Attn: ScanGauge II Owners! Individual tire TPMS data!
Discussion in 'Prius OBDII Third-Party Apps' started by Mark57, Oct 25, 2017.
  1. Prodigyplace
    12,469
    11,718
    Central Virginia
    I suspect if you get a new one it still needs to be reflashed to get these features.
  2. Mark57
    2,945
    2,740
    OK
    It will definitely need the firmware version to support the XGauges. I don't know what production firmware version is shipping right now. It "was" 4.42 before this flash offer. Mine that I got back yesterday with the 2016-2017 Prius code is version 4.45.
  3. Prodigyplace
    12,469
    11,718
    Central Virginia
    Online current is 4.42
    Mark57 likes this.
  4. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    Correction: I did lose 8 of my Xgauges since 8 were added for tire temp and pressure. The limit is still 25 so I have 8 for tires and 17 other Xgauges.
    I did verify that the new version is 4.45.
    Mark57 likes this.
  5. Mark57
    2,945
    2,740
    OK
    New info from James DeLong. He plans on offering the free upgrades through the end of 2017!
    Is that awesome or what?
    fuzzy1, wjtracy, jdcollins5 and 2 others like this.
  6. xliderider
    xliderider Senior Member
    8,139
    3,274
    Honolulu, HI
    Packed up my Scangauge 2 today for mailing Monday. Thanks for the heads-up Mark57! (y)
    Mark57 likes this.
  7. xliderider
    8,139
    3,274
    Honolulu, HI
    Wow, scangauge received on Nov 17th at 1054 am at Linear Logic. Scangauge flashed for 2 Toyota vehicles, packed up, and picked up by USPS at 349pm.
    Looks like James has sent it via priority mail too. What great service! (y)
    Mark57 likes this.
  8. Mark57
    2,945
    2,740
    OK
    They are very good. Great business model for others to follow.
  9. xliderider
    8,139
    3,274
    Honolulu, HI
    Here's the SGII hooked up to the Camry. I have the front inflated more due to the weight of the V6 engine:
    Mark57 likes this.
  10. Mark57
    2,945
    2,740
    OK
    Glad it's working for you.
    I have mine set up to read tire pressure and tire temps for my 2017 Prime, 2014 Camry Hybrid, and 2014 4Runner TEP. It's very easy to swap between vehicles.
    xliderider likes this.
  11. JMJCATH
    JMJCATH Member
    91
    52
    Here
    AutoZone currently has a special on the Scanguage for $119.99.
  12. Fester
    Fester Active Member
    201
    198
    Ohio
    So, if I'm reading this right, my recently flashed SGIIs (now at vers. 4.45) should support TPMS? Are they configured as standard gauges or do I need to enter the codes for the seperate S-Gauges? Anyone have the codes if this is the case?
  13. Mark57
    2,945
    2,740
    OK
    Good price. They will not have these XGauges on it.
    Did you send it to them to flash it as recommended in this massive thread? If not, I'm guessing just 4.45 alone is not enough. If you didn't send it to them to flash, I'd contact their support and ask.
    WilDavis likes this.
  14. xliderider
    8,139
    3,274
    Honolulu, HI
    @Fester, all I had to do post flash was to scroll through the Gauge options until I found the TPMS gauges that displayed readings for my vehicle. I didn't have to set up any x-gauges at all.
  15. WolfpackBill
    WolfpackBill Senior Member
    349
    500
    Lexington, NC
    Well then! If there isn't an end date, I'm gonna pack mine up and ship it out tomorrow!
  16. Mark57
    2,945
    2,740
    OK
    See post 65.
    WolfpackBill and Prodigyplace like this.
  17. Fester
    201
    198
    Ohio
    I'd sent both to them to do a flash (around Oct. 10th) to the newest 4.44 vers., and subsequently saw this thread about TPMS data for each tire. I emailed Linear Logic and got the reply of "experimental/for Prius Prime" etc. When I received the gauges back after flashing, the vers. was 4.45 instead of the expected 4.44 vers. . Nothing then on the website for a change log of what was included on the 4.45 vers. I received back. So I was left puzzled as to whether the new undocumented 4.45 vers. did include the individual TPMS readings.
    Mark57 likes this.
  18. Mark57
    2,945
    2,740
    OK
    If they are on there, the XGauges will already be there from the flash to choose from. Look for T1P - T4P for pressure and T1T - T4T for temp for the Prime.
    They have not yet published the details to key them in ourselves as it's not production yet. There will be a minimum firmware version to work but I don't know what that will be. I got the impression that there was more code added than just the firmware flash to make this work.
  19. rrg
    rrg Active Member
    458
    120
    East coast - NJ
    Mark57 thanks for finding this and posting.
    I just got back my reprogramed Scangauge II with the new Xgauges from Linear Logic (James DeLong) for the tire pressure and Temperature. Very good communication with email and a nice note indicating what was done. A++ working with him.
    One note of caution: I forgot that I originally did the TPMS hack to turn off the light when I put the other set of tire/rims I have and did not want to pay the dealer to reset it. So I had to remove the paper clip/wire hack to see the numbers.
    The new program works as described, so far. My car is a 2011 and 125,000 miles and the tire pressure gauge 3volt cell batteries in each tire still work.
    Here is the tire pressure for each one right down to the decimal point. Very Cool!!
    I just over inflated the tires recently to see if I could regain some MPG since it got cold and my mileage dropped a little.
    I don't know yet which tire number corresponds to which tire on the car.
    It's to cold to let air out of each tire and see which number corresponds to which tire name on the gauge.
    NOTE: I used fine sandpaper to remove the ink of the ScangaugeII to make it look more OEM above the steering wheel.
    The Temperature per tire works and I am thinking that the temp. is 53 deg. on Tire program 1TT not 531 degrees.
    1TT = 53 deg
    2TT = 60 deg
    3TT = 59 deg
    4TT = 53 deg
    #79 rrg, Dec 17, 2017
  20. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    You can identify which sensor code goes with which tire by parking the car in the sun. After a few hours, the sun side will show a higher temperature. Then turn the car 90 degrees and you'll get a front/back difference.
