Audi making diesel from water, CO2, and electricity.
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Trollbait, Apr 24, 2015.
  1. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    I am not sure about the practicality of this. Reading an article it sounds more like an R&D pipedream than reality, and if it turns to somewhat economically viable at ~$100/barrel with Keystone XL and Saudi OPEC powerplay it will never take off the ground.
  2. telmo744
    telmo744 HSD fanatic
    2,181
    769
    Portugal
    Missed that. It takes filtration/separation, electrolysis, reaction to make blue-crude out of CO2 and water, and from this blue-crude it will need more energy/resources to get diesel.
    Here can I find it in the text?
  3. Trollbait
    12,505
    The diesel infrastructure is already in place, and this isn't the sole pathway for a renewable or synthetic diesel. Along with the vegetable oil sources there is also pyrolysis and thermal conversion. The thermal conversion has been shown to produce syncrude from waste plastic. They, and this process, yield a high quality light, sweet crude. It is closer in composition to the desired end products, and has no sulfur to remove. So less energy to refine than petroleum.
    They likely also have a portion of gasoline. Selecting for diesel is probably just the most efficient and cost effect pathway.
    The NOx still needs work in light of on road testing, but is not insurmountable. Updating the testing procedure to better reflect those on road driving conditions is the first step.
    Barring political interference, Europe is going to require exhaust filters on direct injected gasoline engines. The type the next gen Prius will be running. If the regulations on particulates were written to be fuel and engine neutral, some port injected gasoline engines would need exhaust filters.
    Diesels with DPFs emit magnitudes less particulates than gasoline vehicles. The gas ones just have the benefit of being invisible to the naked eye. So people don't get is fit about them, even though they are likely getting deeper into their lungs than those diesel ones.
    wxman likes this.
  4. wjtracy
    wjtracy Senior Member
    11,366
    3,608
    Northern VA (NoVA)
    Highly unlikely...they are probably using the bogus numbers...dino diesel does not have to be synthesized from scratch, it already exists in nature.
  5. telmo744
    2,181
    769
    Portugal
    Trollbait, The first step is hydrolysis in both FCV or this "bluecrude" process.
    If to a FCV - fill up tank and 65% TTW efficiency, water tailpipe product
    If to the rest of the path to e-diesel - reaction, further refining, 25% TTW efficiency and complex tailpipe emissions.
  6. wjtracy
    11,366
    3,608
    Northern VA (NoVA)
    If I was a betting man, which I am not, I'd buy some H2 FCV stocks. The is so much institutional fear that FCV may be disruptive technology we are <not> hoping for.
  7. Trollbait
    12,505
    But you are ignoring the cost, money and energy, a FCV has over an ICEV or even hybrid, and of getting the hydrogen to those cars. That is the syncrude's big advantage, and the energy cost to make it can be reduced when we use carbon and hydrogen sources besides CO2 and water.
    Recycling plastic is no where near as effective as recycling a metal. Reheating it degrades it; making it undesirable for its original purpose. So new uses need to be found. Most of the HDPE used in milk and juice jugs ends up in composite fiber decking, instead of another jug for a food product. But for less cost than for Audi's bluecrude, we could take those milk jugs, plus water bottles and plastic products that can't be recycled, like the soft plastics in up scale car dashes, and convert them into a similar syncrude. From there we can burn it directly in a power plant or large ship, or refine it into diesel, gasoline, and base components for more plastics.
  8. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Feeling confident ? Volunteer to be the next rat.
  9. SageBrush
    11,627
    2,533
    Southwest Colorado
    Color me skeptical about the energy lifecycle until I can read a scientific paper, but CO2 capture is pretty easy, e.g at centralized power plants. The difficult part is finding something to do with it.
    Consider coal burn at a power plant:
    First pass ~ 35% thermo efficiency, ~ one Kg emitted CO2 per kWh
    Then the collected CO2 + 1.0 kWh electricity -> 0.7 kWh diesel
    So we can view this as a way to convert coal to diesel that costs 30% of coal's energy.
    #49 SageBrush, May 8, 2015
    bwilson4web likes this.
  10. GasperG
    GasperG Senior Member
    1,169
    601
    Slovenia
    2018 Prius
    Coal to fuel conversion was already made in WW2 by the Germans.
    About that second pass, if 1 kWh electricity comes from coal, then e-diesel will only be 25% "coal efficient". And another problem of capturing CO2 at coal plant is that you capture also a lot of other emissions.
  11. Trollbait
    12,505
    The CO2 for dry ice is just separated and concentrated from the air.
