ATF fluid changes ARE Required.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Bill Norton, Dec 15, 2012.
  1. Bill Norton
    Bill Norton Senior Member
    2,234
    748
    MONW, Ks.
    2019 Prius
    L Eco
    Cripes, they also tell you not to change the transaxle fluid. "It's a lifetime fill" . Do you wholeheartedly believe that too?
    I'm just trying to help out my Bros that still drive '90's tech hybrids. If you maintain them they could last a very long time.
    But then, has there been any transaxle failures from never changing the fluid? Maybe not...
    It' true, I did sell my '10 Prius IV w/solarsunroof and bought the highest tech car on the road.
    It's so nice having a great handling 150HP EREV that never burns any gas for 6 weeks at a time. I'm saving thousands a year buy not buying gas.
  2. telmo744
    telmo744 HSD fanatic
    2,181
    769
    Portugal
    I always thought that clutches belong to the early steps of hybrids.
    My bad, Volt has 3 to mock us. :p
  3. Bill Norton
    2,234
    748
    MONW, Ks.
    2019 Prius
    L Eco
    They only engage/disengage at zero torque. This is what it takes to create the next gen of EREV. It has many distinct drive modes. But this is all transparent to the operator. You just step on the Go pedal and feel the power.
    What do you think the next Gen PiP will be like? Or are you just fine with limited acceleration and 62MPH in EV mode? For 3 seasons.
    The Volt is a proper EV,,,, When it's an EV.
  4. Mendel Leisk
    42,285
    No. I've replaced my transaxle fluid twice, with ATF-WS. I've got the sense to cherry pick Toyota's statements:
    1. Never change the fluid? <There's drain and fill bolts, the procedure's outlined in the Repair Manual, I'm gonna dub this one pure showmanship, with callous disregard to the longterm health of the transaxle.
    2. Use Toyota ATF-WS, other fluids may toast the transmission? <Hey, who am I to argue? The Toyota fluid is readily available, and a transaxle failure is something I don't want to tempt.
    #424 Mendel Leisk, Sep 8, 2014
  5. telmo744
    2,181
    769
    Portugal
    Next Gen PiP? The early test version was already good, limited acceleration and 62MPH were more than enough.
    Prius is a proper Hybrid, not a gasguzzler like CS mode Volt.
    You'll have to balance between the good thing and the bad things. Spare us to the 90' years technology giggle breath, like the Otto engine inside the Volt... :rolleyes:
  6. Bill Norton
    2,234
    748
    MONW, Ks.
    2019 Prius
    L Eco
    telmo, you are right, tech is tech. It's in the eye of the beholder.
    What matters is Cost per Mile. And I guess you could consider where your transportation dollars end up, but that's different subject...
    My costs have dropped incredibly with this EREV.
    YMMV, right?
    For instance, I get to top up at work for free. 6-7 Kwh = ~$0.45. Less than the some employee coffee costs !!
    But not everyone has the benefit of working for a high tech employer while driving the highest tech car on the road.
    When I am a gas burner on road trips I get 36-38 mpg going +5mph the speed limit. 85mph in Wy and Ne. Is that a gas guzzler?
    To me that's a fair trade off to burn NO gas for weeks at a time. And it's a proper 4 season EV that's fast and fun to drive. Can't say that about a PiP.
  7. GasperG
    GasperG Senior Member
    1,169
    601
    Slovenia
    2018 Prius
    Cost per Mile? Did you consider calculating TOC?
  8. Matt H
    Matt H Active Member
    164
    105
    Okinawa Japan
    2012 Aqua
    That's an interesting statement: "box of gears and bearings"
    With a high voltage electric motor that creates a lot of heat...
    Dielectric properties of the oil? Is the aftermarket oil is more conductive? Can this cause arcing in the air gap, breakdown of the insulation on the windings, or current to be carried through the bearings, causing premature failure?
    Guess why you have to use a special (different) oil and equipment for hybrid AC systems. As little as 1% contamination from charging the system with a machine used on normal AC systems can cause major problems.
    The other thing the oil has to do in a Prius transaxle is cool the rotor/stator. What are the heat absorption properties of the aftermarket oil compared to OEM? Not just can it handle high heat...but can it move heat?
    Know how everyone talks about WS turning dark pretty quick? Anyone know why it turns dark quicker than conventional ATF? It has to do with the detergents and dispersants in the additive package. You see, conventional detergents and dispersants that do a good job at keeping the oil clean are (drumroll)... more conductive.
