this.
  16. JC91006
    16,769
    8,567
    How long did it take you
  17. FrankB
    FrankB Member
    117
    53
    Started around 9AM, finished around 4PM but I took an hour for lunch and probably another hour of soaking the intake manifold.
    amos, Raytheeagle and JC91006 like this.
  18. mjoo
    mjoo Senior Member
    1,156
    1,328
    Michigan
    Last year when I did the EGR cleaning, I found some copper 20 awg wires at the hardware store. I believe it was doorbell wire. Most of the insulation was stripped but I left some on for my cordless drill to grip better.
  19. tvpierce
    tvpierce Senior Member
    951
    883
    Maine
    2013 Prius v wagon
    The center wire of coax for cable/satellite TV cable. I don't know if it's precisely 20g... but it worked perfectly for me.
  20. Mendel Leisk
    41,474
    That's what I used too, but once I got into oxi-cleaning (@mjoo tip btw), I think the wire mostly became redundant.
    mjoo likes this.
