ATF fluid changes ARE Required.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Bill Norton, Dec 15, 2012.
  1. bwilson4web
    16,531
    I bought a spare plug and drilled two holes for the heat shrink covered thermistor. I calibrated it using steam and an ice water bath. Then I ran the leads into the cabin. I have photos on my web page.
  2. bwilson4web
    16,531
    My original goal was to reduce rolling friction by reducing tire flex. Then I found it significantly improved straight line stability.
    First get one, lowest rev/mile tire and mount it on a full size rim. Test the tire on one rear wheel in worst case like speed bumps at higher speeds. If it passes, buy a second and mount both on the front. You may notice the attitude change but if it doesn't cause a problem, you are done.
    You will have to use calibration constant or go GPS for speed and distance.
  3. Bill Norton
    Bill Norton Senior Member
    2,242
    753
    MONW, Ks.
    2019 Prius
    L Eco
    Bob,
    At next tire change I will look into getting the highest aspect ratio tire that will fit.
    Any thoughts on going -1 for width? A 185 instead of 195? But with a slightly bigger OD of the tire?
    What do you mean by "calibration constant"? Can the speedometer be tweaked for accuracy?
    It's ~2 mph fast now with fairly fresh tires.
    I would think your 'open air vent' is letting the transaxle 'breathe' with every change of barometric pressure.
    Just like caves do.
    The humidity level in the transaxle would average out to the average for your region.
    And depending on the condition of the air filter, the transaxle is seeing slight pressure changes with each application of full throttle.
  4. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Bill, the wisdom if the internet says that WS is more hygroscopic (moisture loving) than normal transmission oil. I share your concern even though Bob hasn't seen any adverse results yet.
  5. frodoz737
    frodoz737 Top Wrench
    4,800
    2,560
    33
    Here's a thought.
    Where I bought my car, the parts dept. charges $45.64 for the recommended Toyota oil and filter. For the WS ATF fluid it is $40.40. So doing the work yourself and changing both at the same time, say every 10K miles, that's $86.04 after tax. IF you need fill/drain seals appx $15 more. Still less than what the average Dealer charges just to change the oil/filter for you every 10K miles. And I'll just bet someone here knows where there are better prices.
    hum...;)
  6. bwilson4web
    16,531
    Hi Bill,
    Use the "Rev/mile" as that is the only true metric. The aspect ratio can be misleading.
    There is no adjustment for the speedometer or trip meter. So I simply measure the offset and do the calculation in my head. A spreadsheet works just as well. <GRINS>
    So far, none of my oil sample tests have shown any evidence of water in any measurable amounts. That may change in the future but until then, I'll keep my setup.
    xs650 likes this.
  7. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Thank you for doing that and keeping us informed.
  8. Bill Norton
    2,242
    753
    MONW, Ks.
    2019 Prius
    L Eco
    Thanks Frodoz for getting us back on topic. He made a good point.
    (Why do threads always devolve into talking about the price of eggs, etc.)
    In some of my early posts I asked "What does it takes to make a "sticky" so the casual or first time/only time visitor can get a quick, concise recommendation on an important maintenance item."
    The owner's manual is just wrong on this item.
    The sticky could have an easy to follow outline of the procedures and materials and tools required to do an ATF change, complete with pictures.
    Many (most?) owners would not dare do this job themselves.
    And some of the Dealers sound crazy! From refusing to do the fluid change, to even not selling you the fluid...
    With a printable procedure any independent shop, and dare I say a "Jeffy Quik" place, could do it for a decent price.
    What does it take to escalate a topic to a sticky?
  9. El Dobro
    El Dobro A Member
    7,106
    3,282
    Pretty please? :D
    Fostel likes this.
  10. dvancleve
    dvancleve Junior Member
    45
    Chandler, AZ
    Okay, not sure this is the best place for this but here goes. I have never changed the transaxle fluid, trusting the service manual and assuming "check it" was pretty much meaningless. I just ticked over 100K last night and want to change the fluid soon. Based on reading this, I am thinking it might be a good idea to drain it, refill, run 1K miles or so, drain and refill again. I don't really want to drain anything "good" after 1K miles and I am now completely out of any warranty. It seems to me that it is a reasonable "risk" to run Supertech Dexron VI for that short period of time, then drain and replace with either Toyota WS or Redline. Since I don't see doing particularly frequent changes, it seems to me like Redline D-6 probably holds up better but I am not sure which I would use. Thanks, Doug
  11. Bill Norton
    2,242
    753
    MONW, Ks.
    2019 Prius
    L Eco
    Doesn't a Moderator have to sign off on some draft of the sticky?
    We don't have a draft yet, but, Moderator,,,, Pretty Please?
