Audio display froze.
Discussion in 'Prius c Audio and Electronics' started by Mandla, Mar 1, 2023.
  1. Mandla
    Mandla Junior Member
    Oakland
    2015 Prius c
    Turned car on radio played until I turned it off after a short drive. When I started it back up I saw the first photo. E3932719-BDED-42B0-8D23-3B30A73CE5B1.jpeg I held the power button on the radio for a few seconds then it would go black and return to the same screen. Then I held the button and while it was black turned the car off. When I turned it back on I got the second screen. 6315C3B9-1992-46C4-A183-FE64409C1D72.jpeg
    It would load, (the line underneath) the just freeze there. From this point I can hold the audio button down and it just reloads at the screen and freezes/stops. No buttons are functional. The touchpad does not respond to any touch. The unit is nonfunctional. 2015 Prius C. Any help would be appreciated.
  2. Leadfoot J. McCoalroller
    7,133
    6,682
    Pennsylvania
    2018 Prius c
    I don't know if those have a reset or reflash capability accessible to the user.
    On the other hand, I do know it takes all of 8 minutes to swap one with a screwdriver, and junkyards don't usually charge much for these.
