ATF fluid changes ARE Required.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Bill Norton, Dec 15, 2012.
  1. Bill Norton
    Bill Norton Senior Member
    2,242
    753
    MONW, Ks.
    2019 Prius
    L Eco
    Doug, and guys,
    I don't know if this is factual. Toyota holds the patent but could have an outside source actually manufacture their transaxles, similar to ZF transmissions used in lots of European cars. This quote was in this thread.
    (let's see if I got this quote technique down)(nope, missing the 'who said' part)
    Just to beat a dead horse, and to wait for a response for a sticky request,,,,(Seriously, what does it take?)
    This is just a gearbox, no friction clutches like an automatic. I suspect it will roll down the road just fine with any lube that has the right viscosity range. It has NO filter or even a magnetic drain plug, so it REQUIRES fluid changes if you want a clean particle-free lube in there for long life.
    It's funny how in other threads you still see posts advising to use only Toyota's fluid if you want your transaxle to last. They are faithful to Toyota for the official fluid but not to the official maintenance procedure which is "Don't ever change the fluid".
    Frodoz, I am definitively on board for changing out my engine oil and transaxle fluid every 10k miles, at least until I see oil analysis of the ATF stabilize.
    Doug, I just found this searching on what you meant by 'Super Tech Dextron VI'.
    It's $3.77 a qt Wally ATF and it says this ( my color ):
    Super Tech DEXRON VI Automatic Transmission Fluid, 1 qt:
    • Specially formulated with premium base stocks and advanced additive technology
    • Officially licensed and GM-approved
    • Meets the requirements of General Motors automatic transmissions calling for DEXRON VI fluid
    • Suitable for use where DEXRON II, DEXRON III, JASO M315 (1A), Toyota WS and Toyota T-IV fluids are recommended
    • Protection against wear and transmission shudder
    • Resistant to thickening due to high temperatures
    • Provides friction stability to maintain smooth and consistent shift performance
    Fostel likes this.
  2. Mendel Leisk
    42,343
    Ok. Doug wants to use an alternate fluid, for a few 100 miles, then drain again and refill with Toyota ATF-WS. Is this other fluid even cheaper? And the double drain is needed why?
  3. Bill Norton
    2,242
    753
    MONW, Ks.
    2019 Prius
    L Eco
    See first post here.
    After 420 miles the fluid was still nasty, after changing the original fluid with 112k miles.
    Fostel likes this.
  4. Mendel Leisk
    42,343
    Part of the confabulation might be the absolute silence from Toyota, regarding what to use. At least I've found nothing so far.
    They don't even say the transmission needs a change. I just searched the Repair Manual for the string "atf-ws", with no results. There is a description of the change, but the fluid is only described as "hybrid transaxle fluid".
    Anyone have a Toyota document with mention of ATF-WS? I think there is something, but not sure.
  5. El Dobro
    El Dobro A Member
    7,106
    3,282
    It says WS in the owners manual.
  6. dvancleve
    dvancleve Junior Member
    45
    Chandler, AZ
    Thanks for chiming in. 2 follow up questions, what do you consider to be a "known compatible" fluid, and are you recommending changing the ATF every 5000ish miles?
    Doug
  7. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    From the Owner's Manual:
    Transmission fluid type
    Fluid capacity
    * 3.5 qt. (3.3 L, 2.9 Imp.qt.)
    Fluid type Toyota Genuine ATF WS
    Using transmission fluid other than “Toyota Genuine ATF WS” may cause
    ultimately damage the transmission of your vehicle.
    If this is not documentation enough I do not know what else anyone may need.
  8. Mendel Leisk
    42,343
    Where? I'm not being argumentative; can't even find the word "transaxle" in the owners manual.
    Hang on, will try to find jdcollins5's clip.
    Bingo: page 563.
    My 2 cents: unless you're a mechanical engineer and/or don't mind risking your transaxle or warranty, use the recommended fluid.
    Considering there might not even be a cost saving, it's a bit of a head shaker why you'd want to use anything else.
  9. El Dobro
    El Dobro A Member
    7,106
    3,282
    Look under specifications, near the back.
  10. jdenenberg
    jdenenberg EE Professor
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Doug,
    My recommended interval is a first ATF exchange at 30k miles and then every 60k miles thereafter based on my lab tests of used Type WS fluid at 60k mile intervals. Others have looked at the data and chosen a more conservative 15k mile first exchange and then every 30k miles thereafter, but I judge even that to be overkill.
    Several PCers are choosing to use Redline D4 or D6 instead of Toyota Type WS, but I will reserve judgement on those till I see lab tests and long HSD life (My 2004 Prius HSD is now at 236k miles).
    JeffD
    MikeYoungRealEstate and xs650 like this.
