ATF fluid changes ARE Required.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Bill Norton, Dec 15, 2012.
  1. ChapmanF
    19,025
    I suppose they could measure amounts of dissolved varnish or epoxy, but only if that's something they measure. And I don't know what levels would mean what.
  2. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Third planet from the Sun
    At least the color of transmission fluid that has worked for one hundred and fifty thousand miles is completely different from fresh fluid. Old transmission fluid looks like dark cherry juice, new one is more of a raspberry shade. The consistency is equally liquid at first glance, but here it is better to have a laboratory analysis. And of course the content of metallic impurities that can form when gears interact.
  3. Bill Norton
    Bill Norton Senior Member
    2,244
    754
    MONW, Ks.
    2019 Prius
    L Eco
    You're all in on Toyota sold only products for your car, it seems.
    'Compatibility' like which manufacture like a certain spec for it's lubes?
    The SAE and the ASTM don't work like that. It's the other way around.
    The manufacturers decide which existing spec lubricant to use. Or if they require some exotic new formulation they ask to have that tested, approved, certified and assigned a spec #.
    What would 'compatibility with high voltage winding' even look like? Is there a spec for such a thing? We'll wait for you to find it.....:whistle:
    Face it, with all the new high power EV's out there if it were a concern we would be seeing new lubricant specs.
    The dinky MG's in the prius line up are very small compared to what can be bought with modern EV's.
  4. Bill Norton
    2,244
    754
    MONW, Ks.
    2019 Prius
    L Eco
    Maybe you could,,, if that were a thing....
    I may understand brand loyalty, but this is just their basic ATF used in almost everything they have. There are technically better ATF's.
    The 'dissolved insulation' issue is something someone pulled out of their ....
  5. ChapmanF
    19,025
    I believe I've seen something about it in Toyota docs (from the tech side of the house, not something a dealer service writer to some gullible customer).
    Not having that reference ready to hand at the moment, I won't use this post to argue with you about it. Here's hoping you'll be equally open to new information if I or someone else lays hands on it.
    Bill Norton likes this.
  6. Mendel Leisk
    42,347
    It seems to me I’m heeding the need to use one specific Toyota product, Toyota ATF WS, because the owners manual says, just for this one application, that anything else could cause damage, expensive damage.
    the argument that they’re advocating this to get rich rings hollow, when they don’t recommend a change interval.
    I suppose it’s a free-speech world now, but why not stick to second guessing Toyota’s warning just on your own car?
    Are you a chemist, electrical or mechanical engineer? I sure as heck am not, so choose to respect their caution.
    #726 Mendel Leisk, Apr 10, 2025
  7. Bill Norton
    2,244
    754
    MONW, Ks.
    2019 Prius
    L Eco
    1. .Exactly. So why take anything they have to say on this subject as.. The Last Word?
    They obviously got the 'lifetime fluid' part wrong, according to the scientific oil analysis I posted at post #1.
    2.. Ok, I will and leave the brand loyalty enthusiasts to have their opinion on this subject which are all made up, since toyota has not opinion on this subject.
    Not an EE or ME, but I an a Tech, working hand in hand with them on some incredibly high tech vehicles that you have read about!
    So, one last time, , ,
    Why not use a known high quality synthetic lube that has the specs, instead of the generic house brand?
    (I don't think the answer can be, "because toyota said so.".):whistle:
    When you think about it, the vast majority of Prii go through life without a xaxle fluid change. Only us geeks care about this. (y)
    It's just a box of gears and bearings, 2 MG's that have insulation on the stator and the wires feeding it.
    Is this a concern for any other EV's? Has there ever been a failure blamed on 'insulation break-down"?
  8. Mendel Leisk
    42,347
    Spare me...
  9. ChapmanF
    19,025
    The history with that in gen 1 Prii was already mentioned upthread.
  10. Bill Norton
    2,244
    754
    MONW, Ks.
    2019 Prius
    L Eco
    Right. Something happened 25 years ago. With the first hybrid production vehicle. Yes, and???
  11. ChapmanF
    19,025
    That seems a slight deflection from the fact that your question was "Has there ever been a failure blamed on 'insulation break-down"?, that is, whether there has or hasn't been real-world reason to think about one of the topics of this thread.
    It does seem that Toyota was able to reduce the incidence of insulation break-down between gen 1 and gen 2, through something, or some combination of things, that they changed between those two generations.
  12. bbrages
    bbrages Member
    169
    47
    St. Louis
    I have a master's in mechanical engineering, so I use Valvoline :)
    Fostel likes this.
  13. Bill Norton
    2,244
    754
    MONW, Ks.
    2019 Prius
    L Eco
    Was this all Gen 1's or just an early learning experience for the company?
    So, yes, toyota had some 'situations' with insulation break down when they invented the hybrid and released it in 1999.
    Don't really know the details of this history from long ago.
  14. jdenenberg
    jdenenberg EE Professor
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    We do not know if Toyota changed the insulation to fix the problem or that the change to WS ATF fixed the problem. All we know is that using WS ATF is safe according to Toyota and the history of no (?) winding failures in Gen2+. Other ATFs may be safe, but I will not choose to do the required testing on my Prius.
    JeffD
    ASRDogman and MAX2 like this.
  15. Paladain55
    Paladain55 Active Member
    414
    172
    The South
    I wouldn't worry about the insulation issue as we don't hear about it at all on gen 3. The main point is to change the oil. Severe service 60k, normal 100k miles. I would add a magnetic drain plug. My car towing from 90-180k on its second oil change was just silver when it drained out. Third oil change will probably be in a couple months at 240k. Car still runs fine though. I don't tow with it anymore. Also, been using valvoline max life just fine. Visually it seems the same as WS. Used it in sequoias, 4runners, ls400s, prius all just fine. Easier to keep one ATF on the shelf.
    Fostel likes this.
  16. ChapmanF
    19,025
    I'm not sure how many gen 3 owners will have changed their fluid at all, let alone replaced it with something else.
  17. Andy Pants
    Andy Pants Member
    37
    29
    WIsconsin
    I'm guessing not many as most Toyota service departments are adamant that it is a lifetime fluid. I changed ours for the first time at 173k after reading through this forum. It was completely black in color so I will be keeping that on my maintenance list going forward.
    Fostel likes this.