    Plenty of info on this in SAE paper 2013-01-0298 "Lubricants for (Hybrid) Electric Transmissions. There's also quite a bit of info concerning this and the above mentioned ability cool the electric/hybrid motor that's bathed in oil in patents:
    • Sagawa, T., Ueno, T., Wada, H., and Aoki, T., 7,307,048 B2.
    • Watts, R. F., and Noles, J. R., US patent 2008/0194442 A1.
    • Smith, P. W. R., WO 2011/113851.
    • Tingler, K. S., Sheth, K. K., O'Bryan, S. R., Yang, J., and Salma, T., 8,076,809 B2.
    • Deskin, S. C., Shah, R., Rosenbaum, J. M., Bertrand, N. J., Lum, D. Y., D'Amico, T., and Schexnaydre, R. J., 2010/0279904 A1.
    • Takei, M, Kanoh, T., Koide, H., and Fujii, K., EP patent 1,662,513 B1.
    • Gong, Q., and Yang, J., WO 2011/147277 A1.
    • Onumata, Y., WO 2012/132,055 A1.
    The one thing that we can take from this is that electrical conductivity and the ability to cool play a part in the formulation of oil used in hybrid-electric transmissions. Oil for these transmissions is specifically formulated to work in the electric motor environment.
    Another thing people bring up is the metal particles in the oil from transmission wear. Metal particles in suspension are far different than metal in solution. Particles in suspension do not create a conductive path, and therefore, do not necessarily make the oil more conductive. The metal additives used in the detergents, dispersants, and lubricants in the additive package are in solution (completely dissolved), and do add to the oil's conductivity.
    People seriously need to get off of this "like" and "trust" rating for oils. The best oil for any given system is one that is certified. Note that "meets or exceeds" is not a certification. For instance GM Dexos, or BMW LL01. One grade of Mobile 1 carries the LL01 cert, another may not. Using oil that isn't certified has torn up lots or mechanical stuff in modern cars.
    #428 Matt H, Sep 8, 2014
    telmo744 likes this.
  9. CreigMac
    CreigMac Junior Member
    Anchorage Alaska
    I've been using Maxlife and Supertech, WS oils in my 2008 Tundra 150K miles, for the past 50K miles. I routinely tow 8000 lbs over the Rockies never had a transmission related issue. If those fluids were subpar the way I use them would reveal any weaknesses. I just used a gal of Maxlife in the Prius and have complete confidence in its protecting the tranny assembly. All WS rated oils are synthetic, if they can protect my Tundra doing right by the Prius should be easy. Toyota didn't even think it needs a filter. If using Toyota oils makes for an easier nights sleep it's well worth the price of admission, I sleep fine using non Toyota WS fluids.
    edthefox5 likes this.
  10. telmo744
    2,181
    769
    Portugal
    From the technical point of view, PiP and Volt share same EV technology, with different sizes. The greater the battery, more power output. But regarding ICE technology, PiP holds a very efficient engine Atkinson Cycle. Volt has a off-shelf Otto.
    There is no chance in naming your car the highest tech car on the road, specially after your first sentence. :rolleyes:
    It is a proper 4 seated EV for some weeks at a time, carrying around a dorment ICE. Very high tech indeed... :whistle:
    See? :p
    #430 telmo744, Sep 9, 2014
  11. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    ^^ You are too kind, Telmo
    I group the Volt in the bin of not very good Prius imitations, despite taking 15 years to copy.
  12. Bill Norton
    2,234
    748
    MONW, Ks.
    2019 Prius
    L Eco
    And yet, the result of this "Leap in Technology" (Lutz) allows a typical Volt to operate at ~70% savings in cost per mile over a Prius.
    Even more if you work for a progressive employer and get to charge at work. YMMV.
    It is NOT the same EV tech. The Volt has 1 or 2 motor EV modes and series or parallel Hybrid modes. Yes, 3 clutches are needed for this tech.
    It seems the PiP came out after garage hackers created PiPs. The transaxle remains the same as the 1999 design, with minor updates (no chain).
    The 40 MPG Highway rated ICE is there for only when it's needed. Very few beat that, besides a Prius?
    The engine comes on briefly every 6 weeks for "maintenance". Some geeks never use the ICE to go anywhere. I'm not that way. I like vacations!
    Shall we talk about safety ratings/crash worthiness? Or Handling and Fun?
    Want to hear about a Volt vs. Prius going up and coming DOWN Pikes Peak? (Interesting story if you like high tech machinery!)
    NO loss of power going up like most ICE cars. NO brake usage coming down!! You must stop and have your brake temp read.
    Can you imagine how anemic a Prius would be during a climb to 14K' ? And what happens on the descent?
