Attention: If you have a squeaky CHS water pump! New TSB
Discussion in 'Toyota Prius Service Bulletins - TSBs' started by galaxee, Jun 8, 2008.
  1. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    the tsb's here are issued by toyota usa, a separate entity to toyota canada. that's why you're not getting the acknowledgment. not sure if the part is the same across the border, sometimes cold-weather cars are equipped with different parts. could explain the discrepancy...
    Meg&Bear likes this.
  2. JayGoldstein
    JayGoldstein Member
    120
    Winnipeg, Manitoba, Canada
    I thought there was a Canadian TSB, but I haven't been able to find one by searching this site and the Web. Regardless, my noisy pump was replaced (without any argument from my dealer) in 2007. I may have used the TSB from Toyota USA to alert the service manager to the existence of the problem.
  3. Ceres
    Ceres Junior Member
    35
    2011 Nissan LEAF
    Hi everyone,
    I took my 2007 Prius to a local dealership yesterday (South Coast Toyota in Orange County, CA) and the service department replaced the CHS water pump without any hassle. I agree with the others about how much quieter the new pump is. I barely even notice the hum now when it is pumping. As others have experienced, I did notice some gurgling noises when I drove away from the dealership but noise went away after half hour of driving and turning the car off/on to test the pump. So far, no warning lights and very little pump noise. I am so very glad I had it replaced! :)
    This thread was extremely helpful. Thank you to everyone who contributed to it!
    Meg&Bear and KAR IDEA like this.
  4. jsorger
    jsorger New Member
    97
    OK, so I've perused the 100+ postings about bad coolant pumps and still have a question. I'm at about 130k and my pump sound has recently changed (temperatures haven't changed much - I'm in N. CA). No bearing sounds or grinding like in the much-appreciated .wav files. Simply went up an octave or so. I have plenty of fluid.
    Anyone else? I assume it will fail soon, but I'm curious if anyone has experienced this (I'm way beyond warranty).
    Thanks,
    Jonathan
  5. Rest
    Rest Active Member
    1,210
    CA
    How does your SG tell you if the pump is working or not. I have a SG and would like mine to show me this info.
    We have a 2006 and 2007 Prius. The 2006 is making the gurgling noise from the pump, while the 2007 sounds fine. I guess it's time to take it in for the warranty pump replacement.
    I wish they would just give me the pump though so I could replace it myself. After looking over the TSB, it looks pretty easy to do. I hate wasting half a day at a Stealership, only for them to scratch or dent the car.
  6. dogfriend
    7,512
    1,190
    Carmichael, CA
    Set one of your gauges as Water Temp (WT). When you push the start button, if the pump is working and pumping hot coolant, you will see the temp rise after a few seconds. I have the units set for °C, so typically, the temp will be 24°C (ambient) when I first push the start button and rise to about 42 or 44°C after the coolant pump has finished pumping coolant.
    And of course, its easy to tell when the pump has finished, because its so fricken loud. :rolleyes:
  7. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
  8. don_chuwish
    don_chuwish Well Seasoned Member
    823
    190
    Southern Oregon
    Thanks to the OP for this post! I've printed out the TSB and will be dropping off the car tonight at the dealer. Hopefully in the early morning tomorrow they can catch the screech. I'm only at 14K miles now and it's not bad, but it's certainly there. Let's hope the service department does right by me.
    -D
    UPDATE: they've ordered the parts and it'll be fixed next week. Very cool.
  9. JimboK
    JimboK One owner, low mileage
    2,817
    188
    49
    Chesterfield, VA
    After much procrastination I finally got this done today. I almost waited too long. The weather hasn't always been cool enough recently for the squeak to be noticeable, and my drive train warranty almost certainly would have run out before next fall. But the technician worked with me, so to speak, in "hearing" the squeak. ;) He had replaced a couple of others and was familiar with the problem and the TSB. Kudos to him!
    Tomorrow will be a good test. We had a cold front roll through yesterday and overnight lows tonight are supposed to be in the upper 30s.
  10. JimboK
    2,817
    188
    49
    Chesterfield, VA
    Update: Quite a difference! Upon reaching work today and shutting down, nothing but a barely audible high-pitched hum.
  11. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    I've been procrastinating too...guess I'll go in and have it done at my 100k mile service (which I'll do before 100k miles due to the warranty). It's so loud in the winter, but it hasn't every quit, so I just blew it off.
  12. don_chuwish
    823
    190
    Southern Oregon
    Mine must not have been too bad. It would screech off and on before turning off, but now it just sounds like before without the screeching. The dealer also did a TSB regarding the AUX port when I complained about a flaky connection there (wiggle the jack and the sound cuts in and out). But when I tried it after the fix it did the same thing. Hmn... maybe I'll try a different cable!
    - D
  13. alanh
    alanh Active Member
    1,175
    99
    Phoenix, AZ
    One hint -- check your coolant level after a day or two. I had trouble with my dealer not purging the air correctly so it was low (the coolant bottle was empty).
  14. rocketrob
    rocketrob Member
    104
    Los Angeles
    @TheForce: Thanks for posting recordings of your before/after of the pump sounds.
    My '07 exhibits this problem. I have pointed it out to the Dealership a number of times without any corrective action.As compared to my gf's '09 Prius, mine definitely sounds different.
    Lo and behold, I find the TSB here on PriusChat. This forum is a great resource. I will also be ordering the extended warranty through the forums here.
    Cheers!
  15. warcat507
    warcat507 Junior Member
    17
    I reported this sound a long time ago, and everyone said I had one of my cats stuck in my Prius!!! (LOL)
  16. Danny Diesel
    Danny Diesel Junior Member
    38
    I have been back to the dealer 3 time with the squeaky water pump problem.
    With no satisfaction. The dealer says if they can't hear it they won't fix it.
    I brought them a tape recording and they still refused to fix it.
    Sent a letter to the CEO of Toyota U.S. along with a floppy disk of the squeaking noise
    never got a reply.
    I am trying LemonLaw.com next.
    Anyone have a suggestion on how I can get Toyota's Attention
    Danny Diesel
  17. Bob64
    1,540
    93
    Virginia
    Try another dealer? Perhaps leave the car with them overnight?
  18. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
  19. danniel
    danniel New Member
    walnut creek california
    My noise is not a squeak. It is a shrill grinding noise only on shutdown so far
  20. richard schumacher
    7,664
    1,047
    United States
    "Shrill grinding noise only on shutdown" is exactly what the coolant transfer pump in mine sounded like, and it only happened in cold weather. Tell a dealer; Toyota may take pity and replace it under warranty.
    Meg&Bear and danniel like this.
