Audi/BMW Style Custom Headlight Assembly for 2010 Prius
Discussion in 'Gen 3 Prius Accessories and Modifications' started by geminikanon, Nov 3, 2010.
  1. geminikanon
    geminikanon New Member
    26
    South Bay
    You are right, conceptually it is quite easy to do the re-wiring ... my problem was that I didn't know these frigging LED lights were hooked up in series! Arggh!
    Although taking the housing apart was a lot harder than I thought, especially since they have been rubber-sealed. I practically had to pry the casing open brute force. Re-sealing the casing was a pain too.
    Posted some pictures of the mod-process.
  2. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    I believe that the reason why Toyota had the LEDs wired parallel internally and using a DC to DC converter is that the LEDs are rated at 12V only. When the car is in ready mode, the 12v system becomes 14.4v This could shorten the LED life. Having a DC-DC converter guarantees each of the LEDs will receive exactly 12V. Also it prevents the LED headlights to be installed in a none LED compliant trims due to the LEDs require height adjustment and headlight washer to wash away snow build ups. A solution to get the LEDs to work is to find a 12V in 36V out DC-DC converter.
  3. sc24vr6
    sc24vr6 Member
    185
    52
    socal
    Are those headlights are for RHD?? if so you might have hard time to see stuff on your right, I plan to get that headlights long time ago but after thought about it I gave up
    BR
    Robert
  4. cproaudio
    2,401
    762
    CA
    Do you see a difference between your right headlight and your left headlight? On my LEDs I didn't notice different beam patterns between the right headlight and the left. When I shine the LEDs to my garage, the beams look the same. I can however see the reflections off the road signs pretty clearly.
  5. geminikanon
    26
    South Bay
    These are purchased from Japan, so I suppose they are intended for RHD. However, the left/right housing seems very much symmetrical, and the light leveling can be manually adjusted despite the leveling motor, so I don't suppose it matters whether its LHD or RHD.
    However, if you are intending to install it on a model V and utilize all the fancy features, I suspect you might have to swap the left and right ECU sub-assembly. The slot and connectors are the same, so that should be an easy swap.
  6. geminikanon
    26
    South Bay
    So. More progress.
    The Prius II/II/IV light system has the following connectors:
    1) 9005 female connector for high-beam
    2) H11 female connector for low-beam
    3) top marker light with 81125-47230 female connector
    4) side marker light bulb connector (don't remember what these connectors are called).
    The Prius V LED headlight assembly has the following connectors:
    1) 3-pin male leveling motor connector
    2) 5-pin male toyota connector:
    a) 3 pins for ECU control: two for LED power and one for control
    b) 2 pins for parking lights
    3) bulb slot for 9005 high-beam bulb
    4) top marker light
    The 9005 high-beam bulb slot need not be moded. So's the top marker light. I can readily use the model II/III/IV wiring/connectors.
    What I did was for all the decorative LED power, I bought 81125-47230 connector from toyotaparts.com, and soldered the male connector to the decorative lights so they can now connect with the parking light connector. This connector was a bit expensive (around $30). I then bought H11 male connectors to route the ECU-bypassed LED low-beam power so that I can connect to the stock H11 female connector for low-beam.
    I then bought 120 SMD LED 9005/H11 bulbs for the high-beam and fog-light respectively:
    2x Car 120 LED SMD Xenon-White Bulbs 9005 Fog/Day Light: eBay Motors (item 280544213867 end time Dec-02-10 04:57:20 PST)=
    So, my lighting system will be 100% LED =D
    Now the last task is to seal the housing with water-resistent seal, and cut plastic to seal the ECU assembly slot. I'll probably custom cut out shapes from some DVD cover.
    Can't believe I had to do so much work after paying 1.2K for this custom headlight. Regardless, I should be happy that this might actually work.
    male connector for
    3)
  7. Much More Better
    Much More Better Active Member
    655
    163
    I admire your skillz and it really does look nice. But I could think of better things to do with $1200 + labour.
  8. cproaudio
    2,401
    762
    CA
    Sorry to tell you but you shouldn't have bought the LED 9005 or the H11. You will not see them from the driver's seat. They're only 1/10 the brightness of halogen bulbs. You should have gone with H11 HIDs for the fog lights and 4300k halogens for the high beams. Don't put HIDs in the high beams. First, it takes a minute to warm up. 2nd, HID's are not made for quick flash. 3rd, HIDs are 2-3 times brighter than Halogens. HID high beams will surely blind the on coming traffic.
  9. geminikanon
    26
    South Bay
    Thanks for your tip.
    I'm not disputing what you are saying, but for the sake of argument, if this were the case, then shouldn't the LED low-beam that comes with the LED headlight assembly for Prius V be inadequately bright as well? Just wondering ...
    I understand that typically the LEDs are of much lower lumen intensity than halogen, but I was just thinking that if it is barely bright enough, why would people even use it, wouldn't that constitute as safety issues?