    It's just more efficient to only do so for part of the CO2 needed for this process, and get the rest from a combustion exhaust stream. Something is heating the water to steam for it.
    Don't we want to capture those other emissions too?
    Granted, if they end up in the bluecrude, we then have to remove them, but I'm not familiar enough with the process to say if that happens or not. Those others may remain gaseous while Audi's process removes the CO2. Some of them will be removed by scrubbers before they get to the blue crude plant, and the rest might need to be removed before then.
    But this is just a thought experiment. Audi's pilot plant isn't paired up with a coal plant, but a biogas facility for most of the CO2. Some of the electric of the process may come from there(I'm assuming it's a landfill power plant) and the general grid. Though the operational plan, to reduce GHG and costs, is to buy excess wind or solar for it.
    It is the same proposed idea for renewable hydrogen to power FCVs. The diesel ICE is less efficient, and requires more effort to clean up its emissions, but it doesn't require billions of investment on an infrastructure to get the fuel to the cars. The cars are much cheaper too.
  12. austingreen
    austingreen Senior Member
    13,671
    4,209
    Austin, TX, USA
    Audi is not planning to make gasoline, they are doing methanol for cng cars, ethanol to blend in gasoline cars, and diesel. Once they have the methane they can convert it to diesel using the same technology shell is using and sansol is planning.
    I'm sure it was a typo and yes the start is electrolysis to produce H2.
    To provide hydrogen for fcv first you need to build the fcv, which are much more expensive today than similar diesel vehicles.(not sure what audi costs but a bmw 328d which seems much nicer than a mirai costs over $10,000 less than a mirai after tax credits in the US. say the bmw (37 mpg combined epa( needs 65% more diesel than the mirai (? miles/kg) needs 10,000 psi h2.
    Both are using renewables right? How much less will that renewable diesel cost than the compressed hydrogen? Probably alot. Sansol thought they could make diesel for about $4 gallon from natural gas. Lets say that is $4 more than the hydrogen cost, or $4*1.65 =%6.60 more than renewable hydrogen processed at off peak times.
    Now look at what you have to build to fuel the mirai with hydrogen. Each station costs $2M+ each. If you are doing renewable hydrogen centrally, you need to liquify it, and truck it which costs more than that extra diesel cost right there. So you have to build electrolysis at each station, have a tank big enough to store it, compress it, etc. NREL says if you only have 50,000 cars that will probably cost $12/kg. Get 15% of the cars on hydrogen, and you may get it down to $2/kg+cost of hydrogen if you overbuild wind as they are planning in germany. Today its much cheaper to build the wind turbines and convert to diesel, than to build the hydrogen fueling infrastructure. You can also use this wind in plug-ins/
    I would bet that the renwable diesel + diesel car infrastructure, costs less per mile unless some big breakthrouhs are found with fcv and hydrogen. Germany, the US, Japan and others are funding research, but it is a long shot.
    #52 austingreen, May 9, 2015
  13. GasperG
    1,169
    601
    Slovenia
    2018 Prius
    I see PHEV and BEV as the only near future solution and a simple PHEV like PiP should not be that expensive in near future.
    As I said earlier 5 l/100 km of e-diesel is equilinat to more than 70 kWh/100 km and a car like 328d will never reach it ;)
    FCEV with 1 kg/100 km uses from 50 to 79 kWh if it's from water electrolysis
  14. austingreen
    13,671
    4,209
    Austin, TX, USA
    GasperG, I agree completely on the first point.
    On the second, the fuel cell lobby argument on renewable electricity is it will be so cheap that it doesn't matter how much less efficient it is. Let's take an optimistic 50 kwh to make 1kg of hydrogen at a station. In a diesel you might get 60 km (37 miles) on that energy, in a fcv 100 km (62 miles), in an average (104 mpge) plug-in you go 247 km (154 miles). Now in a big central plant you can just turn on the electrolyser when power has excess renewables, and locate this near the wind farms. A stand alone station is not likely to do this unless it has a very expensive tank that lasts a week. I would posit that the hydrogen fueling infrastructure would cost a lot more than the extra wind farms. Charging a plug-in at night would take a lot less net renewables than either other option. Der Spiegel noted that even in 2050 there is unlikely be enough cheap renewables in germany to run a large volume of hydrogen cars, and small volumes make the fueling infrastructure/kg or km very expensive.
    Note on this cheap intermittent renewable hydrogen we could make methanol or ethanol more cheaply per unit of energy and blend it with gasoline in a flex fuel hybrid or phev. That would probably be the most cost effective way to use this renewable hydrogen for transportation.
    #54 austingreen, May 10, 2015
