Featured AU: Toyota stunned as consumers flock to hybrid version of new RAV4 SUV
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Tideland Prius, May 27, 2019.
  1. Prodigyplace
    12,564
    11,779
    Central Virginia
    Wouldn't the Highlander Hybrid HSD work in a Hilux capacity wise?
  2. GasperG
    GasperG Senior Member
    1,169
    601
    Slovenia
    2018 Prius
    The main problem that I see is motor scaling. To cope with constant load it would have to be dimensioned acordingly, and that comes at a price...
    HSD can be made to cope with anything, it's just the question of the price.
    alanclarkeau likes this.
  3. Trollbait
    12,543
    I recall 200F being the point at which conventional auto transmission fluid starts breaking down. Synthetics should handle higher, but I don't know how much higher.
    The gen4 Prius got tranny cooler that all automatic transmissions have, which is why Toyota was willing to give a (low) tow rating. Plumbing in a supplemental cooler is easy once that standard one is in place.
    The Prius got traction control, which couldn't be turned off originally, before other cars in order to protect the system, not just for traction reasons. So more than just the fluid may need to be addressed.
    While many may not tow with their Hilux/Tacoma, it something expected of a truck. The previous HiHy, with V6, had a tow rating of 3500 pounds, and only with AWD to help take the load off the transaxle. IIRC, the FWD, V6 Highlander of the time was rated for 5000. GM's dual mode hybrid trucks had lower tow ratings than the ICE models. Same with the Escape hybrid. The current Rav4 hybrid has a higher rating than most of the rest of the line up, because the hybrid drive train is more powerful. Even then, the Adventure trim, with fancy AWD, has a rating twice that of the hybrid.
    The current Tacoma, depending on equipment, has a tow rating of 3500 to 6800 pounds.
    The new Explorer hybrid, which is likely the system the F150 will get, is rated for 5000 pounds, but it is a RWD, parallel hybrid with traditional automatic transmission.
    The Lexus system that will likely end up in the Tundra is essentially HSD with a 4 speed automatic on the back end. The 'hybrid premium' here is around $4500 on a car that starts at over $75k. That might be acceptable to full size truck buyers of the more loaded trims. I think the real hurdle will be in getting over those buyers' scepticism of the system's durability.
  4. wjtracy
    wjtracy Senior Member
    11,368
    3,608
    Northern VA (NoVA)
    just got the RAV4H
    alanclarkeau, Bab F and bwilson4web like this.
  5. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,592
    near Brisbane, Australia
    Yes, maybe they can never be sure someone won't ACCIDENTALLY overload the towing rating, being a truck:
    dig4dirt likes this.
  6. Prodigyplace
    12,564
    11,779
    Central Virginia
  7. alanclarkeau
    7,045
    7,592
  8. Prodigyplace
    12,564
    11,779
    Central Virginia
    That Tesla has an 8 year unlimited mileage warranty. Somebody just bought one of those with 400K mikes on it. The battery had been replaced once under warranty. The only other large expense was tires. It is still under warranty.
  9. Prodigyplace
    12,564
    11,779
    Central Virginia
    Raytheeagle and alanclarkeau like this.
  10. Trollbait
    12,543
    ICE pick ups can tow train cars.
    Short distance publicity stunts over level ground tell you nothing on how the truck will handle towing over thousands of miles uphill, downhill, through twist and turns, nor if the truck can stop the trailer when it needs too.