    Not for me... for the poor under-maintained transaxles....
  12. Bill Norton
    2,242
    753
    MONW, Ks.
    2019 Prius
    L Eco
    Doug,
    If your technically curious and want to add to the knowledge base, you could spend another $15 down at the local
    Caterpillar shop and get a prepaid oil analysis kit.
    But you already know that, right?
    All the discussions on what color the old fluid is does not do anything technical.
    $15 does !!!
  13. dvancleve
    45
    Chandler, AZ
    Thanks Bill, I guess I am not that into it ;)
    In your opinion, nothing horrible will happen running "cheap stuff" for a short time? Seems like a good idea to clean things out and I don't mind wasting my labor but I don't like wasting my moolah.
    Doug
  14. jdenenberg
    jdenenberg EE Professor
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I would not ever put any "cheap" ATF in my Prius as a percentage of it will live on after further drains and refills.
    JeffD
    dogfriend, Merkey and xs650 like this.
  15. Mendel Leisk
    42,343
    I'm not sure about second gen (per your signature), but just assuming the spec'd. transaxle fluid for yours is the same:
    Toyota ATF-WS was $9.32 per liter when I purchased about a year back. If Toyota tells me I need to be using a specific fluid, there's no way I would throw something else in.
    Even for a short duration, I would not want to contaminate the transaxle with something else. Also, I don't see the logic in double change. For one thing, the drain is very complete, not like a regular automatic transmission, that retains maybe 50%.
    My 2 cents, if you want to do a double change, use the kosher stuff both times.
    Merkey likes this.
  16. Bill Norton
    2,242
    753
    MONW, Ks.
    2019 Prius
    L Eco
    Doug,
    I like your plan. If this gearbox can handle the abuse of going 100k + on the original fluid it can handle any ATF you choose to use. Did you see the post saying other car makers have this sort of hybrid system tranaxle and each calls for a different fluid? Your gearbox will be so happy to get rid of the crud and have clean fluid!
    Just be ready for the naysayers...
  17. Bill Norton
    2,242
    753
    MONW, Ks.
    2019 Prius
    L Eco
    Did you see my second oil analysis after just 420 miles?
    It was still pretty bad.
    #1 post in this thread.
  18. dvancleve
    45
    Chandler, AZ
    So are you suggesting that more like 500 miles then drain the Supertech? That works too.
    I didn't realize I had landed in a GenIII area until you pointed it out ;) I guess at 7YO and now 100K miles I am not concerned about babying the car. Seems to me that low mileage Supertech Dexron VI is less of a contaminant than original fill Toyota ATF WS with 100K miles on it. Plus, if it is a nearly complete drain like a manual transmission it doesn't seem like contamination is a big issue.
    Thanks, Doug
  19. Former Member 68813
    3,524
    983
    US
    If you go to the page 1 of this thread and look at the OP's UOA, you will see roughly 10% contamination rate. I don't think what you plan to do will be harmful to the tranny, but it's not exactly proper.
    While I replaced mine at 22,000 mile mark and I'm glad I did for a peace of mind, I'm still not entirely convinced one absolutely has to do it very early on. IIRC, Bob posted UOA from factory fluid at 350,000 miles, so long life is possible with old fluid too. Based on my analysis of posted UOA, there is some weak evidence that change at or before 60,000 decreased wear SLIGHTLY as opposed to waiting 100,000 miles.
    So what I'm saying, you are better off doing it every 60,000 miles rather than doing it twice at 100,000 miles.
  20. frodoz737
    4,800
    2,560
    33
    I am going to speak as a Mechanic, not as an Engineer, internet search wizard, couch potato or any other kind of self professed expert.
    To Doug (dvancleve). After 100K miles on the original ATF, do a double drain and fill with the factory recommended fluid. The initial, and again after 500 mile of normal driving. Do not use the "cheap stuff". With that many miles you are just asking for trouble, I don't care what you drive.
    To the other interested parties. Whether you use WS or another known compatible quality ATF, the point is change it and stop talking about how smart you are. Who has the longest xxxx or prettier wife has nothing to do with maintenance, preventative or repair. My educated and experienced advice is to change your Prius ATF when you change your oil/filter. It doesn't take a rocket scientist to know when fluid is past it's prime. Found my last actual receipt for $92.24, which included all needed for this including the washers/seals. $46.44 for the trans, $45.80 for the motor, just in case you missed the point earlier.
    This is needed preventative maintenance people and I dare any qualified Mechanic (Toyota, NASA, Jose or Joe Bob), to say otherwise. Take care of your vehicle, what ever it is, and it will take care of you and yours.
    dogfriend and jdcollins5 like this.