    I also had a 2000 1st gen Honda Insight and a '10 Prius IV. I know this chit. Technology moves forward !! All in the name of efficiency !!
    ps. I love carrying around my "dormant ICE" !! It's a 'heavy' load I'm willing to bear.
    pss. What about all the oil analysis done on WS? What exactly is this conductivity spec? Where is it written that WS is synthetic?
  13. telmo744
    2,181
    769
    Portugal
    Modes? Clutches? Same tech involved, but more hardware, please go find a Voltec transaxle draft to check differences...Inverter/MG/Battery are similar.
    1999? Prius was designed in 1996, released in 1997.
    Also you paid for, you'd better be happy with it!
  14. Bill Norton
    2,234
    748
    MONW, Ks.
    2019 Prius
    L Eco
    Similar tech is involved. Planetary gears creating a Power Split between engine and motors and wheels.
    I'm very familiar with MG1/MG2 in the Prius. Very simple. I loved the concept while I owned it. Very limited as an EV. Suits some just fine.
    I'm very familiar with MGA/MGB in the Volt, and the 3 clutches that allow the 4 distinct modes of propulsion.
  15. JC91006
    16,934
    8,644
    Your comment makes me think Toyota factory WS fill may be different than what you buy over the counter....with added additives.
  16. Maarten28
    Maarten28 Active Member
    415
    224
    Netherlands
    Is this the interesting story or is there a link to the story somewhere? Assuming we're talking about a PIP and not a regular Prius (that would be an unfair comparison with the Volt indeed), why would it be anemic? Sure, the concept is different (and IMHO the next-gen Prius should have more emphasis on the E than on the ICE), but when you don't mind the revs, it's quite punchy (admittedly, never driven Pikes Peak).
    And going down? I put mine (regular Prius) on ACC and it brakes electrically automatically. And when the the battery is full, it automatically uses the engine to brake.
    Basically, a Volt and a Prius are two different vehicles. The Volt appears to be better if you can drive electric a lot, but when it has to use the ICE it's worse than a Prius.
    Same difference as a Porsche 911 against a Toyota Landcruiser. Both have their strengths.
  17. Bill Norton
    2,234
    748
    MONW, Ks.
    2019 Prius
    L Eco
    No link, just personal experience.
    The Prius, like any ICE car loses HP with Altitude. And during a big climb like Pikes Peak the Prius/PiP will use up the battery quickly leaving you with a , what?, < 50 HP car. Look up HP reduction at 14k'. Turbo'd engines might maintain rated HP up to a certain altitude then they start losing also.
    If the Volt was driven not in Mountain Mode and it used up the battery reserve, it would be even more anemic than a Prius on gas only.
    I attempted this but failed. I was switching between Normal and Hold modes, but I arrived at the top with 1 bar on the battery level display.
    I wanted to feel a < 45 HP Volt.
    Coming down at the Park Ranger check point my brakes read 75° front/105° rear on a 65° day. The cars in front stunk to high heaven. The Ranger said he has seen hot brakes on Prii.
    I arrived in Manitou Springs with the battery at ~75%. That was hard on the battery, an ultra quick charge.
    And if the battery ever gets full on a big descent like this, (like if you charged it at the top like a fool), the Volt has a 2 motor braking mode.
    MGB will apply braking forces against MGA generating the regen power. This will create heat within the transaxle but the ATF has its dedicated heat exchanger. GM thought of everything! I don't think there is a mode where the engine is brought in for engine braking on big descents.
  18. telmo744
    2,181
    769
    Portugal
    Even at a 3.0% lost in power every 1k' altitude, the nominal 99HP 1.8 Atkinson NA should give 55HP available if only ICE propels the Prius.
    Anyway, since your personal experience is limited to the Volt in this track, I wouldn't declare this as a overhelming limitation of the superior design of the Prius :LOL:
    Regarding the brakes temp, Toyota has thought of that, and protecting the battery against a quick charge...
  19. Bill Norton
    2,234
    748
    MONW, Ks.
    2019 Prius
    L Eco
    umm, I didn't think it was a linear %/feet.
    Either way, I had sea level power at 14k', as an EV, 150 HP !!
    And no brake pad or engine wear on the way down!!
    90's hybrid tech is still pretty good. But technology marches forward.
  20. telmo744
    2,181
    769
    Portugal
    That's more like it. And technology marches "forward"...ops...sideways...carrying an unused seat and a dead weight under bonnet. :D
    Unless instant response of nominal peak power at 14k feet is the new breakthrough test... :X3::sneaky:
