Atomic Photos of failing batteries
Discussion in 'Knowledge Base Articles Discussion' started by Mendel Leisk, Oct 28, 2017.
  1. Mendel Leisk
    38,644
    pilotgrrl, bisco, Mark57 and 2 others like this.
  2. fuzzy1
    10,149
    I've had to track down dendrites in a different context. Mine were forming on the surface of a printed circuit board in near-condensing humidity, shorting to a sensitive power supply feedback control node, causing a momentary high voltage condition that blew up a separate part. The high voltage also cleared the dendrite, so the power supply returned to normal operation. Once I was able to reproduce and record some events in action in an environmental chamber, and figured out just where they must be getting triggered, the manufacturing folks were able to see them at low optical magnification. And fix them by changed the soldering process to a cleaner (though more expensive) method, leaving less residual surface contamination.
    But that was easy compared to what these battery guys are doing.
    #2 fuzzy1, Oct 28, 2017
    RCO likes this.
  3. Maybe the challenge isn't to prevent dendrites, but... what if there was a way to use nanobots to repair dendrites automatically?
    RCO likes this.
    49,371
    pretty cool photography. should help in advancing battery tech.
