Audio without car running?
Discussion in 'Prius v Main Forum' started by nednvermont, Jan 15, 2021.
  1. nednvermont
    nednvermont Member
    67
    74
    Vermont
    Hello all, I thought there was a way to listen to audio on my 2017 Prius without having to have the engine running (i.e. like we used to be able to do on a 'normal' vehicle by turning key to accessory position), though I've not been able to find anything in the owners manual. Am I mistaken?
    Thanks for your help!
  2. jdenenberg
    jdenenberg EE Professor
    3,961
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Push "start" while NOT stepping on the brake and your Prius will go into accessory mode. It will allow you to listen to audio for a while and then shut off to protect from draining the 12v battery.
    JeffD
    nednvermont likes this.
  3. nednvermont
    nednvermont Member
    67
    74
    Vermont
    Thank you, Jeff!
  4. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Because your 12 battery is so small, expect to need to use a jump pack to start the car if you use electricity when not in Ready.
  5. jdenenberg
    3,961
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Jim,
    He has a Gen4 so perhaps a bit bigger battery.
    JeffD
  6. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Odd, he posted in a Prius v forum. The v has the small battery.
