audio control stopped working when 12 volt battery was disconected
Discussion in 'Gen 3 Prius Main Forum' started by sat narayan, Jun 1, 2017.
  1. sat narayan
    sat narayan Junior Member
    suva fiji
    I
    my mecahnic switched off the 12 volt battery so they could repair accident at place where the battery is on my 3rd gen 2009 toyota prius ..now after bhe switched on the battery ...the audio controls on my sterring in no longer functioning ...this was okay before .....any suggestions how i may solve this problem
  2. Rebound
    Rebound Senior Member
    3,961
    2,609
    Portland, OR
    Disconnect and reconnect the battery... it could be that simple.
    Or, if airbag was deployed in the accident, maybe the mechanic didn't reconnect the steering wheel control cable when he reattached the airbag.
    Or just take the car back to the guy who worked on it and tell him to fix what he broke
    Johnny Cakes likes this.
  3. RePrius
    RePrius New Member
    Bakersfield, Ca
    Clarification: 2009 in Gen 2. Is it 2010?
    The two are unrelated, battery disconnect and steering controls for audio. You might not have noticed steering controls stopped working previously, or it coincidentally stopped working at nearly same time.
    You probably have in excess of 150k miles logged and cassette wiring in wheel is worn. Cheap part and easy to change.
  4. Rebound
    3,961
    2,609
    Portland, OR
    No, sometimes when you reconnect the 12V, something doesn't reboot itself properly. It's easy enough to try.
  5. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    Have you tried ALL of the steering wheel controls ?
    Some of the memory in the audio head may have been lost and some button functions might not work just because of that.
    (Wild guess)
  6. Rebound
    3,961
    2,609
    Portland, OR
    The radio may have a Setup Menu which can disable the steering wheel controls, and this may have been reset unintentionally.
