ATF fluid changes ARE Required.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Bill Norton, Dec 15, 2012.
  1. Matt H
    Matt H Active Member
    164
    105
    Okinawa Japan
    2012 Aqua
    I'll just throw this out there.
    I've seen all the oil analysis info, and read a whole bunch of anecdotal information, but the fact of the matter is this:
    With around 30% of the cars on the road in Japan being hybrids, and 50% of the cars on the road being Toyota's, NO ONE changes the HSD transaxle oil... Ever... Lots and lots, and lots of cars with over 300,000km on the clock, and transaxle failure in gen3 and on cars is rare. When it does happen, it's usually an electrical issue.
    If you want to change the oil because it makes you feel better, more power to you. But the hysteria I've seen on this site is ridiculous.
    mmmodem likes this.
  2. Matt H
    164
    105
    Okinawa Japan
    2012 Aqua
    With 180,000 on the factory fill, that's believable. WS is specifically formulated without metals in the dispersants (which is why it turns a "dirty" color quickly). With high mileage, and higher metal content in the oil, leakage current is sure to increase, making the system less efficient.
  3. telmo744
    telmo744 HSD fanatic
    2,181
    769
    Portugal
    I wonder how electrical issues are related to the oil higher metal content.
  4. Bill Norton
    Bill Norton Senior Member
    2,244
    754
    MONW, Ks.
    2019 Prius
    L Eco
    Matt,
    It's a box full of bearings and gears. Can you name any other application where having all that metal debris in the lubricant is acceptable?
    I found in my first oil analysis metal content so high that the light-based particle size/count could not be performed because the lubricant was so dark. The second analysis (performed not many miles later) still had a variety of sizes and counts of metal particles.
    "Electrical current leakage" responsible for decreased efficiency??? Come on...
    Sure a Prius transaxle might make it to 200-300 k miles without ever having the lube changed. (I don't think the one I had could have..)
    But why grind the gears and bearings with dirty lube if you don't have to?
    I have a few bank courier friends that take cars to amazing miles. Preventative maintenance is important if you want to do that.
    (600 k on a Prius Gen2, Two Gen 3's with +300 k miles,{although one had a head gasket failure but is back on the road} and 1 million miles on an Accord wagon.)
    Is there still a law in Japan about a "Max mileage" a car is allowed to have, then it is put to sleep?
    Kind of like here where some people still believe once past a certain 'line in the sand' (100-150 k miles) the car might as well be driven to the salvage yard.
    If you are that sort of car owner, then by all means save yourself ~$50-100 and don't do preventative maintenance and sell that car at your personal 'tap-out' miles.
    But, if you are in it for the long haul do PM and use quality lubricants, not the generic house brands. WS is just another ATF. You can buy WS spec ATF at Wally's for cheap. Or you can buy premium American made synthetic ATF.
    (Does Toyota warn you to "Use only Toyota Brand Windshield Washer Fluid" or you'll damage your washer pump, hoses and the windshield?)
    #544 Bill Norton, Nov 6, 2015
    edthefox5 and frodoz737 like this.
  5. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    So far as I know, Toyota is not using their windshield wiper fluid to cool parts running at 550 VAC. If another vendor certifies their ATF to be as electrically insulating as ATF WS, it would begin to consider alternatives. So far, that has not happened.
  6. Bill Norton
    2,244
    754
    MONW, Ks.
    2019 Prius
    L Eco
    You guys pulled this "insulating" property out of your,,, I don't know. All oil is electrically insulating.
    If there was a conducting ATF it would be the pearlescent crap I drained out of my transaxle at 104 k miles. (disregarding the owner's manual instructions)
    WS is just a spec for a LUBRICANT used in any and all automatic transmissions that Toyota sells.
    They have to have a house brand so their dealers can sell it at a large mark up.
    Wally's has their WS spec ATF for $4.27 / qt. : ( there are probably many other brands of WS spec ATF) { I chose what I thought was best.}
    Super Tech DEXRON VI Automatic Transmission Fluid, 1 qt:
    • Specially formulated with premium base stocks and advanced additive technology
    • Officially licensed and GM-approved
    • Meets the requirements of General Motors automatic transmissions calling for DEXRON VI fluid
    • Suitable for use where DEXRON II, DEXRON III, JASO M315 (1A), Toyota WS and Toyota T-IV fluids are recommended
    • Protection against wear and transmission shudder
    • Resistant to thickening due to high temperatures
    The main issue here is: Brand Loyalty runs deep. That's a good thing, for the corporation. Carry on !
    edthefox5 likes this.
