Attention Kill A Watt Nerds
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by priuskitty, Aug 18, 2012.
  1. I yam vaiting.
  2. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    rumor is, this "Toy" monitors TPMS:confused:
    lensovet likes this.
  3. Tire Pressure monitoring System, and at least 4 other possibilities. Wikipedia.
  4. lensovet
    2,615
    496
    Burlington, NJ
    yeah, some of us are hoping to get readouts of the individual tire pressures
  5. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
  6. lensovet
    2,615
    496
    Burlington, NJ
    No way, you've got tire pressures AND tire temperatures?
    WANT.
  7. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
  8. lensovet
    2,615
    496
    Burlington, NJ
  9. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Here's the user guides
  10. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
  11. CharlesH
    2,797
    1,165
    Roseville, CA
    I wonder why they decided to remove the individual tire pressure information from the display, as illustrated in early versions of the user's manual? They did externalize various features that formerly required an OBD-II device, such as headlight delays and door lock/unlock options, but then removed the individual tire information that is in other Toyotas, such as my 2008 Highlander hybrid. :confused:
  12. lensovet
    2,615
    496
    Burlington, NJ
  13. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Fortunately for me I bought my Mini Laptop with a TV tuner for checking out TV shows while working as a cashier on the late shift at the local grocery store. No longer on the late shift and management frowns on TV watching while on duty. So.....win win....Mini Laptop has a new job!:D
  14. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Windows XP on Android
  15. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    ok, here's the latest, SOC before charging 30.9% 15 degrees Fwt. EV 2.0 miles
    Charge Complete SOC 85.4% 15 degrees Fwt EV 11.5 miles. Calculated KWH 2.2899. charged car on 1-21-2013 at 5:00pm notice the charge status at half lasted 28 minutes. I think last summer it was ten minutes. 01-21-2013 Charging status with temps at 15 degrees.JPG
  16. Edsvfr800
    Edsvfr800 Member
    67
    30
    Franklin wi
    My kila a watt meters accidentally came out of my outlet last night --- lost the whole month of data....crap. Got to find a better way to secure it to the outlet.
  17. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
    The following are not commercial products available to the general public. They are for engineering test and prototyping. I don't have these but work with similar platforms. These are very well done by Texas Instruments.
    EVM430-F6736 - MSP430F6736 EVM for Metering - EVM430-F6736 - TI Tool Folder
    Description
    Currently Out of Stock
    This EVM430-F6736 is a single-phase electricity meter evaluation module based on the MSP430F6736 device. The E-meter can be connected to the main power lines and has inputs for voltage and current, as well as a third connection to setup anti-tampering. It allows a customer to test the new MSP430F673x/F672x series and see the accuracy result, wide dynamic range achieved and ease of calibration. The easy-to-use Energy Library provides metrology software for fast startup with this EVM. The software is also programmable for any user’s needs.
    Features
    • Run real-time electricity metering applications
    • Connects to any test system or AC voltage
    • Several power supply options
    • Easy viewing of results and calibration
    • Metrology software provided
    MSP430 Energy Watchdog Tool - MSP-NRGWTCHDG - TI Tool Folder
    Description
    Note: This product is currently unavailable.
    Going green as an individual consumer just got easier! The Energy Watchdog tool is the latest MSP430 development offering which supports power monitoring applications. The integrated MSP430AFE253 device is perfect for precise measurements using the 24-bit Sigma-delta converter. This is the perfect tool to analyze an LCD display showing how much electricity is being consumed from any device which plugs into a wall.
    Features
    • Integrates the MSP430AFE253 device, the industry’s first programmable analog front end microcontroller
    • Display measurements include
      • Incoming AC voltage, current and frequency
      • Active power, reactive power, apparent power and power factor
      • Energy consumption in kWh
    • Interface to communication modules such as RS232, ZigBee, Sub-1GHz 802.15.4 and Wireless M-Bus
    • Simple push buttons for adjusting LCD display and time settings
    • Schematics and software available
  18. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Here is a video of my setup at my apartment in 3D
  19. mrbigh
    3,686
    699
    Long Island, NY
    I got dizzy...............:censored:
  20. JamesBurke
    1,222
    493
    27
    Morgantown, WV
    Ghostly! But that's my 2001 video card fault. Visual effects you couldn't recreate if you tried.