  11. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    In the owners manual as others have said.
    Nice catch on it not being in the Prius Repair Manual. The closest I could come to finding it there was "Hybrid Transaxle Fluid" which says approximately nothing:)
    OTOH, they don't specify engine oil either. Could be because the repair manual covers more than one country and they recommend different oils for different countries depending on that countries regulations and what is generally available in their market. It's not uncommon for repair manuals to defer to owners manual and lube charts for lube specs.
  12. jdcollins5
    5,131
    1,346
    Wilmington, NC
    Here is a Toyota document that I have saved that lists the fluid specifications for all 2010 MY Toyotas.
  13. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Only for those sold in two North American countries.
  14. jdcollins5
    5,131
    1,346
    Wilmington, NC
    Does anyone on here have a similar document for other countries for comparison ?
  15. Bill Norton
    2,242
    753
    MONW, Ks.
    2019 Prius
    L Eco
    Guys,
    The owner's manual does not say to use ATF WS.
    Is says to leave it in there forever. Remember?
    ATF WS is just what Toyota stocks to cover their entire fleet of cars. For simplicity, probably.
    There is nothing unique within the Prius gearbox.
    It's funny how there is so much allegiance for this fluid but NOT for the recommendation to never change it.
    Fostel likes this.
  16. jdcollins5
    5,131
    1,346
    Wilmington, NC
    The Owner's Manual most certainly does specify to use ATF WS and specifically states using anything else can damage the transmission, on page 563 if you want to read it for yourself. You are correct that there is no recommendation to change.
    I do not think anyone in this thread is disagreeing on the need to change, only the correct fluid to use. You are welcome to experiment with your personal car but I for one will only use ATF WS in mine.
  17. Bill Norton
    2,242
    753
    MONW, Ks.
    2019 Prius
    L Eco
    How can you use it if you never change it?
    So, we are all going against Toyota's recommendations by changing the transaxle fluid, correct?
    I'm just poking the hornet's nest.:whistle: Have a good weekend, and continue following only some of the official recommendations.
    Fostel likes this.
  18. Former Member 68813
    3,524
    983
    US
    My guess is Toyota did some kind of study and based on the results, the benefits of early changes were too small to measure or recommend routine changes in most of the cars. Maybe Bob can chime in on this, but I saw results of UOA of factory fluid at 360,000 miles in one of his files. So, that proves that tranny without fluid changes can reach super long life.
    I do admit exceptions are possible. UOA the OP showed did concern me a bit. I see some indications of abnormal wear due to large particle sizes. The particles smaller than 20um are normal and harmless. The "wear particles" we see on the cheap UOAs are under 10um and totally harmless.
    This discussion is not unlike the never ending argument for first engine oil change. Some like it at 1000 miles or below, some are OK waiting 10,000 miles.
    For the record, I did 10,000 mile first engine oil change and 22,000 mile first transaxle fluid change.
  19. frodoz737
    frodoz737 Top Wrench
    4,800
    2,560
    33
    For what it's worth...
    In Doug's situation, it is common industry practice to double drain and fill, minimum, when fluids are known to be contaminated and/or the duty cycle has been exceeded (same thing), to more completely clean the system. I learned using 500 miles between from experience. This is to stop further wear and damage caused by residual contamination and is "usually" adequate. Reset it in other words. For units with removable pans, it is also wise to remove and routinely clean them of the coating/metal/sludge that does accumulate (oil pans too). This is why the "Transmission Flush at Jiffy Lube", where they hook the hoses up, is not recommended on your traditional Ford or Chevy, as it stirs the crud back up into the system, ultimately causing more problems.
    The logic not to use a "cheap fluid", my comment referring to quality and compatibility, should be obvious. Although there is indication some alternative ATFs may be suitable, the point is mute if you just change it using the recommended, BEFORE it is "past it prime". This applies to all of your vehicles fluids, filters, belts, ect... That is what we call.....preventative maintenance.
    I have always changed my oil at 5000 miles with this Prius, and have since included the ATF to this regiment. After what I learned and saw here, then proved to myself, it became a no brainer. Whether you feel this is excessive is of no importance to me, as this is my car. As mentioned before, I pay less to do both than most, who don't turn a wrench, pay to have just the oil/filter changed alone. And it is done correctly. For those that change, or have their oil/filter changed at 10K, I recommend you do the same with the ATF. Take my advice.....or not....but I am qualified.
    By the way, Kudos to the OP on the magnetic drain plug, as they should be used in all such applications and on all vehicles.
    MikeYoungRealEstate likes this.
  20. Former Member 68813
    3,524
    983
    US
    It's one thing to do obsessive over maintenance and then another to recommend it.