  7. Mendel Leisk
    42,345
    Toyota tells me to use Toyota ATF-WS, and cautions that using anything else could damage the transaxle. I'm ok with that. And when I trade-in the car I'm not handing a potential headache to the next owner.
    #547 Mendel Leisk, Nov 6, 2015
  8. Bill Norton
    2,244
    754
    MONW, Ks.
    2019 Prius
    L Eco
    oops, stupid site....
    #548 Bill Norton, Nov 6, 2015
  9. Mendel Leisk
    42,345
    Yep, remember "I'm outa here"?
    SAronian and Britprius like this.
  10. glenspool
    glenspool New Member
    az
    The important aspect is that the fluid was changed.
    $40.00 plus ( 2 jack stands that I had ).
    When will my next fluid change be 50k from now or less?
    I want to keep this car going for the long haul.
    Yes I brand shop and if this was a standard transmission I would not be too concerned.
    Buy brand name fluid like valvoline whatever at 6-7 bucks a quart.
    Prius only requiring 3.75 quarts who cares? 4 quarts saved $3.00 each?
    Some car owners plan to keep their cars for 100k then trade up.
    Some buy at 180k like me and want to see how far it can go.
    Somewhere in this thread is a discussion about viscosity.
    I am now temporarily a brainwashed consumer believing that
    I can only use toyota ws fluid.
    Here is the big question parts of a penny per mile?
    4 quarts of trans fluid $5.00 per quart from walleye mart = $20.00
    4 quarts of trans fluid $9.99 per quart from toyota = $39.96
    $19.96 saved
    *If my next brainwashed not in the toyota manual fluid change was 50 thousand miles what is the price difference per mile?
    The most incredible thing everyone should be talking about is how well designed this car is.
    180k on a transmission no fluid change is simply exceptional compared to a standard auto transmission.
  11. Matt H
    164
    105
    Okinawa Japan
    2012 Aqua
    The more conductive the fluid becomes, the higher the current leakage. This translates to lost efficiency.
  12. Matt H
    164
    105
    Okinawa Japan
    2012 Aqua
    Depends on what's "acceptable." Who specifies this? I can tell you that a typical automatic is much more sensitive to debris, as it causes sticky solenoids, and spool valves. But Toyota says these transmissions are also a "lifetime" fill... Typical cars in Japan probably run to 200,000-250,000 km at the outside. If a car will run to 300,000+km on the factory fill, and doesn't break due to not changing the oil, is that "acceptable?" I'd say yes to that.
    WS goes dark quickly due to the dispersants they use. Metal-based dispersants keep the oil "cleaner" looking, longer, and are the standard for most transmissions that I know of. Oil for hybrid transaxles purposely don't use metal-based dispersants.
    Plenty of SAE technical papers that address hybrid transaxle oil, and the efficiency gains and losses using different blends that increase/decrease conductivity of the oil. Once again, metal-based dispersants showed high enough losses to keep them from using them, even though they're better. I don't find it a huge leap to assume that increased metal content in the oil, from wear, would add to this. In fact, I'm pretty sure one of the tests I read addressed it, They compared the conductivity of the oil with different dispersants, over time, and all of the oil had decreased insulation, but the non-metallic based dispersant oils fair much better. 'Leakage current" is a very real thing. How about electric motor bathed in a fluid...?
    A generic SAE paper about lubricants in hybrid transaxles, and the effects of conductivity of the fluid can be found here: Lubricants for (Hybrid) Electric Transmissions
    Keeping in mind that I'm not saying not to change the oil. I do it at 100,000km intervals, and recommend to customers to do the same. But that advice is based on no more than a "feeling." I have no evidence to show that not changing the transaxle oil over the course of 300,000+km is going to kill it. Why grind the gears and bearings with dirty lube if you don't have to? Why change the oil if you don't have to? I see them all the time, and my oldest son works for Toyota as a tech in Yokohama. They service taxi fleets with way over 300,000km on them, they don't change the transaxle oil, and they don't see lube-driven failures. So why change the oil if you don't have to? Being honest, if one of my customers is going to keep the car for 10 years, and drive it under 300,000km, evidence shows that changing the oil is wasting their money. Also keep in mind that we don't average the same speeds as the US does. People drive fast on the expressways, but the average speed a hybrid sees over it's life in Japan is much lower than the US. You are bound to have more wear.
    I've never even heard of this.
