ATF WS - Drain/Fill Question?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by CBarr31, Apr 19, 2016.
  1. priusgto
    priusgto Active Member
    194
    231
    Northern Arizona
    I'm also an aircraft mechanic, retired and an automotive DIYer. I guess thats why I don't like others working on my cars unless it's absolutely necessary and if they do, I will inspect their work out of habit and make them fix things that they didn't do correctly. One of my biggest pet peeves are the plastic fasteners holding on the covers under the car. If there's even one missing they will hear about it. I never take "it came in like that" as an excuse which I've heard more than any other.
    frodoz737 likes this.
  2. Mendel Leisk
    42,264
    I take our panel off completely at each (DIY) oil change. And all the fasteners, put them in small tub of hot, soapy water, float the grit out of them. Grit seems to be what jams and breaks them. I think I've had to replace one, in 10 oil changes done so far (every 6 months). And use the proper, correct fittingToyota fasteners.
  3. CBarr31
    CBarr31 Active Member
    436
    225
    Charlotte, NC
    Thanks to everyone for the responses.
    FYI, Ema (my 2006) now has 440,000 miles on her with the original engine, HV battery and transaxle. I think it is a reasonable assumption that the transaxle would be TOAST if I had followed the Toyota recommended fluid change interval. For those wondering the ATF-WS is a "Lifetime" fluid :ROFLMAO::ROFLMAO::ROFLMAO:
    I will stick with an initial change at 5,000 or 10,000 miles, another at 50,000 miles and then every 50,000 miles after that. ATF-WS is cheap and its an easy drain and fill it appears.
    Happy driving,
    Chris
    Roland1555 and Mendel Leisk like this.
  4. CBarr31
    436
    225
    Charlotte, NC
    To all,
    Apparently, the procedure is no longer a simple drain and fill ... or Jim Barkley Toyota in Asheville is clueless. Actually probably the later, lol.
    I had my employee call last week to make an appointment to have the ATF WS drained and refilled. They said no problem see you Monday. He gets there and now there is a "several hour" cool down time for the transmission needed and additional temperature testing requirements for the procedure. All told $300+ minimum ... could be more depending on the Tech's time.
    Of course I told my employee to walk and I will have him drive to my non-clueless dealership here.
    Happy driving all,
    Chris
    #24 CBarr31, Aug 1, 2016
    ETP and Mendel Leisk like this.
  5. Mendel Leisk
    42,264
    Crazy! This is 3rd gen instruction, but very similar.
    ETP likes this.
  6. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    That's because they will be checking critical items such as muffler bearings, johnson rods, and Kuneutson valves and also replacing that old winter air in your tires with fresh summer air. Don't ask questions, this stuff is WAY too technical for you to understand.:rolleyes:
    BTW, my 16 year old son and I did the trans. fluid change in our driveway for $30-ish dollars. (y)
    Merkey and ETP like this.
  7. CBarr31
    436
    225
    Charlotte, NC
    They did not mention these parts if they would have I would have understood the pricing. For that price I should be getting the fetzer valves treated with some 3 in 1 oil and gauze pads as well.
    Chris
    Mendel Leisk and ETP like this.
  8. fotomoto
    5,639
    3,815
    So. Texas
    Ahh, a wise shopper indeed! :sneaky:
    ETP likes this.
  9. ETP
    ETP 2021 Prime(Limit),24 Venza Limit,B52-D,G,F,H
    2,804
    1,170
    Auburdale FL
    Keep us posted on the dealer tranny fluid change. Also they will try to sell you a flush which cannot be done. But could if you are really stupid.:sick:
    Watch out for the famous flush speech.:ROFLMAO::LOL::cry:
    Most customers are really that stupid! I said drain and fill and they said we don't have a price for that or can't do that for a Prius.
  10. Mendel Leisk
    42,264
    In this case I suspect they're sincerely misguided; aren't there some Toyota vehicles that require something like this. Still, if they're going into the job with that amount knowledge and quoted price, avoid them like the plague.
    Again, this mess should be dropped off on Toyota's doorstep, they're behind this confusion. The transaxle fluid change procedure should be:
    1. Included in the maintenance schedule. (they could get themselves off the hook by describing it as "optional")
    2. Explained in the Owner's Manual, along with the engine oil and filter change.
    garglo likes this.
  11. CBarr31
    436
    225
    Charlotte, NC
    Well ... took the car to my normal dealership and they were better at $149 for everything. They overcharged for ATF-WS but I can't complain about that to much. Its nice to have new trans fluid in the car and hopefully all the silicon, aluminum and other wear metals will be less.
    The bad news is my normal Service Advisor was off today and the new one forgot to the tell the Tech to collect samples for me. I specifically took a Blackstone sample vial and a .5 liter old water bottle for Bob Wilson ... neither was filled :mad::mad::mad:
    At least the car has new ATF-WS and everyone has a baseline price to work from now.
    Happy driving,
    Chris
    ETP likes this.
  12. ETP
    2,804
    1,170
    Auburdale FL
    I think I lost my muffler brearings. Did anyone find them?
    The only one of 4 changes I had done that I am sure they changed it is the one I smelled tranny fluid when they pulled it up.:ROFLMAO:
    I try to watch from a distance but it is very difficult to tell exactly what is going on without a proper viewing angle and a pair of binoculars.. Some folks have video recorders which may help. That is what I like about the cheap shops that have a glass viewing room.
  13. Mendel Leisk
    42,264
    Was there more than the transaxle fluid change? That's a bit steep otherwise. Some Canadian dealerships were doing that for $80.
  14. CBarr31
    436
    225
    Charlotte, NC
    No, just transaxle. My employee has the receipt with the rest of the car records. I think the 4 quarts of ATF-WS and other "parts" along with disposal fee was like $70 or so. Then there was 1 hour of Tech time at $80 or something like that.
    Like I said a little steep but well worth it considering the car is 4 months old and has 14,000 miles on it already.
    Chris
  15. Mendel Leisk
    42,264
    Here's my costs, purchases in Canadian dollars from a dealership parts department, in October 2013. These were "list" price, no special discount. Also, 3rd gen is a bit different, think the capacity is slightly more (but still under 4 qts/liters, and the washers vary from gen 2):
    TOYOTA ATF WS per liter: $9.32 (4 required)
    Drain/Fill bolt washers: $1.99 (2 required) (What they charge for washers is robbery, but hey)
    $80 would be a good price, anything over $100 is a little bald. If you can, I'd price the parts, and consider DIY next time.
  16. Autoist
    Autoist Member
    119
    81
    Seattle Metro
    The OP has a 2006 Prius... why is this thread posted in the 2016 model forum?
  17. CR94
    CR94 Senior Member
    2,819
    1,238
    Northwestern S.C.
    Especially considering you don't need new ones, unless you somehow manage to damage or reverse the old ones. Mine came off looking new, went back in the same positions, still looking new, and don't leak.
  18. Mendel Leisk
    42,264
    Yeah, I know. I'm a little obsessive, guess I figure it's an infrequent happening, might as well play by the book. Do the same when draining the engine oil: that washer's only $0.95 though, and just the one.
  19. ETP
    2,804
    1,170
    Auburdale FL
    mine was in the 67-77 range.
  20. Mendel Leisk
    42,264
    Yeah, everything in the 'States tends to be about 30% cheaper, in US dollars. At least, lol.