  10. cproaudio
    2,401
    762
    CA
    They use different wattage LEDs. The OEM Prius V LEDs are probably 10W each and puts out 500-1000 lumens each where the ones used on cheap ebay LED replacements are .06W each for 1210 SMD LED and .18W for the 5050 SMD LED. The 120 LED you've listed are 1210 SMD. The LED that Prius V uses is probably these 1pc 10W White LED Energy Light F + 12V Led Driver - eBay (item 160505441439 end time Nov-16-10 23:30:15 PST) I'm only using common sense here to describe how and why ebay multi LED replacement bulbs are not as bright as OEM bulbs. The Prius V LEDs and many OEM LEDs found other cars face forward where as the OEM housings for filament bulbs reflect the single point where the filament in the bulb is located. Placing those LEDs in filament bulb housings would only reflect a concentrated spot on certain LEDs. The rest of the LEDs gets reflected to directions that's deemed ineffective. This is why the beam of LEDs in filament housing gets scattered all over the place.
    The lights on ebay are for looks. Functionally they don't serve any purpose. Many PC members regret buying them. The only thing I find LEDs are superior over OEM bulbs is replacing interior lights. Even that, you'd need hundreds of individual LEDs. Also they have to point directly into the cabin.
  11. Blackmamba
    Blackmamba New Member
    113
    usa
    The license plate LED mod is a worthwhile one too.
  12. geminikanon
    26
    South Bay
    Just got the H11 SMD LEDs. You are right, they are not bright at all; they are purely decorative. What a disappointment. I'll probably return them...
    There are lots of threads on HID kits/bulbs. Just wondering, has anyone on the forum tried HOD halogens like these?
    H11 HOD HID 6000K 12V 100W Halogen Bulb Headlight - eBay (item 160507689666 end time Dec-17-10 01:25:27 PST)
    This is what I've gathered from the web, the HOD also contains a little xenon in the halogen bulb, but it does not require ballast; the brightness is 3 times as much compared to halogen bulb, but less bright than HID. Price is around the same as regular halogen.
    Halogen HOD
    Luminous Flux 1600 2300
    Brightness 3100 3350
    Life 250hrs 350hrs
    If anyone here has any experience with HOD, whether positive or negative, I'd love to hear it, thanks!
  13. cproaudio
    2,401
    762
    CA
    I also bought some ebay bulbs that claimed to be 100W but after I received them, they are dimmer than store bought halogens. Beware that Hong Kong postage are MUCH cheaper than US postage. It's pretty much you bought it and it's yours. Return shipping cost as much as the item if not more. Save the money and the hassle and get HIDs for your fog lights.
  14. PaJa
    PaJa Senior member
    678
    114
    92
    Czech republic
    HOD bulbs are too expensive if they are for free. Just another China crap.
  15. geminikanon
    26
    South Bay
    I've completed the headlight assembly installation for a while now, but didn't have time to update this posting. Sorry it took a while, but better late then never. All in all, this took me a few weekends, probably collectively around 16 hours of work. Personal thanks to many people on the forum for their excellent suggestions and advice.
    Below are some of the process steps I took to illustrate the process:
    first step is to consolide and short all the individual halo lights, the under-liner LED, the electroluminescent liner, as well as the parking LED and short them into the same parking-light power/ground source to the ECU wiring harness.
    The last picture shows what the resulting parking light would look like.
  16. geminikanon
    26
    South Bay
    The next step is to disassemle the entire housing assembly. The problem here is that the model V headlight assembly's low beam (i.e. LED lights) were powered by the ECU. The ECU up-converts the 12V power source to a 24V power source which then powers the LED lights connected in series.
    So what needs to be done is to rewire these LED's in parallel so that the 12V power source from the ECU harness can power them. I took the power source going out of the ECU inside the assembly, bypasse the ECU unit and tie them directly to the power/ground source of the ECU input harness.
    I purchased the ECU wiring harness from toyota parts, cut off the harness, and install an H11 harness connector at the other end of the ECU wiring harness for compatibility with exising model II connector so that both the parking lights as well as the low beam are now powered by standard model II 12V power supply.
    The last 3 pictures show the completed results during testing (used a standard 12V power adaptor rigged with aligator clamps and such to power the headlights at home).
    Oh yeah, noticed that I changed the parking light from a halogen bulb to a blue LED bought from JDM parts. It gives it a completely new look!
  17. geminikanon
    26
    South Bay
    The next step is to build a custom cover to shield the hole where the ECU unit resides.
    I did this by taking the rubber gasket to cut out a plastic contour out of normal DVD casings.
    I then glued the gasket to the cover using epoxy and further seal it with caulk to seal the assembly from moisture.
    I then glued the cover over the ECU assembly slot, seal it further with caulk. Resulting picture shows the underside of the headlight assembly in its completed form.
  18. geminikanon
    26
    South Bay
    I then installed the fog lamps (nothing special here, there are many postings on this process, so I'll skip this part).
    Then I installed the HID ballasks and bulbs (5000K), and then the headlight assembly.
  19. geminikanon
    26
    South Bay
    Finally. Here's the result:
    Picture outline:
    1) lights off.
    2) parking light.
    3) parking light with fog light.
    4) HID low-beam + parking light + fog light
    5) HID low-beam + parking light + fog light + HID high beam.
    The jury is still out on whether this is worth the money/time ... but oh well, what's done is done. I personally thought they were awesome. Everytime I turn the lights on, it brings out a smile on my face =) So ... yeah, I guess it's worth it =)
  20. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    Looks cool. I'd change the top parking LEDs so all the parking lights match in color.