    WS is not just another ATF. It is made for use in hybrid transaxles. I've seen plenty of Honda transmissions destroyed from people not using OEM specified fluid, but that's a clutch and valve body issue. The Toyota hybrid transaxle only needs lube for the gears and bearings, so you probably won't hurt anything using a fluid that's not OEM certified...but can you be sure? I don't know, and neither does anyone else outside of Toyota. I do know that hybrid transaxle oils are engineered to be less conductive. I will also say that it's strange to want to change the oil based on no evidence of dirty fluid-caused failure (trying to keep the transmission in good shape), but also want to put something other than what the manufacturer says to use, without any knowledge of what they want, or why they want it (possibly doing horrible damage to the transmission). Is there something in WS that helps carry away heat? It's a coolant, after all. What about long term degradation of the motor winding insulation? Is there something in WS to protect against this that's not present in high-dollar, non certified ("meets or exceeds" is not certified) lubes? I don't know, but neither does anyone else. Interesting gamble, though. What if you ruin the transaxle using a non-certified oil? Will they honor the warranty? Plenty of manufacturers now running oil samples on destroyed engines, and not warrantying them. Toyota now has a service bulletin telling techs how to identify a modified battery pack, and won't warranty them if they've been touched. We use OEM oil at mostly OEM intervals, and have no issues. See way more issues from people deviating from what the OEM says to do...like using cheap 5W-30 in a Pruis. Going back to Toyota 0W-20 for a few changes has fixed plenty of oil burners.
    Once again, not saying not to change the oil. It might be good insurance. But without a failure pattern linked to not servicing the transaxle, they hysteria is completely unfounded.
    #552 Matt H, Nov 9, 2015
    CR94 likes this.
  13. telmo744
    2,181
    769
    Portugal
    Stator insulation is supposed to work properly. Can you explain?
  14. eric1234
    eric1234 Active Member
    392
    201
    Hamden, CT
    I'm a fan of the 60k mile transaxle oil change. And, agree wholeheartedly. There could be all kinds of differences between WS and other "compatible" transmission fluids. Odds are probably good that Toyota contracts some major manufactuer (such as Castrol/Mobil/etc...) to manufacture the oil. It could be that they do so under a strict confidentiality and commercial agreement that their formulation not be manufactured for any other purpose/brand.
    Who knows? All I know is that if I'm going to go through the extra effort to crawl around on my garage floor every 60k miles and go through the hassle of changing that stuff - I want to have it be the most likely best fluid for the application. And absent information from a Toyota Engineer charged with the responsibility of lubrication formulation - the most likely best fluid is Toyota's WS...
  15. frodoz737
    frodoz737 Top Wrench
    4,803
    2,560
    33
    WS was not "designed" for Toyota hybrid transaxles...it is also used in them. Additionally...like any "gearbox" or motor lubricant an early fluid change does rid break-in deris and assembly contaminants and regular fluid exchanges extend the service life of said components. That fact that some components are better made than others only reflects on the design of that component, not the need (or lack of) for service. The service life of a fluid is not determined by when a component fails...or is out of warranty.
  16. Mendel Leisk
    42,345
    There's been a few mentions of 60,000 miles as a good interval. I'd qualify that to stress: a much earlier first change seems beneficial, judging from the appearance of the fluid I drained at the one year mark; it was quite dark. Left it a couple of years for the next drain, and that stuff looked almost new.
    I won't mention the km's involved, I might be put away. :whistle:
  17. frodoz737
    4,803
    2,560
    33
    With hindsight I should have done my first at 10,000 miles...and will on my 2015. 30,000 miles is my regular interval...but what do I know? I'm just some lowly Mechanic. ;)
  18. eric1234
    392
    201
    Hamden, CT
    Hi Frodoz, I don't think I ever said it was designed for them. I just said that it is most likely the best fluid for them... This is purely a presumption on my part - but the only entity, (the only people) that have access to both every engineering detail of both the transaxle design and the lubrication formulation is Toyota. It is possible that various different formulations of lube can meet the same specification (and can be, perhaps, equally "good".) But, there is only one formulation that was reviewed with the benefit of being able to review the application design details - and that is Toyota's WS. (I'm not saying that did happen, but WS represents the only lube for which it could have happened.)
    Use of other fluids (created by manufacturers without the benefit of the application design details) just don't have that same (theoretical) advantage.
    All I'm saying is that Toyota knows more about their application than anyone else, and if I'm going to crawl around on my garage floor changing that crap, I want to use the OEM fluid.
    I did mine at 15,000 mi & 80,000 mi. In both instances, the fluid coming out looked very clean. I still think it's a good idea (for all the reasons already articulated by Frodoz) to have a regular change interval.
  19. eric1234
    392
    201
    Hamden, CT
    Lowly - that's pretty high in my opinion - some of the smartest & most capable people I know are mechanics.
  20. Mendel Leisk
    42,345
    Our service manager calls them "techs", hate the term.
    #560 Mendel Leisk, Nov 10, 2015
    CR94 likes this.
